- How tight??? flywheel bolts?
- Flashing ecu codes 2000>onwards
- where can I get 8v baffle plate?
- big problems please help
- nitros in xe?
- c20xe revving problem
- 1.7Td alternator
- c20let corsa hose loose
- v6 wont rev properly after manifold mods
- v6 cams
- throttle bodies off let on c20xe
- Essential components to run Phase 3.5?
- 20xe eating oil
- INJECTORS
- what engine mount??
- Wire from airbox to air filter box??
- F28 with hydro clutch mod
- dump valve zafira gsi
- idle control problem
- xe camshaft oil seals??
- Omega 2.5td
- Compression check and water out of the exhaust
- C20NE F16 gearbox
- C20XE TB breather
- conversion mounts
- x16xe exhaust system question
- What should happen ?
- ASTRA G Di diesel boost gauge install
- C20XE Oil Cooler removal - info needed please!
- How can you tell if a dump valve is twin piston?
- can 2.0 red top be dropped into astra mk 4?
- f23 help
- Z18xe1 vectra b 1.8 sri 130 ecu fault?????
- Z20let with vxr turbo (turbo problems)
- What fuel pump for C20LET?
- F28 Fwd back to 4x4 ?
- speedo transponder plug help
- c20let+gt28rs
- Gudgeon Pin does not fit the Piston!!!
- Help with C20LET head gasket needed please
- c25xe temp guage
- c20let oil pump
- C20let Actuator help.
- z20let which pistons?
- c20let rotor arm
- calibra c25xe f28, which clutch/flywheel???
- z20 let advice
- c20xe wont start
- c20xe wont start
- boost pressure
- Denso ls1 coils. Attn Chip/rick
- x17dtl boost gauge help
- 4 g cams c25xe?
- engine mounts question
- R6 Carbs (Jet Sizes?) I've read 1.8mm (1.8 Drill bit) ??? Confused
- Can i run EDS phase 3.5 on this engine spec without any problems?
- Coolant pipe problem
- piston + bore measuring
- f28 electrical to mechanical bell housings??
- Release Bearings From??
- Xe crank, pistons, rods into xev block?
- Gearbox HELP PLEASE
- Corsa C ZLET Problem HELP....!!!!
- x18xe1 conversion problem
- Possibly a stupid turbo question
- EML Help Again lol...
- z22se omega 51
- How can i find out my engine code? 1.4 8v sri
- Vectra Diesel no starty!
- Need help pretty quick if poss!
- How much can you get away with before losing comp after rebore.
- xe or ecotec in a carlton
- astra sri irmsher backbox help
- Omega 3.0 Owners Help
- What is best box to use with astra g zlet
- is a 1.6 16v corsa sport engine into a 1.4 16v sport shell easily done?
- Corsa XE getting too hot quickly and won't cool down
- fast tickover (1500rpm) prob on 1995 Cavalier 2.0 ecotec 16v ABS
- help astra gsi turbo vac hose
- Corsa 1.2 8v wont rev past 4000rpm
- Throttle Bodies on corsa z18xe, any advice?
- fuel pressure on x16xe project ..
- corsa c combo
- Honing my xe block - Do I need bigger pistons and rings?
- Build your own ARPs ?!
- f28 GEARBOX REBUILD REPAIR KIT
- C20 Head waterways corrosion
- Corsa C20let Plumbing in
- Vectra gsi B crown wheel in diff gone?
- rebored xe
- what injectors?
- Intermittent Diesel Rattle (Isuzu) Advise Needed
- strange engine temprature issue Corsa 1.2 16v
- c20xe corsa no spark
- diagnostics port on my 1999 t reg mk4 astra van?
- petrol to diesel conversion astra g
- V6 mk4 headache!!
- Cambelt change on Corsa
- What Injectors and where ?
- dizzy to coilpack!!??
- header tank
- O/S rubber mount for Corsa B 16v to 20xe
- XE/LET cambelt query
- 86.5mm bore XE/LET - what CC?
- Anyone Done a X20XEV turbo conversion in a mk3 astra???
- what drive shaft is this 22 spline to hub and 28 spline to box
- X12XE Camshaft Sensor - Torx bolt size?
- Nova conversion information
- C20xe spluttering at low revs
- astra mk3 oil light flickering
- z20leh water ports
- z18xe idle control valve.
- plugs??? best ones for my LET ?
- eds 3.5 w/o map sensor
- hub problem
- What mains, shells do i buy?
- Whistling noise when boosting, help!
- Vectra GSi 2.5 slightly rattly and intermittent tapping
- 6 speed gear box in my Z18XE, any advice please?
- Ongoning idling issues: Testing wiring/ECU etc ?
- Corsa C20XE gearbox swap..PLEASE HELP!
- 2L 8 valve SE & 2L 8 valve SEH
- Corsa B won't start
- Facet fuel pump?
- swapping exhaust housings?
