: Engines and Transmission
  1. In tank fuel pumps .
  2. Fueling problem 1.7tdi Isuzu
  3. corsa c big block hubs, which bearings to use?
  4. Pourous GM Heads
  5. high idle on my corsa xe
  6. Engine chappy when warm??
  7. overfueling problem
  8. Redtop into corsa
  9. conrod for 2.2
  10. xe to carlton box no clutch pressure plz plz help
  11. Vectra GSI Misfire
  12. c20let correct throttle position sensor? cutting out on boost after track day
  13. c20let ICV wires
  14. supercharging V6
  15. Flashing Engine Management Light?
  16. C20LET NGK BKR7EIX Gapping
  17. 1.3 cdti corsa to z20let conversion possible?
  18. Nova c20xe hesitateing before hard accelaration
  19. C20LET Head Problems, Advice Desperately Needed Please
  20. XE exhaust gasket on an LET
  21. C16XE starting problems
  22. C20xe sump gasket choice,
  23. Photo Request, C20LET corsa with PAS setup
  24. closed
  25. closed
  26. corsa b sri - can i put corsa gsi cams in my 1.4sri??
  27. zaf intercooler on ebay
  28. engine help - x18xe1 - z18xe ?
  29. XE teething problems.
  30. Cv joint question
  31. oil pump
  32. F20 Speedo ring part number .. Where from
  33. Z20let Coupe. problematic..
  34. CODE 42 HELP speed sensor voltage
  35. what to do with 1st gear sensor plug help
  36. c20let rebuild or not?
  37. best brakes and shocks calibra4x4
  38. bosch injector application 0280 150 832 what car?
  39. vxr injectors on my z20let
  40. Adjustable Cam shaft Pulleys x20xev
  41. c20xe with f18 not running reverse??
  42. Astra G X20XEV Fuel Pump Constantly Running
  43. cav v6 running lumpy at 3000rpm
  44. what gearbox for RWD with an XE?
  45. diesel boost pressure
  46. 3.8 bar fpr question
  47. c20ne into x10xe
  48. water pump quickie
  49. steam through centre airvents 1.7td izuzu engine
  50. F13 gearbox info
  51. which gearbox
  52. 1.0 12v to 1.4 16v swap !
  53. Crankshaft sensor?
  54. will my f23 clutch fit the c20let flywheel?? and should i get a lightened flywheel??
  55. do i need a fuel tank or just the fuel pump?
  56. c20xe early type clutch part number
  57. Wideband free air set up.
  58. Quick question (C20LET vacuum)
  59. corsa b 1.4sri
  60. Fitting a Turbo to a 1.8 SRi Astra G?
  61. Z20LEH and adjustable pulleys
  62. which pistons ????
  63. stalling cutting out but only when fan comes on!!
  64. 2.6 inlet on cavalier v6?
  65. No return oil valve on ecotec block
  66. astra 1998 1.6 8v prob
  67. what gearbox for astra g 1.7 cdti
  68. Whats the best replacement Dump/Blow off Valvew for Astra Coupe Turbo Z20Let
  69. any one know if a y17dt engine is a valve to piston contact if oil pump pulley broke
  70. tunning z20let with an ebay remap
  71. c20xe air flow meter PROBLEM!!!
  72. poor idle when sfter fan
  73. what gearbox
  74. VXR turbo on K16 Manifold
  75. let dumpvalve
  76. Turbo or Valve Stem Seals?
  77. piston trouble
  78. inlet and exhaust questions
  79. Corsa gearboxes
  80. what cam for 16 8v
  81. C16XE Intake Manifold
  82. pistons
  83. nova rose jointed gear linkage with quick shift
  84. starter motor
  85. Astra Mk4 2.0 16v exhaust manifold
  86. Exhaust rubbers worth getting poly ones?
  87. Speedo / Gearbox issues, Help please.
  88. Anyone ever fitted a Walbro/Sytec fuel pump etc to a Vectra B?
  89. C20let / help
  90. vxr injectors for zafira gsi
  91. Vxr Heating Problems
  92. z18xe injectors
  93. Engine Code For BMW Engined Omegas
  94. Any Z18XE Corsa B's help needed..
  95. astra gsi mk3 exhaust
  96. front strutbrace on a turbo corsa b
  97. info about running my isuzu 1.7 td engine on vegi oil?
  98. help... shafts c20ne...?
  99. cav inner cv's
  100. c20xe into corsa shafts
  101. standard let bottom end 330bhp?
  102. van v6 conversion
  103. 2.0 red top in astra mk3 will it work ??
  104. the dreaded emissions test......
  105. c20xe 4-2-1 exhoust manifold on x16xe in tigra
  106. 1.4sri
  107. what engine in 2002 vectra
  108. XE sandwich plate removal
  109. 1400 16v Vauxhall engine into rear wheel drive - Ford Anglia 105E - help/info ???
  110. c20xe lightened flywheel
  111. XE and LET valves the same?
  112. mk2 astra dash and corsa c hub, speedo reading wrong......
  113. turbo a 1.4sri?
  114. good fuel pump upgrade v6 ?
  115. anyone ??
  116. Corsa C C20let Mounts
  117. Coupe turbo tuning?
  118. gearbox leak
  119. How to Astra 2.2 turbo?
  120. x20xev engine weight
  121. C20LET coolant connector?
  122. vauxhall astra 1.4 mk3 help with the gearbox
  123. c20xe Redtop Turbo Conversion
  124. z20let stutter
  125. chevette engine and gearbox???
