- 20XE gm spark plug gap plz
- tigra 1999 x14xe firing on two cylinders when cold?
- Abit of help with my C20LET Corsa
- F23 in a nova
- Z20LET - Cameshaft X20XER
- Vandervell bearings
- C20LET noisy hydraulic tappets
- astra red top
- x20xev, kms management crank sensor question,
- Fuel problem?
- can you put external wastegates on turbo that has internal wastegate?
- x16xe shafts
- About Pistons: c20xe on z22se
- c20xe water pipe needed
- coolent question
- 2.2 16v oil pressure
- was the F20 ever fitted to the C20let as standard
- 1.6 engine corversion info please
- are outer cv joints the same as inner cv's on the big blocks?
- c20let stallin at junctions and missin
- c20let+gt28rs
- Need a conversion guide for 1.2 8v corsa b to 1.6 8v.
- twin plate super clutch?
- C16XE Ignition, no spark!
- Non vaux, help with my Subaru Justy 4x4 (winter bad boy)
- rebuild kkk16
- some turbo advice needed c20let
- standard internal's??
- Clutch slave astra Mk4
- Getting a buzzy rattle...
- C20xe running issues
- c20xe not timing up
- uprated z20let internals
- Another XE Idling question... :)
- C20let help??
- X16XE SAI Breather
- fitting a f28 help
- Grrr Help! Idle control valve, high engine idle
- seen car for sale but crunches in 2nd gear, wot you think?
- Air fuel ratio questions
- adjusting vernier pulleys on a c20xe
- C20LET fueling problems
- C20xe running r1 carbs how do i get a good cold air feed
- Cylinder bore glaze breaking question
- will engine not start if airbag module goes down?
- Z10XEP head on a pre facelift Z10XE corsa c
- Getrag F28 rebuild question
- corsa c not starting
- crank bolts
- crank bearings c20xe
- Old 1.7td Isuzu engine into a Vectra C?
- F20 speedo ring?
- idle control valve
- Boosting problems?
- c20let f20 clutch?
- Oil consumption f18 gearbox,2.0 ecotec astra gsi 1997
- Quick question about throttle bodies on c20xe
- Astra gsi mk3 ecotec exhaust de cat,will put limp mode on???
- c20xe wont Fire!
- F20 hydraulic clutch conversion
- Z16XEP Astra throttle body
- please help corsa redtop problems!
- corsa weird revving
- Exhaust recommendations for astra gsi 2.0 ecotec(xev)
- Early and later type 2.0xe red top-Differences?
- 1.3 cdti wont start. need help before i burn it!
- rear axle
- Quick question about the Z20LET Oil Pump on the C20LET
- astra G to saab turbo info wanted
- 308mm brackets for corsa b????
- x16/z16 engine parts swap
- Wont go into gears! F16cr
- calibra turbo 4x4 spigot ring size
- Suggestions on power and gearbox upgrades?
- c20let fan not working
- vectra c 1.8 - saab turbo engine
- standard c20let injectors how much power
- fuel pressure gauge
- c20xe ron plug
- Workshop info required on f23 gearbox
- missfireing AGAIN z18xe
- upgraded shafts?
- All steel Zaf GSI what power ???
- Corsa C c20xe redtop conversion
- c20ne help... all advice welcome...
- motorbike engine in a car? surely its possible?
- diff ratios and teeth info?
- Best power steering fluid for mk3 astra gsi
- Best gearbox oil for my astra mk3 gsi (ecotec 2.0 XEV)F18 GEARBOX
- Best engine oil for 2.0xev(ecotec)
- stand alone managment on c20let
- Z16se Advice needed
- Zafira Z22se engine downgrade.
- C16XE chip. please help me!
- Code P0202 on X20XEV (Astra G)
- f18 or f18?
- z20let head x20xev bottom end
- 2.0 redtop corsa C
- Astra mk4
- corsa c x20xev
- torc settings on a c20let
- c20let timing
- Zlet oil pump on a clet
- Level of Engine Rebuild Required for 350BHP LET - Advice Needed plz
- C20Let/XE Early/Late Cambelt Set-Up Questions
- engine and gearbox advice
- c20xe into corsa b help please
- Difference between 32-34 DTML for manual & auto g'box?
- Large throttle body
- help zafira overheated and oil/water mixing
- c20let water probs and hissing sound
- help speedo not working?
- f35 on c20xe(let)
- how close is your xe to your inner wing?
- corsa c20xe inlet question
- Problem
- wats this part called?!
- C20xe corsa problem won't even turn
- phase 3 from regal??
- oil pick up pipe question - xe
- Headgasket gone on x14xe
- Broken Silver Pipe
- Whats your BHP?
- 1.6 8valve into corsa
- difference between pierburg 2e and 2e3 carb?
