: Engines and Transmission
  1. fao electrical bods xe diagnostics
  2. Corsa Gsi 2.0 16v Conversion Wiring (no Spark)
  3. relocating battry into the boot
  4. let crazzy
  5. Wiring c20xe
  6. coolant header tank
  7. inlet manifolds
  8. Tappets
  9. "grand theft auto" type sound coming from engine
  10. Astra XE Engine Mount
  11. Cav Turbo Clocks into a Corsa B?
  12. QED Throttle postion sensor wires, gen
  13. XE and LET blocks...the same??
  14. URGENT XE nova mount Gen required
  15. Indicator Problem
  16. Code 65 20xe
  17. Loom fault finding
  18. XE into Nova - Day 3
  19. 20XE into BMW
  20. Nova GTE 1.6 Head on a 1.3???
  21. head gasket
  22. 20SEH Plastic Cam Cover Removal
  23. C20XE Bottom End
  24. XE into Nova - Day 2
  25. Wierd engine noise
  26. Astra GSi LET exhaust
  27. aux belts make engine rattle?
  28. x20xev bottom end
  29. a few injector, fuel pump and regulator questions.
  30. C25XE Camcover seals leaking
  31. Rotor Arm Mod (c20let engines)
  32. Throttle boddies and MBE kit????????????
  33. Oil pressure
  34. recirc valve blocking - spacer dimensions needed
  35. anyone had an exhaust system from online (tuning.co.uk) ?
  36. XE into Nova - Day 1
  37. Turbo/ Manifold removal
  38. LET running lean and clifford immob. question
  39. 20XE Hall Sensor
  40. Switched Live To Pump Relay??
  41. MF2 Injector driver
  42. Low boost on standard LET
  43. Cleaning oil/water galleries
  44. Oil
  45. Coscast xe head
  46. How to remove Cam Pulleys on XE
  47. Dead turbo...Results
  48. Leaking Diesel Injectors?
  49. Could I use a Nova GTE performance exhaust system for XE nova?
  50. Need some advice guys......on ecu chips
  51. Astra carbon canister
  52. C20LET boost in 5th
  53. astra gsi gearbox
  54. what are the benifits of water injection?
  55. C20XE Conversion Accelerator cable
  56. timing belt life/renewal
  57. clutch on 1.8 cav
  58. 1.6 ECU doesn't work...
  59. steel rods from argentina....
  60. help with 20 XEX
  61. XE Fuel Lines Q
  62. spark Plugs
  63. Regal Head studs XE
  64. X20XEV swapping for Red top XE HELP!!!!!
  65. Changing worn Corsa GSi cam
  66. xe idle probs...
  67. Lift Pump?
  68. Does C20let Clutch Fit Xe
  69. Fuel Pressure Regulator pipe on GTE 16v
  70. Best stuff for getting old gasket off?
  71. Turbo timer fitting, help needed
  72. Chip you still changing the xe to let?
  73. i lost a gear
  74. Any one had trouble with gear linkage?
  75. Corsa/ Astra Mk3 turbo weight
  76. Calibra 16v engine. HELP
  77. universal jap backboxes...
  78. Can you rebuild a dumpvalve?
  79. Ecotek Valve
  80. F20 Gearbox Leak
  81. CavGSI20004x4 SUMP GASKET?
  82. what oil now?
  83. F28 Speedo Drive JESUS my box has fallen in half ;)
  84. F16 oil breather.
  85. Ecotec EGR Removal
  86. Few things i need ironing out. LET nova, running temps and rad choice
  87. What year did the C25XE cease to be in the Calibra?
  88. 8v turbo
  89. Tappy Turbo
  90. Cav Gsi Xe Wiring Into Mk2 Astra 8v
  91. Head problems
  92. 5th injector???worth buying and having?
  93. Corsa 1.4 DOHC cambelt broken - damage?
  94. Oil coolent pipes
  95. Engine mounts
  96. XE Help
  97. Cav 4x4
  98. Interesting Z20LET Info from apple.
  99. xe conversion wiring help pls....
  100. xe pulley problems
  101. trasfer boxes
  102. GSI Turbo wiring fault???
  103. C25XE heads on X30XE block ???
  104. astra big block engine, suspension
  105. Oil Pressure Gauge
  106. F20 - Input shaft bearing
  107. oil in coolant
  108. c20let question
  109. removing a F16 box from 2ltr 8v in a nova..
  110. C25XE camcover gasket price ?
  111. Engine location number
  112. crank stops turning on 1 full circle?
  113. humming from ecu when turning my let off
  114. vectra v6 loom turmoil
  115. Power steering fluid pi**es out of my new cav turbo
  116. 1990 Cav GSi F20 'box
  117. Rattleing xe
  118. using an early xe type flywheel with a 6speed box
  119. Input shaft baering - F20
  120. Will no exhaust damage an engine?
  121. Cally 8V to 20xe??
  122. F28 Speedo Drive mechanical/electrical
  123. Unichip Remap
  124. Rotating wheels on a cav/cally turbo.
  125. Cav Turbo rev counter to 7000rpm?
  126. turbo rebuild opinions
  127. LET problems still
  128. buzzing fuel pump
  129. xe into astra mk3 no oil light
  130. xe and let dizzy's
  131. Autronic or EDS???
  132. New Tappets? where to get them cheap?
  133. LET V ECOTEC Block
  134. Z20Let Head gasket
  135. tb's wireing loom ?????
