- LET question,
- phase kits
- exhaust fitment?
- Whats a good price for a superchip?
- throttle bodies and induciton physics
- injector changing
- Removing the spindle from a LET throttle body?
- 2.0 Ecotec cam belt change.
- Head gasket thicknesses
- Loom Swap
- SO's C20XE idle cut out
- vectra 2.2 sri cam sensor?
- Diesel or Petrol
- Engine lightning
- Back Box on mk3 1.4 astra
- Cheap induction kits
- 180bhp from an xe with zorst, manifold, gas flowed head
- Capacity of Frontera Intercooler
- Injector cleaning - did you notice?
- GTE Fuel pumps
- dizzy question ?
- gears sri turbo
- taking engine out at weekend advice needed.
- Who know's where to get the cheapest steel engine parts??
- Nova 16v Gear-linkage Problem?!?
- Why is my 4x4 light flashing?
- Turbo's MKII Astra exhaust???
- 16se inlet manifold on a 1300 head
- turbo fault code 26
- 1.6xe into a mk3
- Standard compression of an XE
- Ecu opening Help!
- Nos Let
- Some Advice to People Doing the Throttlebody Mod
- ABS & Cav V6 questions:
- Coversion to C20XE (wiring)
- Headway
- help!!!!!!XE experts pls!
- 1.6 or 1.8
- over fuellin or leaking?
- XE perfomance probs
- hugh loss of power,
- XE block on turbo engine please help!
- dump valve/recirc
- Throttle bodies
- speedo with quaffe lsd?
- Gte 16v Injector Probs
- Tbs Vs Carbs loss of servo assistance
- Fuel computer query
- Starter Motor
- V6 Cambelt tensioners and rollers
- knock sensor
- Question on fuel pumps
- Clutch
- Has any1 tried the EDS XE chip yet?
- Drilling 5-stud V6 discs to 4-stud.
- Problems with X.E Engine can anyone help!!
- fitting a quaife lsd
- Corsa GSI
- Starter Loom Pinout C20NE - C20XE
- Valves
- tunability of the 1.6 16v
- looking for somewhere to take my calibra turbo to be sorted
- What TIS says about motronic kangarooing...
- How do you remove a Lambda Sensor?
- astra sxi fuel problems
- 4x4 Light
- popping prob HELP!!!!!
- woodfuff key
- Got my throttle bodies this week
- Pistons.
- Timing belt change
- corsa power steering
- lack of oil pressure
- Engine Number
- fuel sender unit/starter motor
- Turbo rear driveshaft removal, How?
- sump gasket/ gasket paste??
- cav turbo
- xe into astra mk3
- CAT on a XE conversion?
- Carb cleaner safe for lambada sensor??
- 1.8SE Starting problem
- Serious Oil pump Help needed :(
- removing oil cooler sandwich plate
- 20 xe cooling system
- LET Pistons?
- 8v oil pump?
- Changing From F20 to F16
- diff bearings for f28 are they same as f20 and where do iget them from
- XE coolant circuit gen.
- 1.2i MODs
- 1.6 16v tuning help
- Fitting oil temp and pressure guages
- Converting F28 to 2WD
- Really Bad Fuel Consumption
- Induction Noise
- Irmscher 1300 injection system
- C20XE - porous head
- Tranfer box dilema!
- inductive pulse sensor ?
- LET Tappets
- 2.0 16v Ecotec for Astra Sport
- X16XEL Into Nova?
- Its sparking now but not running!!!Ecotecc
- engine differences
- lightened & balanced flywheel, is it worth it?
- how to reduce exhaust resonance??
- Cav turbo's
- What Alternator belt
- Engine rebuild
- fuel guage indicator
- de-cat
- Converting a 1.2 - 1.4
- Misfire+Blacksmoke+PoorFuelConsumption = Crank Sensor Broken?
- Dizzy for XE Carb conversion
- vauxhall cavalier 4X4 ???