- insignia cdti intercooler on c20let ?
- c20let or v6?
- f18 wont fit c20xe block, yes strange or what !!!!
- c20seh running in issues
- c20xe corsa shafts and cvs
- C16 XE power and tuning?
- c20 let Engine torque settings
- astra van v6
- C20LET Fault Code 31
- gearbox oil?? C20xe f16!
- C20LET Corsa turbo problems?
- Turbo Supports / Bracing
- Corsa XE ongoing fault
- engine removal - length of webbing sling / chain?
- C20LET head bolt size
- carlton gearbox?
- can a c20let run without an airflow meter?
- corsa 16v engine mount picture
- F20 gearbix
- wiring problem please help
- c20xe conversion - any gurus out there? I'll give you moneys
- c20let throttle bodie on a xe
- this any good for the price? can't be....mad price for a clutch
- had my car on the rolling road today and..
- Where is the Idle Control Valve located on X25XE?
- F28 converting bact to 4x4
- X25XE started idling at 5000revs, possible causes?
- Idea's for smoke C16XE?
- Urgent help required!
- c20xe astra mk4 distributor setup help please
- Re-routing catch tank breather pipe back into engine
- Vectra TPS with Omega inlet
- what oil for vauxhall combo cdti
- c20xe bottem end
- x14xe cylinder head bolt tightening tourqe?
- c20xe flywheel weight
- What type is opel car's crank and cam sensor?
- Nova 1.5 TD engine in Combo van - cut out, now won't start. No fuel at filter?
- Corsa B Mis-firing
- best ways of improving power c20xe
- x18xel engine removal
- Opel Astra Di 16v Modified!! ESTATE
- corsa equal length shafts
- Vectra estate 1.8 gear box Whine.
- c20xe fuel rail thread size
- z20let coolant issue
- vectra c z18xe coilpack
- 20xe missfire
- Cavalier mk3 2.5 V6 engine options?
- oversized forged valves on intake and stock valves on exhaust on LET
- C20LET Boosting Issue 1st/2nd & Sometimes 3rd Gear
- c20let icv the same as a c20xe icv
- c20let idle problems and cuttin out
- calibra coolant issues ???
- wastegate question
- Are these the Evo5 chips everyone goes on about?
- F23 gearbox
- Vectra 2.5 V6 error code P0130 - O2 Sensor 1 Circuit Voltage Low
- Vibratechnic engine mount????
- corsa b rear engine mount
- corsa engine
- gear box issues in a redtop
- Calibra V6 warm idle issue!!!
- C20let bearing sizes...
- gearbox bearings?
- Nova internal fuel pump
- Mk4 astra running problem
- z20let converstion in astra G
- best c20let rods
- A lot of Oil pump C20XE questions!
- F17 on Z18XE whining noise
- Inlet leak
- corsa c engine swap
- Forge dump valve spring .
- z22se bigger air intake?
- Clutch question
- C20ne backfiring, Won't rev up
- ditching the oil cooler
- Flap Valve in air cleaner (cav 1994 1.8 auto)
- astra mk4 c20xe no power and on full throttle judders
- engine mounts not fitting
- how do i adjust the gear linkage on an f35 gearbox
- X20xev manifold help!!
- is there a how to on reconditioning a c20let oil pump??
- c20let need advice
- C20XE flywheel & Clutch, on a C25 .. With RWD box?
- xe runing rich!
- best way to clean engine block?
- Can you straight swap an Ecotec cylinder head for an XE head??
- X20XEV to 17DT conversion pitfalls?
- What engine mount is this from?
- x18xe crank into 20seh block
- clutches,will they fit
- dump valve on 1.5td corsa
- AFM in boost pipe ??
- which way should the piston arrow face?
- c14se on mbe
- C16XE intake mnifold
- Tuning Motronic 2.8 - WOT problem
- fitting an LSD
- Is this company Genuine?
- C20LET Standard ECU powerd
- c20xe EARTHS!! WHERE???
- isuzu 1.7td cam timing out?
- Z20LET tuning
- Tps Power setting ??
- what do bosch fr8 hdc +36 spark plugs fit ???
- juddering - stalling - cuts out - runs lumpy astra mk3 1.6 16v ecotech x16xel
- Gt28rs smoking on c20let
- C20xe not behaving :(
- Corsa B V6 Brakes Conversions, spiget rings for disc's?
- c20let running too rich HELP!!!
- Omega V6 wont start. Help!
- 1990 1.2 8V, nova, would like some help?
- paperclip test = error code **---******** (28)
- Garrett T3 + Management
- C20LET idle issues
- blanking of the egr valve will i need to get the ecu re-flashed
- radiator help
- vectra B gearbox
- What Actuator....
- who is using ballast resistors with dta s60?
- Engine and gearbox oil
- Arp rod bolts Q