- afm to turbo intake pipe
- F28 and quaiffe
- Please help!! This bloody z22se timing chain
- C20XE's encryption key fuel - A or B?
- are all f23 gearboxes the same?
- fvectra 2.2 dti f35 box from rod to cables is it possible
- how much over 200bhp on standard c25xe injectors
- Coolent setup for corsa C20LET help
- Which gearbox??? F16 or F20??
- c20let adjustable fpr
- C20xe Corsa won't start
- whoops got wrong speedo type on my f28, please help
- exhaust
- what do i need to fit f20 box or cav 17td box to c25xe??
- c20xe throttle body strip down
- uprated cam belts
- diff help on calibra
- 2.0L redtop and 2.0L vectra engine
- running a flat type flywheel on a isuzu diesel?
- Redtop corsa help!
- Carburettor people please give me some info (zxr carbs)
- Wanted 1.2 16V Corsa B engine
- dual mass fly wheel to solid help needed
- Oil in water on Vectra 2.2 dti, Is there an oil cooler on these engines
- Corsa c wont start
- c20let corsa gsi with f28
- C20XE Coolant Temp. Sensor
- Will a 1.4 16v fit a 1.2 16v Corsa
- Corsa 1.4 sport/corsa gsi driveshafts the same??
- c20let smoking white
- should my modded vectra cdti be doin better motorway mpg than this??
- c20ne corsa exhaust system
- nova c20xe cold start
- apexi avcr into my astra coupe turbo z20let help
- Engine number on a Vectra B '02 GSI
- C20xe running rich
- Torque Settings for bottom end....
- 20SEH 2.0 8v spluttering low revs.
- astra 2.0 td sri fuel pump
- gearbox problems
- Easytronic, any pointers wanted -IE clutch actuator removal, tech2, bleeding info etc
- wastegate pipe
- saab 2.3 turbo engine mounts
- Z20LEH steel head gasket for C20LET ?
- under bonnet fuel tank vent valve c25xe
- Please can somebody give me some advice about the condition of these plugs?
- 218 & 221 gear clusters for f10/f13 gearbox
- Z16se
- Help Needed On My Astra Mk3 Project.
- What Actuator ?
- xe pot type flywheel , what clutch ?
- lambda sensor ?
- c20xe corsa cutting out...
- rwd corsa
- c20xe on fireblade carbs
- cavalier 4x4 rear diff
- HELP! hydraulic clutch problem
- X14XE & X16XE Fly Wheels ??? A.S.A.P
- Converting Vane AFM to MAF MOTRONIC on a VECTRA A C20NE.
- x30xe con rods
- Hi guys -) Hallo from Russia Moscow-)))
- Throttle Body Trumpets
- C18xe ecotec opinion
- Blown turbo??
- C20XE build, no managemeent light,help!
- HELP needed diagnosing C20let problem.
- X20XEV: Management light / fault code suggestions?
- Master cylinder outlet question
- C20let inlet manifold, vac hoses and the likes
- c20xe oil leak usual suspects?
- MK4 ASTRA ISUZU 1.7 turbo diesel, what turbo's will fit??
- Astra Mk2 Distributor
- tx autosport steel rods
- c20xe in to corsa c
- Vectra B Gsi Facelift Gearbox options
- clio clutch
- 1ltr '04 Corsa - do I have a big end bearing issue?
- how to install oil cooler?? please help guys
- engine rebuild needed
- Is this a good idea or pointless? Port+Polish my head with no mods.
- corsa b xe hoses
- C20let Corsa Exhaust questions
- water injection jet, where to put it???
- 120 or 150 bhp
- Vectra B GSI petrol consumption
- c20let low power on rollers
- Running very thick rather than clean and crisp
- slugish when hot
- c20xe motronic 2.8 (m2.8) cams
- Cav sri exhaust size
- Strengthen the Z20LEH block, or swap for C20LET block?
- corsa b c20xe fuel pump
- estimated hp on SEH
- Whats a dodgy wideband reading,
- Car Stuttering
- leaning out on dyno run
- engine timing
- tool for timing adjustment
- universal lambda sensors!
- 20 xe into base model mk 3
- 1.4 to1.6 conversions
- C20xe on R1 carbs, misfire on tickover?? help
- c20let advice i have been given anyone heard of this?
- x20xev in to mk4 astra
- rebore or not
- C20XE lumpy idle, black(ish) spark plugs?
- head, block and crank work. where to find it?
- corsa c20xe more power
- map files for zlet
- turbo advice
- Turbo HELPP !
- c20xe with throttle bodies from M3 3.2 EVO
- mk4 astra gearbox?
- NEED HUBS! Corsa c20xe! Will these Fit?????
- clutch slave cylinder *HELP*
- Turbo
- z20let balancer shaft
- 2.2 vectra 150 sri misfireing
- z20let into astra mk 4 convertible
- new and old engines
- Torsen v Quaife Diff for f28
- C20xe/let head gasket kit copper ring????
- c20let phase 1 set up
