- Automatic XE
- HELP PLEASE! Corsa B 1.2 C12NZ 1996, 12V at distributor should be 5V, New everything!
- Clutch problem please help
- Suspension.
- piston rings
- Will 1.7dti combo engine fit in 1.3cdti
- Driveshafts
- corsa Z12XEP eng bad misfiring from start up
- horse power ?
- C20LET with XE inlet and exhaust cams
- air bag light on dash
- sandwich plate adapter on calibra c20let?
- stupid and rapid question about water temp sensors
- Do i need tank vent valve and amal on my c20let??
- What gear box ?
- Saab engine into astra coupe ??
- Engine removal Z18xe astra G
- fuel system help
- C20XE ECU Fault Code 44 Oxygen sensor Air/fuel mixture too lean (weak)
- Gearbox sensor
- Anyone fitted a vectra 2.5 gsi engine into a mk3 astra?
- What gearbox does a vectra gsi have?
- 1.6 16 v question
- Crank trigger??
- X20XEV 16v with an F28?
- Wiring switch for fuel pump
- corsa b and c gear linkages the same??
- is there a diffrence in the cavalier x20xev and the vectra x20xev
- what psi should my oil pressure be on c20xe
- flooding webers
- c20 let running problem
- c20let smoking issue
- Will c20let with t3/t4 fit into engine bay from underneath with everthing attached??
- odd compresion test results
- vauxhall say headgasket has blown- i disagree what do you think?
- Corsa sport 1.6 driveshafts .
- v6 conversion for tigra
- what cool running thermostat for c20let?
- astra sport running on 3
- quick question - will this shaft fit my corsa/F20 box?
- F28 onto X20XEV
- z18xe eml - lambda, knock sensor, low temps
- 1997 opel astra 2l i low oil pressure.
- Corsa sport overheating
- major c20xe idling problems running out of ideas
- Cav 2.0 16v overheating help please
- Fuel lines
- 1.8 smallblock, info?
- nova propshaft needs shortening
- Oil Pressure Switch
- Engine Misfire
- benefits of running xe injectors in 2ltr8v
- Help Plz Vectra B Oil Filter Housing
- help plz c20let not running right
- headgasket on x12xe
- Can you machine down xe pistons to low comp them???
- 20xe rod bolts re-usable or not?
- car missfires and cuts out after idling for 10-20min
- XE/LET Headsets
- 2.3 saab turbo into nova?
- EDS Phase 4 Chips
- C25XE lamda sensors, same as X25XE?
- red top v6 crank sensor
- !!!PLEASE HELP!!! Astra mk3 x14xe starting problem!!!
- Calibra Turbo 4x4 305bhp What Clutch?
- How do i tension early type cambelt on c20xe
- gearbox
- 8v head bolts
- HELP! Corsa Lack of powern and engine management light on
- c20let gaskets
- 3.0 cavalier killing fuel pumps
- Equal shafts on a nova ?
- fitting first cambelt
- How to replace valve stem seals
- c20xe with no catalyzer - is it too noisy?
- vectra c engine swops - ideas
- z12xe Reseting the timing.
- f16 f20 final drive.
- Piston rings how long they good for ?
- injectors,whats the differences in colours etc
- vivaro tecshift
- r1 carbs on c20xe help please
- stroking a c20let?
- What Oil for my Cav Gsi
- vxr turbo fitting kit - whats in it ???
- X16SZR Block Problems Help
- Part Number Needed for Vec C Cdti fuel filter housing
- Temperature gauge
- Adjustable fpr fitting help?
- Nova F28 Mount Rubber?
- z16se engine code help please...
- vacuum hose size
- mtech c20xe ecu chips?
- Speck me a decent turbo for my let and other pats please
- exhaust manifold
- my corsa sport
- c20xe monza project
- X25XE vectra gsi starting/running issues
- both xe cams in let??
- 2l redtop corsa
- COOLANT!
- piston dimensions
- 2.2 belt driven
- corsa c engine swap HELP
- need help cav xev
- turbo to top hat pipework
- 2.0 DTi Reluctant to Start When Cold
- c20xe head or head gasket gone
- Engine Over Run ??
- Z20LEH into Corsa D. Has it been done yet?
- cavalier engine swap
- c20let vacum pipes
- bad vibrating on a cav can anyone help?
- a cav/ astra gsi driveshaft question ?
- Does anyone know anything about LNM003 NM rod bolts
- cavalier fuel pump location
- fitting twin webers to Nova.
- Vectra B V6 to C20LET
- steel con rods x22xe from ebay
- mk4 astra van - oil presure gauge
- c20letoil pump
- c20let - mk4 astra mounts??
- tappet trouble please help
- 20seh pistons
- zafira gsi turbo preoblems
- What torque is needed for up-rated "arp" bolts?
