: Engines and Transmission
  1. new exhaust fitted to nova TD
  2. f20 gearbox
  3. XE Problems...
  4. fse and radiator
  5. xe timing marks, dont line up HELP!
  6. Maximum power from a c20xe engine?
  7. Which pins is it you short to get ecu codes on a X16XEL.
  8. Cat replacement box?
  9. throttle problem corsa valver
  10. Setup for Dellorto 45's on 2L xe
  11. throttle bodied engine timing marks
  12. Tigra engine mount
  13. 2.0 xe in rear of nova
  14. should my x16xe+mantzel drive like this?
  15. fuel pipe size
  16. calibra turbo
  17. AMAL Valve?? Help please!
  18. timing belt
  19. Red Top Turbo Query.
  20. cally 16v loom, ignition live?
  21. Calibra 8V, Engine probs! Poss Crankshaft sensor?
  22. Astra 1.6 Si Serious Problems!
  23. C20LET into a corsa, plain sailing or pain in the ass..??
  24. F28 gearbox, slight annoying problem
  25. driveshaft/cv joint reassembly
  26. Rolling Road today - 15bhp down
  27. XE conversion into Corsa Diesel?
  28. 4x4 problem
  29. exhaust manifold?????
  30. cant find 4th gear at high speed switching up..
  31. driveshaft problems PLEASE HELP
  32. DTA Engine management
  33. gear linkage what di i do............!
  34. Nova : Fitted new radiator, slow running water...
  35. C20LET problems....please help!!
  36. LET - Actuator Options
  37. Radiator into GTE 16v
  38. Induction kit or panel filter???
  39. Water pump removal.......
  40. urgent c20xe corsa f20 gearbox transplant advice
  41. Lambda Sensor
  42. Pinking/Detonation...
  43. Leak at gearbox
  44. Different XE blocks
  45. head pics help
  46. best running in oil
  47. fitting a universal backbox fabricators in ipswich
  48. Porus Heads on XE's
  49. is the let and xe lamba sensor the same
  50. oil pressure?
  51. C20let Headgasket Query
  52. 8v engine question????????
  53. engine conversions and wiring looms
  54. Block in storage has surface rust on mating face - how to treat?
  55. Relocating battery in Nova - where to ?
  56. 2001 Corsa 1.4 SRI Hot starting problem
  57. XE Cambelt Cover
  58. Opinions on exhausts required!!!!
  59. ally flywheels xe engine
  60. Torque settings for x14xe.....
  61. What engine oil should I be using?
  62. Engine revving eratically. Need help with ecu codes
  63. What Is The Best Oil,s
  64. nitrous
  65. Turbo 1.4 SR nova help!!!!!
  66. XE Teething Problems
  67. cav ecotec , white spark plug ends?
  68. C20XE - oil pump seal/sump gasket leak
  69. nova gte loom
  70. cat bypass
  71. my timing belt snapped.
  72. atra low blow diesel
  73. removing air-con pump
  74. Oil consumption, c16se
  75. C20LET alternator...
  76. F18 Gearbox Swap
  77. got my head back but one of the studs is bent!
  78. Clutch
  79. Question about gears
  80. irmscher backbox
  81. To Superchip Or Not To Superchip??
  82. Headlight adjusters...
  83. ECU location on Nova SRI???
  84. let doesnt rev easily after 5000 revs
  85. Over fueling?
  86. turbo boost
  87. cally exhaust bracket
  88. Reset Ecu, Or By A Chipped Ecu?
  89. HELP fitting 8.1 ltr intercooler
  90. xe problem when cold...
  91. ingredients for a xe into nova
  92. Contaminted clutch
  93. XE on an engine stand
  94. Pre/Post 93 C20XE Heads!
  95. fixed my suspention.
  96. headgsket failer (warranty claim).
  97. Piston rings and valve stem seals
  98. Mini With K Series K16 engine how?
  99. F13 gear cluster in an F10 ?
  100. Rs turbo block???????
  101. Driveshafts for xe into a nova??
  102. x16xe mantzel box......cam breather?
  103. calibra turbo brakes!
  104. Which intercooler for a Cav Turbo
  105. help with induction
  106. loss of power
  107. F10 Final gear to F15
  108. Blocked radiator causing water pipe to pop off?
  109. c20xe on f15/16 into corsa
  110. c20xe big end shells
  111. fuel pump starting when connecting battery
  112. removing crankshaft pulley
  113. Best Engine!
  114. Indicator Fault
  115. astra 3 gsi headlight washers
  116. suspension-cav turbo/gsi
  117. Turbo oil feed pipe "BLODDY EXPENSIVE" :(
  118. Altenator & C20XE issues...
  119. Intercoolers
  120. fuel rail thread on v6
  121. anode .. cathode??
