- F28 mechanical/elctrial question.
- c20let turbo recon
- Zafira GSi Engine problems....
- M-Tec v3 or MBE
- 1.0 corsa b oil warning light issues
- x30xe in a corsa?
- Gt3076 how does it drive below 4000 revs
- c20let block advice
- Corsa with F28 Gear rose jointed linkage diagram needed.
- lamda sensor
- coil pack to dissy
- what cams for c20let
- c20let engine building help needed
- redtop corsa gear linkage problem
- will the vxr crankshaft fit a z20let engine
- Bike carbs c20xe turbo
- z22se driving stutter
- Corsa 20XE on bike carbs, what to use for ignition?
- radiator for let thinner than the standard one
- which starter motor for my c20xe running pot flywheel for f28??
- fuel reg and bypass plate
- R1 bike carbs on xe suddenly overfuelling quite bad
- does aquamist actually work
- c20xe oil pressure problems(HELP)
- Oil system won't prime - 20XE
- f28 gear linkage in corsa
- 3 way fitting on c2let manifold?
- Steinmetz box for calibra turbo 300cv
- Airbox help
- 1.4 / 1.6 16v astra mk4 driveshaft
- c25xe firing problems
- engines c20xe and c20let?
- Eml and no speedo c20let
- Where do these water hoses go? C20let
- Rebuilt engine burning oil?
- ECU lighting up with loss of power
- Corsa 1.5 Diesel overheating
- kkk16 rebuild
- Vectra gsi msd into nova?
- Corsa 20xe won't start
- C20LET Air Filter
- mk3 astra converting to a c20xe :D
- c25xe / x25xe crank sensor
- Engine mounts for Mk3 Astra.
- Corsa Bigger Engine?
- C20LET - Servicing
- which gearbox
- Opinions on 8v's please
- vectra v6 charged
- 08 CDTI Noisy Engine
- Aiming for 400bhp!
- need prices
- vectra gsi x25xe power gains???
- 20xe/f20 into corsa B 1.2 16v: what n/s mount???
- equal length corsa b shafts???
- 18se engine
- Fiat Car Running XE & F20/16 - Cable Selector Possible?
- Astra 1.7dti oil cooler bypass, what pipe to use?
- vehicle speed sensor on f28
- c25xe / x25xe
- What engine do I have? Vec C 2.2
- combi van
- is 316 stainless steel good for a manifold running gt3071/76r
- X20XEV - smoke signals - could it be head gasket?
- f28 driveshaft oil seal
- Fuel pump
- F15 Gearbox questions - Corsa sport
- individual silicone hoses
- helpful gearbox ratio tool
- Nova saloon/ 3dr hatch petrol tanks the same...
- C20XE baffled sump
- Changing 2.0xe from dizzy to later coilpack set up
- mk3 astra quickshift help?
- will a clutch fit out of a mark 3 astra derv into a mark 4 derv?
- What headgasket to go for (c20let)
- Need a new dump valve for my Z20let
- Vectra 5-stud hubs
- 2000 corsa b no drive?
- 1.4 sri engine
- Corsa B 1.2 16v - Water pump\Cam belt
- Help! X18XE1 mount/cambelt differences???
- QED DTH Help needed
- fitting wideband AFR with bike carbs
- fuel control
- corsa 1ltr 12v non start 1999
- How many teeth can you be out without noticing
- LET ebay t3 manifolds-fitment/clearance
- C20LET: Vernier pulley fitting\advice
- wanting to achive 200+ BHP using X20XEV - thoughts?
- corsa c 1.2 sxi smoke
- X14XE water pump alignment
- c20xe 2.8 loom
- c20xe cam belt help
- 1.4 16v Wont Start/Fire...
- Quick Turbo Boost Question
- HELP! Corsa b missfiring / cutting out
- EDS Phase 3 boost wheel problems :(
- converting 4 stud to 5 on mk3 astra whats needed..
- 1.4 Corsa Engine running badly when first started up.
- VX 1.3 CDTi Engine...Fuel leaking from fuel pump...Help please
- HELP with removing c14se throttle body ?? 1 bolt i cant get
- Has anyone done a 1.3cdti engine into a corsa b ? whats needed ?
- 20xe afm
- 3 liter lower divider on Vec V6??
- Can CTS - Coolant temp senseor failing cause a 4000RPM idle? answer ASAP!
- c20xe spark, but no fuel in cylinder??
- Dirty injectors
- how hard to fit a c20xe engine to my mk3 astra currently fitted with a 2.0 8v??
- calibra 4x4 on snow
- coil wiring
- best place to buy rc injectors??
- Consumption too high. Astra cabriolet X14XE 1.4 16v 90cv 1997
- How do i remove diff to get speedo ring off an F20???
- c20let- steel rods yay or nay
- Corsa X16XE - Breather / Vacuum Pipe HELP!
- Best c20let mods
- Fuel Rail
- Isuzu Td on chip fat
- Phantom Grip on f28?
- C20let t3 or t34?
- which gearbox
- coil pack to dizzy on a c20xe is it poss??
- f13c failed, which box next?
- 2l 8v into corssa 1.4 8v
- Astra mk3 1.4 16v: Manifold heat shield pipe.