  136. Eds Phase 3 + Kit
  137. Fitting new valve stem oil seals?
  138. LET Cooling Questions and Digidash temperatures
  139. Building an engine for nos
  140. Footwell wires Astra GSi/LET
  141. radiators: "LET" V.S. "XE"
  142. Need a Smaller AFM
  143. best fuel pump for 350bhp?
  144. How do you change the oil on an F28 box?
  145. backbox query
  146. C16XE re-build help
  147. air/fuel mixture
  148. Phase II max hold boost with Apexi AVC-R
  149. which way do EDS chips go in
  150. 2.0 ltr blocks
  151. Rally Car head
  152. Cav 2lt GLS (95/N) Radiator Fan always on
  153. Metal XE oil pump gasket and sealant
  154. problem with AC pump
  155. FAO XE Experts in manchester area!
  156. The bit between the fuel filter & Fuel pump...?
  157. Is N/a 16v Block Same As C20let Block
  158. piper exhaust gen
  159. Will an 8v tin sump fit a 20XE
  160. LET question
  161. Astra GSi LET wires, help
  162. Corsa C20xe running problems
  163. torque settings
  164. clutch or syncro?
  165. wot 2 do wiv the 1.8spi lump
  166. How hard is it to change the sump on a cdx cav.
  167. C20XE turbo conversion?
  168. ran out of petrol and now its goosed
  169. turbo 308mm?
  170. f28 parts?
  171. whats exhaust wrap for?
  172. Regal FMIC fault
  173. XE running rich- any gen
  174. GTE16v water pump removal
  175. cav or cally turbo
  176. Few LET questions
  177. DE-Cat Pipe
  178. Catch tank breather oil fumes at idle revs
  179. fitting a evo310 wallace performance chip
  180. omega pistons
  181. 1.5TD flywheel onto a 1.7 TD
  182. Calibra CAT
  183. EVO4 v-max chip
  184. Calibra 16V driveshafts in an Astra?
  185. ebay air filters?
  186. xe cooling pipe pics?
  187. Alternator light - 20xe
  188. Replacing Release Bearing on F20 G/B
  189. astra GSI with cally turbo in it....
  190. speed camera
  191. Corsa coilovers will they go on nova?
  192. Placement of air filter
  193. Throttle Bodied XE with single plenium inlet - Discuss!
  194. Removing valves?
  195. Building a Pretty Bullet Proof XE
  196. final drive removal. ok before changing the crown wheel on the f20 i was wondering if
  197. hmm, thats a thinker(help with rough running engine)
  198. Engine Help
  199. Seat belt too tight
  200. gearbox gen required
  201. Astra AFM's differences?
  202. XE Manifold
  203. turbo cams
  204. Sheared cam pully on Cav Turbo
  205. Blown laptop plugging in audio out jack into headunit
  206. Sportex exhausts
  207. Z20LET Headgasket Gen required
  208. Transfer box
  209. cossie intercooler on a mk2 astra with an let
  210. C20LET not boosting
  211. 30 psi on stock chips - impossible, right?
  212. Oil temperature & oil pressure sender
  213. What gear box for 2ltr 8v in a nova...
  214. Digidash indicator question
  215. Undoing rounded out crank pulley bolts???
  216. XE/LET oil cooler connectors
  217. is this any good for c20let????(NITROUS QUESTION)
  218. cav turbo's, what goes wrong?
  219. Lambda question
  220. V6 Oil Cooler/Sandwich Plate
  221. fuel pressure on let
  222. XE Valve stem oil seals
  223. twin backbox exhaust systems??
  224. Engine Mounts
  225. dump valve
  226. f20 questions
  227. F28 ratios
  228. Long shot? Powerflex bush suitable for Nova exhaust mounting
  229. Injectors
  230. New Limited Slip Differential
  231. LET not firing up
  232. Converting XE to DIS
  233. XE revs hanging/slow to fall
  234. Timing belt tension on XE Early setup
  235. Running In Oil
  236. corsa sport engine in2 nova
  237. Cambelt change on my 1.4 SPI ? Any gen ?
  238. 1.4 Sport cooling system probs...help!
  239. competition engine mounts with a nova let
  240. 4 brach manifolds??
  241. cavalier 2ltr 8v engine..
  242. MK3 astra gsi LET+F28 conversion
  243. LET oil presure?
  244. weird noise engine help
  245. Clutch
  246. engine control light on
  247. Facet Red top
  248. C20LET Fault Code 42?
  249. vauxhall Mk2 astra 1.6
  250. C20xe
