- Corsa EGR removal
- SBD's Oil pressure relief valve
- Turbos and Cams
- Throttle Boddies in a MK2 GTE
- Oil Pressure
- throttle boddies
- Exhaust Fitting Help Needed
- 2 or 3 pins CTS diff?
- Flexi Exhaust Gen
- Urgent: Nova in tank pump what better one fits?
- XE wiring ?
- breather
- I dont have a cat so do i need a lambda sensor still???
- disconnecting amal valve to actuator pipe
- C14SE tuning?
- im looking for a rover engine.
- wheres the engine number on C25XE
- 20xe over fueling
- Few Niggles witha redtop
- Whats the equivalent to a clutch on an auto....
- ECU on a 16v ecotec Cally
- Pop goes the transfer box
- ++help Turbo Boost Problems (tc113)++
- C16XE Questions
- Fuel mapping
- Camber adjustment problems (fancy image included)
- Have I melted a piston?? LET
- C20LET not boosting right
- tiresome GF's C20XE
- pressurised fuel line does it influence performance
- Things to do with the C20LET whilst its stripped
- Which dump valve is this...
- New engine pics
- TAS dump-valve
- cally lowered. camber problem?
- URGENT:Camber correction kits??
- which exhaust is best for a cav gsi
- XE Cambelt Tension
- major prob with c20 let.
- 4x4 Transfer Box Workshop Manual
- Cav Fuel Computer ??
- Realy need decent clutch advice!
- URGENT: Anyone who has stripped/rebuilt an LET
- TO ALL NOVA/CORSA 1.4 8v SRi OWNERS
- 16SE Sump?
- is my sump supposed to look like this?
- phase 3.5+ problems
- where can i get a fuel rail pressure valve
- Exhausted
- Sealant on the oil pump to block face?
- r avo coilovers serviceable??
- Fault code on cally t
- Powerflow Exhausts
- Increasing capacity of small block 1.6 8v???
- Lambda sensor on mk3 cavi
- XE problems please help!
- cat replacement gen?
- Headlights on MK2 Astra won't switch off???
- Aftermarket Oil cooler
- v6 cam question
- engine out WHAT MODS????
- how can u test an ign coil??
- fse boost valve
- Custom Exhaust In Essex?
- Mating xe manifold with nova exhaust
- Nova XE radiator
- Anyone got Courtenay suspension??
- black wire from ecu to coil
- Switching fuel pump relay to imobilise car?
- valve stem seals - AutoVaux vs Vaux
- Are early XE rods forged?
- FSE Power Boost Valve Guage???
- Best clutch for phase 3?
- Camshaft housing C16SE
- How i can desconnect the gearbox linkage?
- Cooling a LET
- Damn fan belt is p*ssing me off, somebody stop the squeeking!
- Tin sumps
- How to remove rear seatbelts on astra mk2 ?
- Valver timing
- mv6 cams in a vectra 2.5???
- Astra clutch needed
- Cavalier Clutch ?
- Dodgy Lambda & V6 performance.
- engine model
- Urgent sump question!
- Can the Gearbox on Mk3 Cav be removed from the top?
- 1.4 16v TB Turbo
- XE Hydraulic lifters again
- HELP in C20NE removing...
- Best gearbox for accelaration
- Problem wiv spax rsx coilover kit
- Injector cleaning
- C14SE Cambelt Snapped - What state is my 'head' in?
- C20XE main end bolts
- indicator trouble
- Engine cleaning
- let fault code 81
- How to alter the the throttle cable??
- Petrol gauge on digidash gone loopy!
- bigger head to lower compression?
- Problem While Racing 2 Punto GT Turbo's
- Perfect Power Management System
- valver nova brake set up
- valver manifold on 8v?
- Driveshaft plunge
- why would the boost gauge needle flicker on high boost
- Arrows Steel Rods
- Engine management light
- gRADES OF OIL ?
- Phase 3 software fitting (pic)
- wiper linkage
- Mk2 GTE transducer wire colours/locations?
- Fuel Injection bulb
- nova leaking oil
- drive shafts
- squeak_clutch noise/spring?also digi dash prob
- car won't start, i think it's this-what is it?
- Apexi AVC-R and S-AFC
- C18XE Milage??
- What Fan belt do i get?
- stimulating the ABS solenoid on cally turbo
- Modifying Astra manifold for 2L Nova?