- modified pickup pipe for c20xe
- vaccume pipers
- how easy to fit carbs to late xe
- problem starting my 1.6 8v corsa
- Tigra Running Issues after Head Removal
- z20let gt28rs help
- EDS Phase 3.5
- water pump on a vauxhall corsa
- corsa c c20let paper clip test help.....
- Zafira A or Zafira B f23 for z20let differences?
- Replacing Irmscher Exhaust - Astra G 2.2 Sri
- difference between z18xe and x18xe
- Phase 3 chips
- how can you tell if a transfer box is a locked txb cally turbo
- Re pluming a c20let
- what engine have i got
- which cams
- 1.8 8v turbo
- MK4 Astra Alternator Tensioner
- zafira gsi tc switch
- Clutch To Flywheel Bolts??? C20let
- 2.0 8v performance..?? what can be done and how easily?
- ngk ZFR6F-11 are they gapped to 1.1 from new ?
- Redtop (c20xe) Rebuilding
- f13/f15 v6
- c20xe qed cams
- what gear box in mk3 astra please help
- gearboxes F16, F17, F18 final drive
- calibra v6 engine mount any one
- C20XE with X20XEV Auxiliaries
- Part number
- What turbo to go for???
- corsa c20let conversion questions
- Final Drive of calibra rear diff?
- Final Drive of calibra rear dif?
- x20xev into mk4 astra sxi troubles
- vectra missfiring badly cannot drive!!!
- head gasket
- How do i fix fault code P0202 (injector 2 high voltage)
- list of LET fault codes, help please
- How do you compression test a engine out of car?
- Vectra B/c20let 400hp - which gearbox ?
- RR setup help Derbyshire?
- Corsa A vs Corsa B
- Cam belt tensioner rattle ?
- c20let front pipes
- how can i tell its an f20 gearbox?
- v6 help
- Multi Vee crank pulley
- Corsa 20xe running too hot
- How do you set up a turbo actuator?
- DTH (CDTI) CRANKSHAFT 1.9 -2.0 on c20xe engine block
- Big problem. no spark on 2 pistons. 1 and 4.
- Help turboing diesel!
- f28 corsa shafts which ones please help
- corsa b sport x14xe holding back when floord
- saab reds and afpr!
- firing on 3 cylinders on start up in a c20xe (coil pack) corsa
- C20xe (redtop) head onto a Z22XE Bottom end ?? HELP PLEASE
- Cooling problems, fan wont kick in !!!
- Astra mk4 > XE conversion, wiring in the clocks
- idf weber or dcoe 1400 8v 40`s
- vec 2.2 dti owners and vari vane turbo
- Z18xe itbs?
- Z20let pistons in a c20let block
- combo 1.7d engine swap
- vectra b x16xel burning oil, misfiring, smoking following rebuild
- Vectra 2.2 ls rattle from startup
- Stuttery kangarooing mk 3 astra
- corsa b 2.5 v6 x25xe misfire PLZ help
- piper cams
- tigra miss fire when hot
- x18xe1 oil filter housing leak
- Can u check if valves are bent without removing head
- Omega Z22XEV TURBO set up need help..???
- c20let lambda same as xe lambda?
- corsa eating altenator belts
- x16xe inlet manifold
- vec gsi water spouting out bottle after a few miles of driving
- c20xe intake monifold dimensions
- Lowering compression on z20xe
- how to remove air con and power steering pumps corsa sport
- which manufacturer does vauxhall use for water pumps
- Vauxhall specialists Derbyshire??
- Is it possible to bend anything by hand cranking
- c25xe misfire
- x18xe1 poor idle and misses low rpm
- QED
- vectra supertourer diagnostics
- 2002 Astra TD electrical fault
- Vectra X20XEV cuts out once i let throttle off and wont idle !HELP!
- calibra xev wont start? please tell me if ive done wrong
- engine rebuild for calibra
- C20let radiator hose help please asap :(
- saab b204 RWD chevette
- f28 and dash ?
- X16XE SUMP Help
- c20let problems when under load
- c20let and f20 clutch problems
- f28 for x25xe
- Astra V6 Wont Start
- emissions
- What gearbox ?
- C20let lambda sensor?
- c20let cams
- c20let knock sensor replacement.
- clutch replacement on astra mk3 v6
- problem of cooling Opel Astra TDS 1686 cc 82 hp ISUZU 4EE1
- C20let boosing problems
- Difference in TXB for F20 or F28
- Redtop into landrover?
- posting an engine prices
- motorsport enigne mountings
- Vec C 2.0 turbo advice
- Help needed asap
- Gearbox or driveshaft Dont know which has gone.
- vectra hydraulic tappet change now wont start
- mk3 astra redtop conversion?
- 1.4 astra spi battery overcharged and now wont start
- c20let on f20 clutch help
- vauxhall vivaro / renault traffic clutch change
- x14xe, engine swap to ......
- Fitted new clutch 3 months ago now it seems itsgone again? Its only a fiesta!
- Wastegate, D/V, Turbo stall, Chatter? Excess damage to turbo?????
- x14xe (i think) running prolem