  122. Sri 8v Head Bolts
  123. Vectra Diesel not starting
  124. XE head refiting
  125. low xe idle
  126. F20 Input Shaft Removal
  127. Head for a Calibra Turbo ???HELP???
  128. 1.8 spi VERY strange fueling problem
  129. Oil cooler sandwich plate question....
  130. Exhaust Manifold for a Redtop with AirCon?
  131. Engine mount on Mk3 Astra turbo.
  132. oil + volt gauges
  133. nova weber manifold
  134. Getting cams to sit right?
  135. Headlamp washer jet fitting
  136. My Breather hose has blown AGAIN!!!! ARRGGGGHHHHHHH!
  137. astra mk3 1.6 spi help
  138. what grease/lube for head studs?
  139. Z20let spark plug gap
  140. Oil change to stop blue smoke????
  141. 20seh to c20xe conversion
  142. 20seh to c20xe conversion
  143. red top engine
  144. Mantzel power resonator for Omegas
  145. Additional electric water pump on C20LET
  146. XE inlet cam in an LET?
  147. c14nz(1.4spi owners)
  148. snapped cam pulley on v6
  149. 94' Cav X20XEV Lambda sensor price ??
  150. Fuel / Trip Computer Reprogramming?
  151. Engine number on a c20XE
  152. C14SE cheap mod
  153. C20Xe engine problems
  154. turbo without water
  155. Engine number on LET?
  156. GTE gearbox transducer removal
  157. 1.6 16V TB'd motor. Gearbox issues!
  158. headlamp alignment? can u do that yourself?
  159. XE Running problems...
  160. Oh crap, engine apart job????
  161. XE into Corsa B - Fitting Kits!
  162. Oil Cooler On Corsa Let
  163. X14XE ECU problems?
  164. Rebuilding nova gte engine - questions
  165. which head gasket
  166. petrol gauge not working on nova
  167. Where do you get your metal fin water pumps from.
  168. water system
  169. XE with snapped plug
  170. c20xe valve lifters
  171. Injector Valve 2 - High voltage. What does this fault code mean???
  172. Calibra Turbo dash fault lights not working...
  173. LET is running after rebuild but few questions
  174. FAO: the Banana people, or 20SEH/C20NE owners
  175. regal steel head gasket question?(c20let)
  176. Lambda sensor
  177. next mod for my calibra turbo?
  178. temp gauge on let,location and info please???
  179. cav v6 clutch
  180. LET into a corsa
  181. wiring loom and gear linkage
  182. C20XE in Nova Gear Selection Problems
  183. c16xe mantzel power box????? HELP!!!
  184. 160MPH turbo clocks?
  185. let into a gls shell
  186. Correct tools for valve replacement on LET head?
  187. Spi to mpi
  188. What fitment are Cally headlight and fog light bulbs??
  189. astra turbo running on 3 cylinders
  190. LET - no spark
  191. Confirm problem + anything else I could try??
  192. gsi mk3 turbo
  193. dump valve ????
  194. HELP 20xe rattle/whease around inlet manifold
  195. crankshaft sensor
  196. 1.7 Dti 16v low end power problem
  197. Help! engine wont fire, C20LET, very weak spark, Help!
  198. Earliest 20XE Engine?
  199. uprated oil sump gasket?
  200. uprated oil sump gasket?
  201. Could a faulty injector cause.....
  202. vacuum in inlet manifold
  203. Xe starting problems
  204. Camshaft cap numbering.
  205. TURBO Conversion
  206. Frontera Intercoolers
  207. Accralite Pistons/Arrow Rods
  208. 4X4 t box upgrade
  209. electric water pump
  210. Tigra - C20XE - any advice?
  211. LET - Headbolts. What ones?
  212. Fuel/Trip computer reprogramming
  213. Fuel delivery issues??
  214. FFS. Urgent Opinion Needed ; Cylinder Head
  215. Ecotec blown headgasket - advice please?
  216. gsi engine re-build
  217. **XE Conversion - mechanical to electrical speedo help! **
  218. Spark plug gap varies between manufacturer? 2.0XE
  219. Rocker bolt?? c20let
  220. ohh dear turbo dieing???
  221. How to check gearbox oil.
  222. damage to flooded diesel engine
  223. VALVER problems....
  224. XE valve collets?
  225. Checking engine health/condition...
  226. Engine managment light
  227. 1.8 8v Belmont engine into astra mk3...
  228. 15 psi out of standerd LET?
  229. Monza Fuel Computer Wiring
  230. modifing throttle body?
  231. cav 4x4 ecu
  232. Nova 1.5TD Intercooler!
  233. CORSA 1.4 16v: Cambelt snapped!!
  234. 2wd conversion kit for gsi 4x4
  235. X14XE running problems
  236. new clutch slips on gas
  237. vectra 2.5 misfire
  238. Astra Diesel Injector Leaking
  239. A few transmission Q's
  240. Still High Idle [astra gsi] redtop
  241. QED Cams
  242. My replacement fixed TXB box
  243. Crank bolt
  244. which head bolts?
  245. TD Engine swap?
  246. chipped ecu
  247. Which head?
  248. XE Flywheels
  249. C20LET Cam Belt
  250. 1997 X14XE aux fan doesn't work when A/C is off