- c20 let injectors
- heads &cams
- fuel pump setup theory
- 2wd turbo conversion kit
- Fuel consumption
- xe plate throttle mod
- Astra fuel pump
- Driveshafts
- ecotec 16v 2.o multi point injection
- help. won't start ????
- fuel computer
- LET into Astra.
- After market oil pressure sender fitted
- Scary hike in Fuel consumption - Please view
- Upgrade/bigger intercooler.... help plez
- Mantzel powerbox fitting help
- Sorry peeps.....Powercap info again..plez
- 2WD Converting F28
- Camber Adjustment
- fuel leak : performance Problems
- exhaust wrapping
- Different right driveshaft on a c20xe.
- Bailey Dump Valve (non vaux)
- Converting X20XEV to Z20 LET
- question?20xej
- engine conversion help
- Tuning info for C18XE
- C20 LET plug gaps
- Lexmaul or SBD
- SBD Zorst Manifold Fitting Gen
- Astra Mk3 with Evo 6 intercooler
- Phase 3.5+ what injectors ?
- few questions for all ya technical people
- exhaust blowing
- carb question non vaux but please help
- Injector cleaning
- 2.0 8v --> 1.8 16v
- Fao Pourous Head
- 1.8 and 2.0 8v manifolds, are they the same?
- Wet seat belts
- XE Oil cooler pipes gen
- LET bearing shells!
- C20LET pipework and wiring diagrams
- Ticking Fuel Injector
- Melted piston in a "let"? which one and why ??
- Wat engine has...?
- exhaust
- ceramic coating
- Engine Conversion
- is there anybody who has really cured c20xe hesitation??
- Best place for oil temp sensor.
- gearbox
- Cav 4x4 question
- New injectors???
- elternator swap on 20xe nova
- let boost temp
- Eds ?
- Solid or hydroilc
- 50/50 Spilt Transfer Box?
- Superchips + xe?
- 2L 8 V Engine age of manufacture?
- quick starter motor question
- C20LET chassis bush upgrade
- Help please : Nova cam?????
- Which chip with my engine?
- Angry Turbo Company
- 6 speed sequential F20
- Turbo PS Fluid
- Airbox modification
- lapping valves
- Water Injection?
- 2.016v Wiring Loom Diagrams Please!
- c20let holding back again please help!!!
- FSE valve
- dbilas throttle bodies on 2.0 ecotech
- let boost
- good head for RDS.
- Changing clutch in 20XE Nova
- 20NE engine parts
- engine swap????
- Dump valve???
- anyone with phase 3.5 and k26 turbo
- GTE 16v Cats
- 20 XE Wiring loom
- 20xe / f20 driveshafts
- which grade of oil
- f20 and f28 diff bearings are they the same
- Turbo oil feed help lease
- 20 xe in mk gte 8v
- Head gasket or Porous head??
- Phase Sensor ?????
- engine change....????
- FAO of anyone whos fitted an EDS intercooler
- URGENT ADVICE PLEASE (pic)
- Wheel fouling gearbox.
- Gearbox model no.
- Will a C20LET fuel pressure regulator fit a 1.6 16V?
- phase 4 power upgrade
- urgent how do i identify a quaife lsd
- benifits of a Gas Flowed Head
- Nova Radiator
- Head bolts threaded........
- how much life is left on my clutch???
- boost problems
- Fuel pre-filter - what the heck is that?
- HELP!! on C20XE
- let fault codes
- Gearbox oil query
- Changing gerabox oil on F20
- Oil Pipes
- Intercooler Dilemma?
- HELP URGENT! need to make window loom
- Help!
- Phase 3 Kit
- LET into corsa c
- What gearbox do i have.
- Vuax Engines
- Nova C20 LET Help. (again.)
- Tuning dilema & Cam choice
- Early xe flywheel...
- A burnt speedo cable and now on the boil.....
- Calli engine transplant question
- cally engine transplant question
- Oil pump question
- Free Power
- C20XE dying high revs!!
- mixing oils
- Whats torque and power gonna be?
- uprated xe clutches...
- valve train parts for c20xe
- Jenvey inlet manifold
