- dispack 20XE into nova...
- Spark lead question
- Ignition Starter Card
- Tools for Head dissasemble/reassemble
- stiff gear changes
- ajustable fuel regulator question
- BMC Induction Kit - Any good for C20LET?
- Engine mounts for XE conversion
- Do Blue injectors flow enough for a C20LET?
- HELP! Whine in gear & now no gears - do I need a new gearbox?
- Splitting LET ECU
- a few XE rebuild questions.
- Backbox noise,lack of,LOL
- Anyone know what hp a h reg nova 1.4 engine is?
- Converting from leaded petrol - super unleaded
- Head Interference, recent or past history?
- Engine speed signal
- F28 quick shift
- quick question - cam end seals
- Oil Pressure Switch on A MK1 Nova 1985
- Alloy sump for 1.6 8v
- astra mk3 LET, hose burst??
- 1.6 16v xel multec-s engine problem.
- few exhaust questions.
- Wiring GTE 16v XE into a MK3 1.6
- fuel pressure regulator
- Regal Manifolds query!
- Just bought a Wilwood Bias Valve!
- c16xe into nova 1.2i...
- Vectra B Crankshaft sensor removal
- Clutch/Gearbox Problems...Help!
- Transfer box replacement/modification
- X16XE Engine Question
- X16XE inlet ports, TB's, manifolds and bits
- fitting turbo clocks in a GSi?
- cav turbo gearbox
- help clutch or gear box!!!!!!!!!!!!!!!!!!!!!!!!!1
- red top disguised??
- f28 gearbox
- C20LET headbolt torque settings
- Head stud conversion?
- HELP my XE Nova won`t start!
- isuzu diesel torque?
- diagnostic plug in nova xe
- con rods
- Making large holes in the engine bay....
- mbe engine management cost?????
- MPI?/Air filters
- Calibra Turbo, Master cylinder - Hose nut sizes ?
- 8v Transfer box...
- Xe Throttle Cable?
- mk3 astra gsi LET conversion
- boild brake fluid
- C20LET Sump Gasket Question
- What type driveshafts have the cavalier, calibra, kaddet with c20xe engines?
- Head Gasket
- Oil Pressure Light Flickers On !
- Engine swap
- XE Exhaust cam on LET Mod
- calibra manifold
- XE running temps
- fuel grade
- engine oil
- Astra 1.3 8v / 2.0 8v engine conversion.
- 40XE to Ford type 9
- Anybody with a F28 box in a mk2 astra help me?
- let running temp
- Engine mountings, suspected problem...
- m.o.t help regarding catalyst?
- backbox fooked
- Astra 1.8/2.0
- Increasing My V6 Cav BHP?
- gearbox
- Valver problems please help!!!!!!
- exhausts, peco boxer?
- Head bolt thread gone. HELP!!!
- Engine response a bit sluggish (X20XEV)
- NOVA GTE/GSi injection Q
- SBD 208 Kit
- anyone got an omex map for a 1.6 16v on tbs?
- whats the best spark plugs 4 a
- what would you add to this list?
- Engine swap in corsa b
- Removing late XE alternator?
- Engine stuck when dropping
- F28 in a Turbo Nova
- Z20let Fpr
- Running the c20xe engine with disconected air flow meter.
- crank bolts
- Igntion map for a 2.0XE
- Could a Corsa B / C Gear linkage work on a nova?
- whats the best oil!!!!!!!!!!!!
- electrical problem spark but no fuel
- mrk 2 nova 1.2i k reg proformance
- where can u get aftermarket pistons?
- why do people use Mk2 Astra Diesel parts
- How to get close ratios for an Astra 2.0l 16V with 210BHP
- mrk 2 nova ecu and oil help
- Carlton Clutch Advise....
- Cam belt change on a c25xe
- turbo droping boost,accutuator?
- big XE probs... Help!!
- corsa b c20xe abs
- calibra turbo hub sizes?
- Rear Diff and Transfer box oil Change?
- Engine dropping out of vauxhall Nova - Helpy please
- PROBLEM HELP - On my EVO5 LET
- oil control ring?
- x20xev same as
- booste valves
- x20xev codes
- xe idle probs
- article in the sun yesterday 'new vx 1.9 twin turbo diesel'
- Are all fuel flow dampener things the same?
- manual boost control valve
- What exhaust have i got
- jet ski help? poss carb related?
- Engine mount thing snapped, help needed ASAP!!!!
