- xe or 1.6 turbo ???
- F28 in a MK2 Cav.
- calibra exhaust system
- Has anyone had the head on their Z20 LET polished internally, is it worth it?
- turboing c20xe?
- polycarbonate window kit's
- neil c cav suspension
- More Supercherged XE probs
- Astra Turbo...C20LET teething probs
- Engine mods!!!!!
- c20let idling at 3k rpm
- Fault codes on astra G diesel
- inlet manifold shapes
- XE16L Fault Code!!!
- Exhaust temperature gauges
- C20LET advice - couple of points
- C20LET compression test help wanted
- ///Engine info needed///
- Cant get my exhaust on!
- mot and cat convertor question
- do mk3 astras have a fuel tank vent
- any users clean injectors
- changing a clutch.....
- F25 and F23 ratios
- sizes of LET rods and low comp pistons?
- f20 gearbox fitting (urgent)
- what injectors
- Yellow Injectors
- FUEL FILTER "ARGH" ADVICE
- 750cc injectors for a LET
- Cts
- Fitting new pistons XE engine
- Wiring up a GTE engine.
- Astra 2.0 DTI unmappable...
- Astra Engine into a Nova.......
- Just bought an uprated intercooler
- 186.6 BHP / 168.7 lbft Ecotec !!
- F1's or Proxes
- Tuning using LPG as the sole fuel
- 2.0 16v XE lifters and a few other bits...(pics)
- Fitting a fse fuel presure regulator on a xe
- What fitment are Astra Mk3 headlight and fog light bulbs??
- turbo oil feed pipe
- Does anyone know where to order megaspark?
- Fixed my Nova 1.3 SR!!!! :D :D :D
- XE Corsa G'Box Mount, look ok or not?
- X16XE cutting out all the time
- 2.0 XE Exhaust manifolds??
- gearbox, clutch or other?????
- Throttle Cable for GTE
- f20 to f28 mod
- using oil
- slight engine conversion soon
- Duff fuel gauge (again)
- carbs for nova gte
- gas flowed head...............
- corsa xe driveshaft question!
- first gear switch f28
- c20let FPR Hose another quick question
- Bloody Fault Code on Z20 LET! grrrrrrrrrrr
- REALLY NEEDING HELP , "LET"
- radiator wit c20let into an astra
- Coilovers
- Free Power
- Nova 1.3SR Gear Shifting Problem - please help - part photos inside.
- wire from ecu c20let
- dump valve
- Oil Pump Gaskets
- motronic 2.5 ecu codes
- Mass air flow for C20NE!,Head, Camshaft,Ignition (Need advise)
- diesel sounding !!!
- Uprated C20XE cams- whats the score?
- Custom exhaust?
- 1.6
- F25 to F23 conversion
- no spark
- engine mounts
- c20xe supercharging?
- Sparks out my exhaust
- xe/f20 clutch issues
- Will The XE Breather Mod.....?
- Question for Turbo owners.......
- corsa wont start
- Blocking off LET dizzy
- Nova XE oil filter housing???
- omega auto gearbox problem
- LET into Tigra
- 2.0 8v and 16v oil pumps, how different?
- Oil pressure/temp gauges X16XEL
- XE - Oil pressure gauge?
- My XE sucks like a Dyson Hoover
- Quick engine type recognition??
- remove rear drive shaft????
- turbo inline oil filter
- Exhaust
- clutch noise
- Power and weights
- Idle Control Valve
- inlet cam for xe
- Guide to V6 Forced Induction
- Nova Turbo Dump Valve?
- Big problem - could headgasket have caused it?
- Gear-box noise help!
- Fuel consumption
- c16xe engine number help....
- 2002 Corsa 1.2 . .... already?
- Removing oil filter...
- Emissions problem
- cat's o/s
- which clutch to buy for c20xe on NOS
- 2.0 DI 16v Oil Leak
- Nova C20XE Problem
- Whats difference between std kkk turbo and a hybrid turbo?
- Breather Pipe?
- redtop oil in water tank???
- air filter/induction for corsa 1.4 16v
- f20 / f28 / f18
- Astra Mk3 1.4i Singlepoint To Multipoint Conversion
- How easy to Turbo a C16XE
- spark
- Does any one have a x25xe wiring diagram
- c20xe... keeps high revs??