- Yet another gear selecting issue
- Corsa b f28 spacers for lower arm to tie bar
- exhaust
- major engine problem please help
- F20 ring on My F28?????
- speedo problem why is it out on my f28
- c20let ideal AFR settings
- 2.1 C20XE engine major problem.
- Z1.2XEP into a early corsa c Z12XE
- ECU suggestions
- Max bhp?
- c20xe exhaust manifold onto c18xe ?
- Corsa C C20LET Conversion Maybe?
- Redtop exhaust manifold onto an X20XEV???
- X20XEV non starter
- Z20let Stem Seals
- sorry for another c20let boost question
- upgraded valves for 14 nz
- fitting r1 carbs to c20xe
- review link about xe cam to c20let
- fiting c20let onto an f20 box
- Running a performance exhaust without a centre box
- Sportex exhausts-any good?
- 99 vectra 2.5 v6.....coolant check problems
- Astra mk4 isuzu engine swap
- "REDTOP" INTO A X20XEV VECTRA...advice etc
- Running External wastegate Z20 Standard management?
- Z20 Heads cracking?
- C20let water hoses
- question about bike carbs
- Do X16XE Pistons fit X14XE rods?
- Rocker breather pipes
- Good quality sounding performance exhaust system for mk3 astra gsi
- Standard c20let top hat diameter?
- what drive shaft can i use on my c20let corsa with an f20?? please read!
- c20xe head gasket
- C14XE poor running
- What dizzy do i need?
- sump bolt tightening order
- can some tell me what engine code my car has?
- nova diesel turbo keeps poping at 10psi
- 1.6 wont start
- C20 LET Conversion (01 reg)
- VW Gearbox problem
- 2.0 8v block and 16v head compatibility
- c20let clutch question..URGENT!!!
- Transfer box loosing PAS fluid through breather hose
- corsa b fitted with f28, gearbox resting on tie bar
- Boring an Engine
- what bhp will 22 spline shafts take.,
- LMF conversion hub
- calibra v6 into cav tips please
- F20 box or cav 1.7td box
- F28 speedo help wont go over 30mph
- Vectra B 2.2 to ZLET??
- turbo coolant feed
- Corsa Sport Stuttering and Engine managment light
- X25XE Into Astra mk4.
- upgrading cams c20xe
- F28 ON x25xe
- c20let where to start.?
- calibra turbo 4x4 6 speed box
- z20leh missing problem
- fitting f20 box to c20ne??
- f23 fork problems 2nd time
- Arp rod bolt fitting
- Mk astra starting issue.
- SBD throttle body kit?
- c20let cutting out problem
- speedo problem
- Vauxhall tigra 1.6 manual 1999 model starting trouble
- Boost controller / Amal valve??
- f28 6 speed box-will it fit to a 2.0 xe without much hassle?
- astra mk4 c20xe holding back and missing please help
- Are c20 xe rods same as let??
- vectra crank pulley nut..
- Z20let Big Power Tuning
- Immobiliser chip inside key needed for 20XE into Mk4 Astra?
- Eds phase 4
- c20let missfire
- Gearbox wurring noise when at a standstill?
- vectra v6 x25xe injectors into c25xe calibra v6
- Corsa B 1.0l Throttle Body
- just a very quick question about crank pulley bolt on a corsa 1.2 16v 2002 year
- vectra c20let
- code 118 wastegate valve high volt
- Cutting out
- c20xe overfueling... please help?
- adjustable fuel pressure reg,which one(why not fse?)
- c20let chips mixed up ????
- Dyno run! Corsa C c20let
- corsa redtop speedo
- c20xe bike carbs
- astra mk 3 1.7 diesel flywheel
- Isuzu 1.5 TD pressurising coolant system.
- Oil & Cold Starts - Good Advice from Opie Oils
- Non sparking Nova 1.2i
- C20let boost/engine problems??
- z22se crankshaft in 20seh?
- midi gearbox swap
- engine conversion help :S
- engine swap help
- Quick question idle problem on c20xe
- 1.6 16v sump
- top and bottom of ecu?
- X30XE, X25XE, C25XE better intake system?
- fittin c20let in 2 corsa c, what do i need to do this?????? please help, tryed lookin
- c20let fuel reg options
- 2L dti zafira flywheel & clutch combo
- V6 Vectra Problem
- c25xe v6 turbo conversion???
- Custom hubs!
- c18xe
- Fitting new oil pump.
- Help with nova engine swap
- locking transfer box
- C20let actuator? Where from?
- xe inlet manifold, pipes question.
- f28 clutch spline
- mk3 astra/x25xe v6 conversion help
- supercharging a seh?
- evolution 4 chip problems???
- cosa b x18xe1 conversion
- c20xe head bolts
