: Engines and Transmission
  1. vectra problem
  2. removing breather pipe on c20let rocker cover
  3. Changed engine,put an auto into amanual car,loom difference for starter motor?
  4. Changing gear clusters??
  5. z20let 2.2 airbox pipe work
  6. astra g conversion
  7. how good were our 4x4 diffs?
  8. F23 gearbox which is the best one???
  9. seh using f15 help¬!!!!! please!
  10. can someone fit a c20xe into my nova
  11. astra mk2 wont start
  12. engine fuel consumption...
  13. z20let whinning
  14. rwd , xe to carlton box
  15. gearbox
  16. 2.0 16v or 2.2 16v
  17. Help! How do i replace a clutch on a 1.0 12v Corsa?
  18. astra van 1.7 td to v6 info needed
  19. Corsa c20xe loss of power
  20. miss fire
  21. 20xe
  22. Immobiliser Help
  23. RWD c20let exhaust setup??
  24. Cav 1.7td Isuzu - Glow plug light on all the time.
  25. convertion help!!
  26. c20let turbo
  27. Comp test
  28. corsa b ,c20xe cv joints ,
  29. 2.0 seh help needed anyone please!!
  30. Bigger turbo V std management what problems ?
  31. how do you read fault codes
  32. Head Gasket & Timing Belt
  33. Whats the best engine oil for my car..
  34. gsi turbo water hose! help needed asap
  35. 20XE / 20SEH clutch and flywheel compatibility
  36. z20let problems
  37. C20xe timing?
  38. Any simple mods for a Z20let??
  39. standart cam
  40. c20xe fitting help needed
  41. Astra mk3 Oil Light C20XE
  42. Astra Coupe Z20LET Blowing Fuses..
  43. Ebay T3/T4 turbo
  44. Autobox to manual.... (Mk3 Cav)
  45. X20XEV Upgrades
  46. Vectra C 2.2 Hot Start Problems
  47. 1.7CDTi tuning box .
  48. vacume pipes on c20let which way do they go please help
  49. Changing gearbox output drive direction??
  50. c20xe idle 1500 revs to high what can it be
  51. which rotor arm do i have (early redtop)
  52. Help eml light !!!!
  53. late red top
  54. X16xe need more bhp
  55. Egr valve ????????
  56. C20let doesn't start
  57. X20XEV vs 2.2 - differences.
  58. Corsa 1.0 headgasket
  59. c20let fuel pressure regulator
  60. Z20LET conversion - wiring query
  61. ARP torque settings plz?
  62. SEH overfuelling
  63. astra mk4 fuel pump removal
  64. Z20let on ph
  65. 1.4/ 1.6 Ecotec engine differences?
  66. x18xe1 & z18xe cams?
  67. Daewoo lacetti 1.6 will it be vaux powered
  68. quaife shifter
  69. front hubs for v6 astra mk3 conversion.
  70. Astra 1.7 CDTI Starting Troubles
  71. oil cooler problem
  72. let cutting out after reving hard and sometimes pops
  73. oil restrictor
  74. Saab/Vectra engine conversion
  75. Fuelling problems?..
  76. drain plug
  77. C20let Throttle Body Question
  78. h beam steel rods
  79. Frontera 2.2 dti wont start.....
  80. Spark plug analysis
  81. Whats happened to my clutch
  82. Stuck XE valve buckets
  83. astra mk3 cutting out on low revs
  84. 20xe corsa not lost spark?
  85. oil temperature
  86. c20xe ecu help
  87. how effective would this twin turbo setup be?
  88. gm 1.7td head bolt torque settings?
  89. red top in corsa b
  90. Which Companies Can Rebuild The F28 Gearbox?
  91. mk4 astra emissions problem!!!
  92. What cams to buy? help
  93. conversions
  94. Vectra B 2.0 16v Ecotec Engine into Astra MK4 1.6 16v/LPG Van
  95. CONVERSION CORSA B... 16V or V6??
  96. C20LET Forged Rebuild Price
  97. mk4 astra c20xe wiring help please
  98. 2.0seh, bike carbs. Dizzy, advice please
  99. How hard is it too.....
  100. What are these codes please???
  101. upgrades needed on standerd c20let to run 3.5 chip????
  102. C25XE Idle Control Valve location?
  103. 20seh running crap
  104. X14xe to x16xe
  105. advise on fitting a f20 to my cavalier v6???
  106. c20xe not fireing no spark no fuel
  107. Throttle Bodies or Turbo on a z18xe?
  108. Frontera Intercooler???
  109. X20XEV Sump Problem
  110. c20xe engine
  111. mk4 astra coupe sensor
  112. Newbie with 1.7TD cam belt fail.....
  113. C20XE corsa issues
  114. closed
  115. Astra mk3 uprated engine mounts
  116. Another LET problem lol
  117. Throttle Bodies
  118. high idle and hard to start when warm xe
  119. XE Fault Codes HELP (Codes 22 and 74).....!!!!
  120. C20XE TURBO decompression plate
  121. x20xe help?
  122. Dbilas throttle bodies
  123. New car (fuse box one) loom - no starty
  124. E16se Fuel pump
  125. sbd heavy duty fly wheel bolds help
  126. RED TOP pistons full of WATER!
  127. x20xev fault code 73 ??? help
  128. X14XE not starting....HELP!!!!
  129. in need of some advise !!!! corsa c20xe
  130. FSE or Fuelab regulator which one ???
  131. 2.0 8v drive shafts
  132. Can't understand why my external waste gate wont shut?
  133. gearbox Q
  134. c20xe/let inlet
  135. dash lights on mk 4 astra HELP!!!!!!!!!!!!