- Lets talk suspension, arms and bushes :D - Need some help please!
- putting petrol in a diesel engine
- Let Into Calibra 16 Valve
- BHP in a 1998R 2.5 V6 SRI
- Let exhaust gasket..quick question
- gear oil
- alternator problem.c20 let.help please
- Fuel tank
- Power gains from an uprated intercooler
- Astra Radiator and cooling system
- strenghting the engine bay
- Multi-throttle setups; good why?
- Astra 1.4mpi
- 1.6 Ecotec in to Astra?
- F28 Flywheel Cover
- 1.6i - 2.0i
- Arp head studs
- Diesel Vibrations
- What is the part number on the XE inlet cam?
- which fuel reg/head gasket?c20let
- Parts for my f28 anyone know where they sell these?
- Iridium plugs on a Z20LET?
- Standard LET ECU
- Chipping an LET with an Apexi AVC-R
- Head gasket set??
- c20xe engine trouble
- Phase 2 MK3 Astra let conversion question
- fuelling? (autronic)
- Astra fuel pump - mechanical or electronic
- Inlet manifold (runners) porting?
- Engine rebuild question
- nova gsi engine into corsa b
- Anyone got any experience with DTA on an LET
- C20XE Sump/Oil depth
- Crank sensor for Motronic 2.5
- injector help please
- Upsolute remap for DTi
- Vectra inlet air pipe mod
- Head Gasket....
- idle speeds
- xe to 8v conversion what do i do?
- Fuel Pump
- injecters and fpr
- possible let probs
- Throttle cable
- has anyone ever converted an f28 to mechy speedo?
- Gearbox change clutch etc
- pouros head
- Injector O-rings (LET)
- 115 bhp nova 2ltr
- F28 Issues
- Engine Swappage - Cally Turbo/Mk3 Astra
- chipped LET dyno graphs required
- Nova engine conversions.......
- Stroke of a XE/LET
- Vectra turbo owners
- 1.6 8v problems
- F28 flywheel cover same as F20 ?
- Ecotec Exhaust Manifold crack ?
- Started at last (Supercharged XE)
- engine conversion
- cally turbo flatspot stalling off
- Xe loom
- flywheel cover plate
- CTS on 20SER?
- xe vlaver guide
- Cavalier Engine into an Astra
- Uprated Clutch for my tuned LET - What's THE Best???
- 1.6 16v gsi
- let me know
- omega gearbox
- k&n induction kit
- ** Fitting Corsa B GSI engine in Corsa C
- X18XE1 oil filter
- Cheapest place for a Mk4 Astra Exhaust?
- 4x4 trouble
- clutch
- astra gte 16v and calibra turbo`s
- AMD VS EDS software, which is best???
- LET oil leak (rear of engine)
- Leaky Let
- Let no spark and rev counter going crazy .
- Fuel pumps?
- Exhaust Wanted!
- clutch slipping
- Another Fuel Problem
- clutch on a f28
- viper kit on a Cally T
- quick air filter question..
- radiator
- 275bhp XE
- Oil cooler
- c20xe sump advice
- turbo technics
- gears corda b
- Corsa 2L conversion AND A/C
- Gear knob removal - how??
- Calibra Air filters?
- phase 2 LET no overboost
- Bigger fuel pump?
- coil springs
- which intercooler
- Water injection kit?
- anybody?? will a fuel computer work ?
- can i put this electronic gear box on my cav turbo?
- Breather pipes
- Turbo Hesitation/Kangarooing - Help Please!
- Finding moronic 2.7
- Engine mounts - someone with banana...
- annoying squealing noise from 1.2 Corsa
- vauxhall fuel pumps
- oil for C25XE
- throttle bodies
- Duff fuel gauge
- 20 LET into a nova
- Bigger capacity or C20Let ?????
- 2.0 blocks
- Quaiffe diffs or any lsd
- Nightmare changing rear engine mount!
- Who Does TURBO Conversions
- c20xe into mk2 astra
- Turbo advice
- gearbox/ speedo cable question
- cav engine mods
- turbo gage
- Cav GSI fuelling problem?
- Where can I get vernier pully for the XE exhaust cam LET mod?
- /// ALL 1.4 16v engines the same???