  126. R1 Carb trouble still, with a Vid!
  127. Torx Socket Size for Ecotech
  128. 2.5 v6 fuel pump on c20let
  129. Wiseco Piston Rings, where from?
  130. Z18XE1 and X18XE Exhaust Compatibility
  131. opinions on best management ecu for c20let
  132. Where is the switchable live? :S
  133. MK3 X17DTL water pump bolt torque setting?
  134. Gm 1.7td compression figure
  135. water from rear of engine c20xe
  136. xe in corsa idling at 2,000
  137. Fueling/ swirl pot help
  138. X16XE spark covers?
  139. xe to let engine
  140. major oil leak
  141. c25xe cylinder head tightening torque sequence wanted????
  142. who best to hybrid my vxr turbo???
  143. Rev-matched downshift - why isn't this implemented in software?
  144. Welding a cracked head?
  145. f23 gearbox from 1st to 2nd syncro allready changed twice
  146. piston compression ratio
  147. c20xe corsa gsi doesnt like to be turned off!!!
  148. c20xe Rev Limit
  149. c20xe corsa gsi doesnt like to be turned off
  150. XE corsa erratic idling out of nowhere?????
  151. how do you read falut codes
  152. 20xe airflow meter prob
  153. X20XEV Into A Corsa B
  154. Dbilas tb's
  155. Vectra C 1.8 petrol, What gearbox??
  156. Dignostic port on 2litre cavalier
  157. Astra mk4 1.6 to 1.8 engine conversion
  158. x20xev corsa b help!!!
  159. F28 broken?
  160. Astra Coupe Z20let Not Starting
  161. hellp knock sensor 1 on c25xe
  162. Installing Quaife ATB in to F20
  163. c20let late type head bolts
  164. F16 vs F18 gearbox
  165. c20xe corsa not getting any spark
  166. c20let rebuild now not running right help please
  167. c20let and x30xe is it true bore and stroke are 86mm?
  168. V6 mk2 Astra
  169. Turbo wastegate sticking?
  170. c20xe head rebuild
  171. astra sxi 07 plate missfireing
  172. Manifold on c20xe??
  173. Pulsating brake pedal - R1 bike carbs
  174. z20net vs z20leh z20let
  175. c20xe with no engine number? where is it?
  176. x20xev into corsa gsi
  177. c20xe no spark? no codes?
  178. straight exhaust from turbo to b box
  179. shaving/milling c20xe. How far should i go
  180. Standalone ECU on Z18XE
  181. What F28 for M reg Corsa GSi?
  182. c20xe corsa running probblems
  183. 1.4 turbo 8 valve ..
  184. mk3 1.6 16v revving problems
  185. x25xe in astra g clutch/gearbox somebody please help!!
  186. What Exhaust?
  187. 4x4 transfer box
  188. saab turbo engine question
  189. f23 4.1 final drive
  190. all astra coupe z20let components into a mk4 astra 1.4 or 1.6?
  191. what chip set up is best
  192. x14xe mk4 astra, throttle bodies on standard management?
  193. pics and info please
  194. c20let not running right
  195. xe only firing on 2 and 4
  196. nova c20xe exhaust and manifold
  197. F28 linkage?
  198. Converting Astra mk4 to redtop
  199. Re-occurring E C U fault.
  200. 20NE gearbox for rear drive!
  201. C14SE head onto 16v bottom end does it go????
  202. Could this be oil pump?
  203. noisy tappets om xe??
  204. Mk4 Astra van engine change
  205. LET Cometic Headgasket Failure? with Pic's.
  206. 1.7 td GM low blow not starting
  207. Veccy 2.5 GSi tapping
  208. info needed please
  209. c20xe piston damage
  210. Very hot c20xe
  211. f23 gears problems
  212. damp starter motor / electrics?
  213. Servicing c20xe
  214. c20let into vectra...do i need the carbon canister and hot start valve?
  215. Where to get helix paddle clutch?
  216. accelaration trouble
  217. drive shaft removal from quaife boxes?
  218. X16XE engines
  219. head's gone porous but has been sleeved..
  220. c20xe corsa not starting
  221. P0420 Z20let fault code
  222. microchips tuning are they any good
  223. plz look at videos and let me know if you know the cause
  224. Head gasket or other ??? Please Help
  225. Screamer Pipe for LET
  226. What Are These Called (Engineering type people).........
  227. Side exit exhuast question
  228. F20 gearbox internals + castle nut for diff
  229. MK2 Astra, C20LET + F28 mounts?
  230. how to mount a f28 gear linkage
  231. Exhaust
  232. Are nova and mk2astra rear gearbox mounts the same?
  233. C16xe problem air flow meter
  234. Cone filters
  235. fueling problem on 1.4 corsa
  236. purge canister pipes
  237. egt
  238. xe inlet cam in c20let
  239. astra 8v mk4 very poorly blue smoke any ideas!
  240. Parts wanted
  241. Difference in bottom ends in years
  242. estimate bhp on my corsa c20let
  243. Z20LET Engine problem
  244. starting + running c20xe
  245. Vectra X20XEV Problems. Rev Limit at 4.5k???
  246. Como van rumble at certain rev range
  247. very interesting trouble with cooling (c20let)
  248. corsa sport x16xe problem?
  249. m reg corsa b gsi bogging down help
  250. C20xe,f20.gear box.only get 2nd and 4th gear..help!!