- Quick aux belts question...
- advise on samco hoses on let'd nova please
- Turbo temp calculator
- How do I change the fuel filter on a 1994 Calibra Turbo?
- re-use a LET sump gasket?
- Ahhhhhh Help I Cannot Stand It(let)
- V6 aux. drivebelt
- Super sensitive throttle
- Engine swap C18 to C20NE
- Yet another gearbox question
- 1.6i CFi 8v Tuning help
- Multi point injection
- c20xe issues
- LET/XE bottom pulley bolts thread
- c20LET + F20 clutch change
- Cav V6 alternator belt idler
- cally turbo speedo problem
- Wot temperature shud a radiator fan kick in?
- What water radiator?
- Need info on Garrett T25 Turbo
- c20xe ticking noise while running
- xe question
- CAT's
- Mk3 GSi turbo conversion. How simple?
- what air box for my c20xe corsa?
- EGR valve removal on mk4 astra td
- Oil cap gurgle
- urgent!wiring of starter motor question!!!!!
- another 4x4 question...sorry!
- anyone know what this is????
- Blitz or HKS blow off valves
- Engine improvement
- omega exhausts
- Cav 4x4 Fault Codes
- Calibra Turbo brakes
- What panel filter do people have on there XE?
- Techie questions for small block
- What Turbos are on 1.7TD
- C20LET don't start...
- engine performance
- Missing a beat
- Induction kits
- Do i LET it happen?
- Which spark plug for nitrous?
- Carb Convertion
- Got to remove an LET
- whats the best oil cally turbo
- very high oil pressure!! /o:
- Do these camber bolts look correct? Pictures.
- smell of petrol
- gear boxes
- xe gearboxes
- Dump valve, anything 2 do after a year of unuse?
- rattle near turbo?
- Weber 32/34 for a 1.3..
- FK coilovers
- Fuel computer
- XE Induction idea
- twin cable linkage
- throttle body trouble
- I want to replace my Fuel Pump.. but how?
- Astra Mk ll 4x4 rally
- How long does oil stay 'clean'
- Which Exhaust?
- Astra 1.4 SPi stalling
- Different sized crank journals on XE
- POLL: What oil do you use in your cally Ecotec
- How to compression test a LET? Did i do wrong or is my engine fubar?
- Nova Rubber Engine mounts...
- throttle boddies problem
- Manta sump on XE, for a kit car....
- C20XE cam follower replacement
- Water injection activation point
- astra 1.4 not starting
- Fuel pump wiring
- XE Nova Driveshafts
- Red Top Twin Carb Problems
- Nova XE conversion questions.
- What Parts For C20let Conversion?
- bonnet lifters for cally
- help! Xenon light out :(
- Nova XE engine bay strengthening kit
- Which plugs best for C25XE
- t3 turbo flange drawing
- F10 Gear Box
- f28 weigh
- Twin Forty Five's On A Redtop.
- Astra 1.4i idle revs
- Astra 1.4i
- lambda sensor mod- general questions
- xe pinking?
- Mk3 astra gsi starting to sound like diesel, HELP!!!
- whats the best clutch for f20 onto a let?
- Cylinder head removal on 1600 Tigra with aircon
- 20Let, which engine bits can break off still run ok?
- Cab Mk3 Saloon and Hatch headlining?
- turbo corsa
- MR2 Engine boffins?
- 2 litre sumps
- ovewrboost and chips
- urgent torque setting for LET
- C16XE issues
- calibra turbo f28 problem
- XE Performance problems
- 1.7 TD exhaust manifolds? is the isuzu manifold the same?
- timing belt/thermostats
- engine mount gone??????
- Cruise Control in a MK4 Astra SRi 2.0L Ecotec
- XE piston Gen?
- bosch uprated fuel pumps
- X20XEV into Nova?
- charge cooler/front mounted intercooler?
- Twin Headlights
- xe head help needed
- Oil Spray Jets and Block GEN needed
- Dump Valve
- 2.0 turbo conversion D.I.Y
- XE clutch
- astra mk3 C16SE probs and questions
- Fuel pump making odd sounds
- how much power will standard rods take?
- dti cat removal
- c20let in mk3 gsi
- Kent Cam timing
- Kent Cam timing
- veccy gsi wheels on cav turbo
- 20bhp...
- High Performance Induction Kits
- nova gte fuel pipes
- carburetor synchronizer gadget (photos)