  136. best oil for c20let
  137. Megasquirt ms1 running c16xe ITBs fuel pressure.
  138. YB Cosworth engine running direction
  139. c20let head studs and heavy duty fly bolds not ARPs help needed urgent
  140. c20xe high idle. please read diff prob to other post!
  141. 2.0 8v driveshaft and hub problem
  142. Vectra 2.0 LS DTI ECU Light on and Loss of Power.
  143. garret t3 or kkk16
  144. Electric speedo vs cable on a corsa
  145. c20let turbo
  146. what hoses? corsa b c20ne
  147. rev limit problems
  148. before fitting a c20let to my vectra what should i do while its on the stand??
  149. Flywheels & clutches to suit C20LET + F20 or F28
  150. x16xe corsa intermitant fault
  151. corsa sport x16xe problems pleasssee help!!!!
  152. Vectra Gsi engine conversion
  153. Good 0-60 time in 2ltr corsa?
  154. Cavalier V6 De-Cat
  155. Help diagnose C20XE problem - Video inside
  156. Vectra Intermittent Engine Management Light - NO Fault codes
  157. turbospares on ebay?
  158. fuel pump needed for 300hp l
  159. F20 gearbox onto C14xx engine?
  160. Mk4 Astra van, how to convert to 5 stud?
  161. injectors
  162. Astra 1.9 CDTi EGR Valve?
  163. Inlet plenum
  164. c20let melted spark plug
  165. vectra c running problems engine light
  166. engine builders
  167. Opel GT 2.0 Turbo
  168. Early XE cuts out once fuel pump is connected?
  169. split my f28, where these washers go?
  170. anyone making tubular manifolds for the zlets?
  171. Any know where to find charging relay on 1.5td Nova?
  172. corsa xe starts buts cuts straight out,some advice please.
  173. C20XE ECU Fault Code 44 Oxygen sensor Air/fuel mixture too lean (weak)
  174. Where does f28 blanking plate go???help
  175. Noise from piston
  176. C20xev c20xe?
  177. turbo flanges t3 and t31 difference?
  178. C20let fuel pump help
  179. C18XEL and C18XE engine management and remaping
  180. Remap on Z20LET
  181. v6 oil cooler
  182. MOT EGR corsa b
  183. Iknow this is stupid
  184. what psi should the oil run at in a c20let
  185. C20XE wont run with pump on?
  186. Which c20xe ecu
  187. c20xe lambda sensor
  188. Early/Late C20XE Engine - How do i tell?
  189. Phase ecu's and power wheels?
  190. Carbs on 8valve?
  191. Air flow meter , where from ?
  192. wideband lambda
  193. 1.6 8v problem starting when bin running
  194. corsa b 1.0 12v to 1.4 16v
  195. de-cat and cherry bomb
  196. 'Porous' Z20LET?.... also help wanted in south shields
  197. Why's someone done this to my tophat/fuel rail?!!
  198. Holset turbocharger cross-section
  199. new car,whole new set of problems
  200. wrecked tbox ?
  201. smokey gsi
  202. Whats needed to run EDS phase 3 on C20 LET?
  203. Corsa B LET Steering Feels Weird
  204. 2.0seh Nova not firing after conversion. Help
  205. Corsa b Ecu upgrade
  206. Help with a flywheel pls
  207. help plz with exturnal waste gate
  208. if the coil amp is broke will it kill power to the fuel pump???
  209. turboing a 20NE??
  210. do you need to earth the coil amp on a c20let??
  211. Throttle bodies on a Xe or Xev?
  212. tubular manifold for LET with T3 flange?
  213. corsa b 1.2 16v stuck on conversion!! please help!!
  214. Can anyone tell what temperature my cooling fan should kick in? [Tigra mk1]
  215. Ngk Iridiums , length query .
  216. vectra c fault codes
  217. car locked me out
  218. radiator fan still not kicking in
  219. fault code 55 on c20let
  220. corsa c 1.0 fuel injection problem
  221. 2.0 8v clutch or flywheel problem
  222. C20xe injoctors?
  223. how to pipe amal valve
  224. Corsa B Redtop Timing Belt?
  225. Changing F20 5th gear
  226. 2.5 v6 fuel/injector problems.wont fire
  227. Corsa X16XE Is Pi**ing Me Off
  228. What gap should be between the tappets and "valve spring"
  229. What air mass meter
  230. wiring mk2 astra GTE loom in corsa?
  231. corsa b 1.4 1993 (Lreg)
  232. c25xe tuning ni
  233. Corsa X18XE1
  234. c20xe crank pully
  235. astra mk3 overheating and fan not kicking in
  236. C20LET Trouble starting when hot .. misfire on boost ... help!
  237. help needed,identifying a turbo
  238. turbo penny valve and actuator dilema
  239. Lowest Crown Wheel And Pinion For F13
  240. Corsa X16XE won't start
  241. turbo cams
  242. Coolant pressurising on engine shut down
  243. vectra sri 130
  244. gearbox issues again
  245. What to do next??
  246. Any one any iders on a trottel cabel for v6 corsa?
  247. nova c20xe cv joints....
  248. Anyone with an e16se. Help needed urgently!
  249. c20let reving 3000 on its own
  250. c20xe timing HELP !!!!!!!!!!!
