- 1.4 8v mpi head on a 1.4 16v engine block
- x18xe1 engine
- Help with a c20 let needed
- corsa b gearbox?
- f20 gearbox trouble
- gear selector rod gaiter size?
- C20let oil cooler
- 1.2 8v belt snapped help
- Astra 1.9 Vibration, help?
- C20xe Timing set up issue HELP
- Engine management help x16xe
- cali turb rear diff
- MG Roadster up keep
- Just bought r1 carbs for c20xe
- doing 1.2 corsa c headgasket?
- external fuel pump set up?
- C25XE running issue
- Corsa C 1.2 Auto to Manual conversion
- x30xe
- whats the best diesel engine to fit to a mk4?
- stupid turbo question - can you use a diesel one on a petrol engine?
- vectra x25xe plenums on c25xe.
- v6 throttle body mod
- C20xe running badly
- corsa 1.8 will not start eml light
- Vectra b 2.5 v6 electronic whining noise.
- 1999 1 ltr corsa b engine turns off funny
- C20 LET coscast head question ??
- Which Drive Shafts?
- Astra 1.9
- C20let boost pipes
- Gearbox
- C20xe metal tensioner failure??
- corsa combo 1.7 gearbox
- mantzel wont idle!!
- How do you change the CAM sensor?
- c20ne Conversion Help !
- Corsa td 1.7 cdti mods?
- Which plug for a 280bhp LET?
- 2l redtop into Corsa help
- T3 Turbo Advice.
- Help with turbo engine C30NE
- F28 gear linkage corsa b
- astra 4 coolant light on.
- Engine Swaps
- C20LET/Chevette conversion "distributorless"
- Mk4 Astra Part Numbers
- corsa redtop problem pls can some one help!!!!!!!!
- My car has just died in heavy rain!!
- drive shafts, knucles and gearbox issues help
- LET running anti lag + launch control
- renualts laguna engines 1.8 auto
- x14xe engine into z14xe car body
- engine number on c20xe
- Clutch cable
- 20seh ECU
- Help needed - stuck with my calibra turbo project!
- kenlow fan test to see if works
- radiator blocked ???
- Juddering when cold but fine when warm?! NEED HELP!
- xe trouble ! again
- z20let Turbo unit
- Astra H easytronic starting problem
- tigra exhausts same as corsa b...???
- D.I.Y exhaust system advice
- astra mk4 gearbox?
- C20let injectors
- X10XE inlet air leak?
- urgent pic of a team dynamic twin cut back bladed turbo
- Corsa VXR wiring diagram
- c20let flywheel thickness?
- let coilpack
- link engine management!
- XE into VAG?
- does the saab 9-5 2.0l turbo go in the astra mk3 ?
- astra mk3 overheating after water pump and thermo
- engine management light on !! astra mk3 x16xel engine
- C20xe gearbox
- Help needed please prop shaft bearing rubber.
- clutch and flywheel for a v6
- 1.4 8v missing on idle
- Gearbox opinions
- ecu gsi 1.6
- Mk1 astra gear shift
- headgasket?
- Corsa C20XE modifying
- what should my c20let idle at?
- F13 gearbox very quick question
- 2.0 8v manifold
- ARP settings with pec rods ?
- corsa redtop not firing
- white exhaust outlets rich or lean?
- Which injector is best for my engine???
- Waste Gate Pressure
- Corroded C20XE engine number?
- 3l v6 conrod dimentions?
- corsa b conversion
- Throttle bodies on dissy type xe?
- MK4 astra 2.0dti sportive fuel problem
- What else would you suggest?
- c20let exhaust stud
- best mods for a standard c20let engine to bring up the power?
- whats the thread size on x25xe lamba sensors?
- 20XE conversion done, how to read trouble codes?
- Low oil pressure on start up?
- X14XE ARP rod bolts ?
- 2.5 and 3.0 cam specs
- X14XE on throttle boddies, please help :P
- corsa redtop van splutters
- Vectra 2.6 oil leak ?
- auto v6 engine on a manual gearbox
- tigra 16pin plug wireing
- show me your heads, X16XEL
- f23 oil change help
- Omega 2.5td Auto box issues, any help???
- help please
- MK4 Astra 2.0 XEV Occasional Non Starter. Fuelling being shut off. Help.
- whats the flow rate of x14xe injectors ?
- X14XE cam belt tensioner torx bolt stripped, what to do ? please help
- new c20 let project
- information on 4x4 ing a corsa b
- astra 1.6 8v spi into a corsa b...problems idleing!!
- GTE rear beam
- Icon Vernier Pulley - Bolt & Washer or Just Bolt
- c20xe and f17 box
- CALIBRA computer?
- slight whine from transmission on C20XE F16 gearbox
- C20xe map sensor?
