: Engines and Transmission
  1. c20let
  2. My fmic design--good enough??
  3. silly oil pressure sensor question???
  4. A/B Plug on late C20XE
  5. Nova radiators
  6. 4x4 thud noise, fuse19 help
  7. "Pinking" and "DET"
  8. XE and LET Similarities
  9. what car did my engine come from ?
  10. samco afm to turbo price
  11. whats better, 2.0 turbo or 2.5 V6?
  12. Audi RS2 KKK26 turbo
  13. SBD Oil pressure relief valve.
  14. Sbd manifold type A fitted yesterday.
  15. water cooled turbo
  16. Replacing sump plug with oil temp sensor?
  17. quaife box question?
  18. 20XE sump thread size
  19. Heavy duty engine mounts
  20. Looking 4 garages/companies 2 transplant valver into Nova?
  21. LET compression??
  22. Vectra sump gasket
  23. Silly driveshaft question...
  24. F28 gearbox questions
  25. wats the diff between a cosecast and a normal head
  26. fuel pump relay clicking constantly
  27. Misfire/cam timing thoughts.
  28. Nitrous installation.
  29. OPEL Part reference for C20LET hose
  30. what electrical prob could damage chips
  31. gearbox probs heeeelp
  32. Possible clutch problems ???
  33. Engine Loom wiring
  34. Whyns fuel cleaner.... amazing!!!
  35. Fuel pump has a mind of its own
  36. engine transplant
  37. 6 speed gearbox up grade?
  38. Help me : C20Let into astra
  39. fuel which way seh..
  40. Cam Timing and Crankshaft Timing ?
  41. Boost on phase 1
  42. exhaust manifold gasket on a omega 2.5 v6
  43. why has my cav turbo lost drive???
  44. Cupra R Dump valve question
  45. Learning Ecu / Chips Help C20let
  46. Low comp pistons
  47. No spark on any pluga?
  48. misfire on full throttle
  49. eletric sunroof
  50. oil pressure & nylon valve
  51. Cavalier Turbo Diesel
  52. Example Fuel Maps Wanted
  53. 2.5 v6 into a 1.8 manta - How to
  54. 16v twin carbs
  55. Gearbox modification for C20let into astra gsi
  56. Calibra Turbo Radiator Dimensions
  57. buzzing sound when ign on
  58. Calibra Turbo Fuel Lines
  59. Oil breater pipe
  60. Exhaust Tones.
  61. Exhaust
  62. Head-block location spigots.
  63. Water Injection with the Winter coming
  64. head gasket thickness?
  65. wot gearbox?
  66. New Car - 4X4 Help, Cally T
  67. Kkk K26 On C20let
  68. C20Xe rear crank seal
  69. Injectors
  70. Gearstick noise ??????
  71. When to change up gear
  72. New Kent engine crane arrived today
  73. Exhaust Hanger
  74. Ecotec Manifolds?
  75. 2.0 Ecotec (x20xev)
  76. timing belt compatibility
  77. Let / Ex questions
  78. Corsa Gsi Induction Kit...
  79. 20XE running probs-Fuel Pump?
  80. set of head bolts and a torque wrench needed
  81. Can I spray a radiator to make it more attractive
  82. SBD Group N ECU
  83. Inlet manifold throttle bodies-brake servo connection
  84. Frontera charge coolers
  85. Engine strip down *not 56k friendly*
  86. Dump valve sounds low!!!!!!!!!!!!!
  87. LET boost drops away rapidly?
  88. Adjustable fuel pressure regulator
  89. Screen wash in water injection???
  90. xe head on my LET
  91. camber kits
  92. camber kit
  93. Fuel probs - please please help
  94. Alternator is the same on the C20Xe and C20LET ?
  95. Astra mk3 with C20 LET. 'Need Traction'
  96. 2.0 8v Btm End on a 1.6 8v
  97. Funny reading on air/fuel gauge
  98. Spark plugs
  99. 1.4 spi to mpi
  100. Omega V6 Exhaust Manifolds
  101. Quick head stud question
  102. Turbo
  103. LET problem(think its pinking)
  104. Toque Head bolt settings
  105. engine type.... help
  106. LET boost rattle???
  107. 4x4 prop seal
  108. Quick Query Engine Management/Fuelling/Ignition Timing
  109. Main cap bolt question on 20XE.
  110. Conveting late Calibra 8v to C20XE...
  111. storing valve train
  112. The next step... c20let tuning..
  113. C20XE cam timing
  114. Fuel pump live
  115. FAO all you turbo bods
  116. grease on water pump ?
  117. HELP on Weber 32-34mm Carb
  118. 20XE head on a 18SE
  119. Manifold Heat Sheild
  120. td radiator
  121. Mystery coilpack 4th pin.
  122. Dispack on 2.0xe Moronic 2.8
  123. mix and match engine 4 me nova
  124. cambelt Question on ecotec
  125. LET nova christmas lights rev counter!
  126. Sticky gearshift.
  127. will a 2.0 sport 16v astra boost valve fit 2.0cav sri
  128. URGENT: Need gen on C20XE mount into nova
  129. 3.0i engine in an astra gte??