- Oil pumps - mmm greasy...
- LET head gasket - decisions?
- Manifold help!!
- Engine question
- wheres oil light on 16v calibra
- c20 alternator wiring
- Change of Engine in an Astra Mk2
- f16 + f20 wots the difference???
- What box to use to replace my F16 WR
- Running engine in
- which one is it&pump volts
- Turbo running lean!?
- Sump Bolts
- Mk3 Astra headlight height adjuster
- Cav GSi exhaust probs
- Sumps
- Turbo
- Cleaning up blocks
- F16 long or short ?
- Idle control Valve
- Lambda! the saga continues
- 1.8 16v ecotec idle speed low
- Genuine Oil Pump vs. Others
- C14SZ on twin 40s?
- sparkplugs white - mixture lean ??
- 2.0 ecotec code 93 ?
- FSE Boost Valve?
- Fitting a T3 Turbo to a red top
- GSI 4x4 Question??
- xe cylinder head breather mod...
- C20XE into a Astra Sport
- Redline shockproof oil vs F28?
- Early XE belt tensioner and roller
- phase 3.5 fulling
- phase 3.5+ what is lamba cut
- Easy XE questions
- Is My Water Pump Dead?
- 16v TURBO into ASTRA GSI
- +20 bhp for £3.20 on e-bay??
- Does Mk3 Astra GSI EX manifold fit 1.8 16v Astra too?
- C20XE Fuel Consumption...
- fuel consumption SPi
- What code is used to write a motronic chip?
- 16V Cam timing explained?
- Exhaust advice
- Car brokedown! (poss. fuel pump???)
- Stock LET fuel pressure
- x20xev cav & vectra inlet manifold
- c20xe rebuild
- 45's carbs on 20XE...
- Exhaust mounts
- C20LET overheating etc
- Best Exhaust bore (2.0 16v)
- cams
- Engine tuning advice :)
- LET in nova
- How to recon a Red Top?
- Cav turbo induction
- Can anyone help ??? 4x4 problem...
- Best oil for C20LET
- oil pumps???
- Damn..problem again with tappets... i need help.
- Wiring Fuel Comp ?
- XE Crankshaft Pulley?
- 1600 16v exhaust manifold for nova?
- lambda sensor??? wtf
- urgent advice spark plugs
- 20XE Engine oil
- i think i have sorted my phase 3.5 problem
- turbo fuel pressure 3.6 bar with vac pipe 4.2 withouton idle
- Motronic management
- 1.6 CVH dizzy wiring
- F20 2WD and F20 4x4 differences
- Up-grading from a KKK Turbo
- Power steering fluid leak - On Calibra Turbo
- Cavalier Head
- Changing clutch and transfer box on Cally Turbo?
- 3rd gear response naff.
- Is brake master cylinder any differant on a GSi to a Turbo?
- engine/heating probs
- x16xe model advice?
- easymap user profiles?
- Dead Turbo charger
- 20XE breathing/banjo/water circ
- optimax n head gaskets/
- turbo faultcodes
- 1.4->1.6 Exhaust Manifolds
- Aquamist 2d WI system
- turbo plug gaps
- Twin 40 Manifold
- Clutch Input Shaft - Removal
- v6 engine mounts
- what causes oil starvation on a let
- Possible Causes for underfueling?
- xe revving up after thrashing
- V6 head porting work
- e16se bigger injectors gen?
- the 20xe
- Does anyone have an F20 fitted to their V6?
- A slice of XE
- Gear linkage
- 2 clutches later...
- How much power on an XE with these mods?
- Fuel pump probs on c20xe
- Valve Guides
- C20LET "top hats/plenum chambers" wanted
- sump leaks and rubber gaskets?
- i need an oil adaptor brkt
- HELP, custom exhaust places??
- Power caps!
- cat pipe
- C20 LET pulley question
- suzuki swift engine into a nova
- looking for engine boost for kadett 1.4 SE
- F20 Uprated Clutches
- Cams
- MBE loom colours for lambda sensor
- Red Top Tickover
- Questions on C20LET
- FAO XE type people
- Fuel pressure gauge - best place to get one?
- what is the hydraulic lifters?
- Exhaust Manifolds
- tps issues
- What is a "Blueprinted Engine"
- anyone got MBE on a let
- spax coilover help