- Fuel pressure EDS phase 3 please???
- HOW TO USE 1.3 CDTI Timing tool???
- astra mk4
- What boost from standard diameter pipes .
- Need urgent help please!!
- vectra b 2.2 dti reverse jumpmg out now no reverse gear all other gears are fine
- Corsa XE Info needed
- water pump away corsa sport
- cam shaft bolt torques needed
- redtop service??
- x14xe throttle body to inlet manifold diameter
- C20XE dizzy to coil pack conversion
- isuzu 1.7 flat fly wheel?
- Piston Compatability
- c20xe into astra g van
- signum z20let
- crank journal size ?
- 54 plate Astra Auto starting issue ( with F light ? ).
- 1.2 nova - how much oil from empty?
- wanting to fit z20leh in corsa c what do i need any one no of a list
- Corsa 1.6 16v inlet manifold made?
- How has this happened? (Timing belt came off! - Pics)
- combo oil pressure,
- x14xe engine tuning tips please
- R1 Carbs on Motronic 2.8 C20XE?
- C18xe mk3astra gsi problem
- C20let - reliable?
- Spark plug choice
- 1.2 corsa c to 1.8 sri
- changing a wheels et ?? (fitting porsche wheels)
- gearbox help
- corsa 1.2 16v engine. box.
- Abs light problem
- x16xe fuel pump running c20let
- c25xe, cambelt getting hot??
- x17dtl remap or tuning box
- need help determine engine type ??
- head work :S
- Corsa B Rear Disc Conversion Parts
- 1998 v6 calibra conversion to cavalier 1994 eco tec.
- VXR lump
- Vauxhall Vectra 2004 Automatic tranmission control module
- Bike carb questions
- starting issue
- c20xe head skimming safe limit
- intermittant jerking on astra 1.6 8v petrol
- stuttering problem
- Change cv joint on cavalier v6
- powerbox, inlet manifold problem
- turbo rebuild
- C20let boost problem
- been offered a vectra b 2.2 sri. losing water
- c20xe, c20let
- ford courier endura tdi 1.8
- x17dtl ecu location
- comparison of zlet headgasket vs 1.9 cometic (c20let)
- closed
- Strange fuel pressure problems ?
- Which throttle and clutch cable
- astra mk 3 x16xel
- Rev counter has a mind of its self.
- c20let injector problem
- £86 + VAT for a water hose - will a different one fit?
- gear box help asap
- Smoke from back of C25XE?
- what manifold to fit c18xe
- 20xe Crank And Late C20let Crank Question
- corsa c20let missfiring/jolting when driving hard (7kish) ??? fuel,plugs,leads???
- Fuel relay
- I've i made a pigs ear of this :(
- Just bought an astra ls 1.7dti estate as my daily driver
- C20LET piper turbo cams, Vernier or standard pulleys?
- astra 1.6 sxi stalling at junctions ?
- Calibra 2.0 8v questions
- c20let turbocharger
- Just brought a Corsa c20let in need of TLC!
- Nova 2.0 8v (seh) Running problems. Suspected fuel
- What can I do to my corsa c 1.7dti engine for more power?
- early cams and late pullys
- f15 to c18xe
- corsa GSi ECUs ?
- Corsa B C20let overheating into the red and i have the fan wired constantly on?? WHY?
- Drill Marks In Back Of C20let Head?
- mk4 astravan 1.7dti
- C20xe engine number query !
- R1 carb user settings
- How to remove an inlet manifold on XE/LET Corsa in situ (the man method)
- C20LET engine mounts Which ones?
- C20xe dispak does anyone know what this sensor is
- power stearing pump help C20LET
- Z10XE engine help
- xe on twin 40s
- Think my water pump has just gone (c20xe)
- C20LET uprated clutch
- a bit random, but lawn mower on methanol.
- corsa b c20xe shaft help
- 1.3 CDTI Injector seal
- gearbox help
- high idle and losing power on c20let
- HELP converting 1.2L 8V to 1.7TD ISUZU Corsa B
- c20xe wiring diagram needed!!
- closed
- EGR valve pics! Think ive found the cause of the power loss! See pics>
- re-map
- astra mk4 c20xe?
- help on what i should do with my gearbox
- Engine running lumpy...
- Best gear box for c20xe?
- z18xe play in crank?
- Dbilas on c20xe corsa
- F28 2wd conversion oil seal
- closed
- best gearbox for xe corsa
- Z16se help
- VXR oil squirters
- mk4 astra 2.0 eco, cam pulley differences?
- Why is my exhaust yellow?
- Corsa redtop conversion
- making a z22let couple of Q's
- vectra 150 cdti crap power and boost dump till 3000rpm
- Internal engine cleaning, mist style!
- c20xe fueling problem.