  130. Piston Oil Spray Bars / Jets on XE/LET
  131. C20xe/C20let Fuel pumps
  132. 2.0 16V ecotec Camshalft Sensor Fault
  133. Urgent question - Turbo blows white smoke when reved
  134. Astra 3 indicator switch
  135. Dbilas dynamic
  136. rose jointed gear linkage
  137. vauxhall fuel pumps
  138. F20 0r F28 on tuned LET in astra?
  139. Carbs on a 1.4SR Nova...
  140. 1.6 wiring problem
  141. XE rods same as LET?
  142. Naturally Aspirated engine comp ratio question
  143. where is my ICV located?
  144. Oil splattering on drivers side wish bone!
  145. dump valve noise simulator
  146. astra mk2 cabriolet powerhood conversion??
  147. GSi 2.0XE 16v turbo conversion?
  148. XE head change pt2
  149. Nova Engine Conversion
  150. Limited slip diff - help!
  151. Headlight washer bottle?!
  152. Magnex Exhaust - Cav GSI
  153. 1.6 16V head
  154. Do my twin carbs need a fuel return ?
  155. mk2 astra sumpguards
  156. why does my astra burn SOOO much oil
  157. astra mileage indicator?
  158. Fuel pumps and pressure.
  159. Motorbike exhaust on a car
  160. Shiny Polished Chrome Exhaust Manifold. Now What!
  161. Dual Janspeed straight through Exhaust system sound
  162. amal-valve gone wild ?!
  163. V6 Throttle ball joint removal & snapped breather pipe - help please
  164. Indicator Fault.
  165. Oil pressure quandry
  166. Cheapest Engine hoist atm is......
  167. C20xe starting problem!!
  168. c20xe weird problem
  169. V tuning upgrades for c20xe.......
  170. XE probs again :(
  171. Uprated clutch for F20, what one and who from???
  172. Reboring the X16XE? and what pistons?
  173. Early/Late C20XE's whats the difference?
  174. 20xe problems
  175. Head quick!!!!!
  176. Input shaft oil seal
  177. Clutch Pedal............Q)!?! ASAP Plz...
  178. Nylon oil pressure relief valve's
  179. let into corsa
  180. Fuel Pump Relay
  181. Timing Belt Problems.
  182. Astra Fuel Tanks
  183. V6 cam-cover gaskets - help please!
  184. Nova standard bias valves
  185. Throttle Cable trouble? Where does it go?
  186. Should i have got my head skimmed?
  187. SMY or Mobilube F28 oil, where from?
  188. Frying clutch(es)
  189. kent cams fitments
  190. Cleaning the block?
  191. induction mods
  192. What parts of an F20 linkage wear...
  193. Saloon exhaust to hatch
  194. XE Rebuild?
  195. Fuel guage/ temp gauge not working properly
  196. F25 gear linkage
  197. Radiator upgrade?
  198. How heavy? 20XE engine and box
  199. Pic required of engine no on XE...
  200. F23 gearbox
  201. 20XE STILL losing water
  202. v6 vectra misfire
  203. chargecool washer bottle to feed cold water to aquamist
  204. headlamp washers
  205. EGR Valve Location?
  206. Fuel pressure problem.
  207. 20XE GTE and Cav GSI Group N ECU
  208. new cooling setup on my valver
  209. Transfer box have i got a prob of what
  210. 2.0XE and aluminium blocks
  211. Aus spec cooler thermostats for LET
  212. Do I have the right loom to....
  213. re-ground cams
  214. Does a mappable chip need a lambda sensor
  215. throttle bodies
  216. 4x4 system
  217. Ecotec inlet on SFI plate...
  218. help needed v6 flywheel
  219. Inlet manifold for upright SEH on carbs?
  220. lowering CR 20seh engine
  221. Gearbox broken
  222. calibra turbo factory alarm
  223. 1.6 into a 1.2 nova
  224. HELP FOR C20LET into astra MK3
  225. Engine Flush
  226. Will it be alright to just let it dry out? Engine?
  227. Oil Temp Sender Question...
  228. New Corsa - Bigger engine needed...
  229. Oil temp location sensor.
  230. loss of power
  231. Picture of flywheel, flat type and pot type.
  232. dawes device?
  233. Subject: Driving with a Quaife ATB lsd in fwd car.
  234. help with turbo??
  235. astra GSi rear beam load valve...
  236. Turbo Prob (Low boost)
  237. C20LET leaking oil pipes
  238. Oil Lack ?????
  239. Clicking from injector housing
  240. Gearbox type
  241. charge coolers
  242. turbo/v6 brakes
  243. Vauxhall Gearbox Problems??
  244. Vauxhall Gearbox Problems??
  245. cav gsi / c20xe questions ?
  246. Box Oil (when using an ATB)
  247. 20xe cams
  248. what fluid/oil to put in astra convertible electric roof pump?
  249. f28 gearbox linkage rubber
  250. biggest pistons in E16SE
