- 1.4 16v
- Vacuum pipes on 1.4 8v?
- Corsa C 1.7DTi ECU issue
- compresion test plus results
- vectra 2.2 ecotec snapped timing chain conversion to x20xev
- c20xe Lexmaul inlet manifold?
- astra vxr equal length shafts instead of cav/cally
- Corsa c20let driveshafts
- High idle speed and rough running
- cambelt tensioner bolt
- closed
- c20let valve seals
- Putting a 1.9CDTI vectra 150 engine into mk4 Astra Van?
- x16xe problem
- exhaust q - emissions light - astra g 2001 1.6 8v
- c20xe missing / will barely rev
- Odd cooling problem... heater blowing cold.
- 6 speed Vauxhall transmission to fit a Saab 9000
- c20seh/c20ne loom+ecu?
- Hybrid kkk16 turbo unit.
- k16 water hose return,
- head gasket
- corsa starter?
- speedo problems
- Not engauging gear?
- what parts for xe conversion
- c20let crank
- C20xe Bottom Crank Pulley???
- c20xe water problem
- F20 gearbox oil consumption
- Zlet oil pick up pipe O ring part number?
- big block shaft question
- 1.2 8v - x16xe Corsa conversion
- corsa 1.4 16v
- c20let turbo recon
- X20xev > z20let
- RWD C20LET Gartrac Escort
- C20LET calibra Airbag
- corsa 2.0 8v gearbox?
- Engine problem on vectra sri
- Breather Help
- c20let dying when in gear
- c20xe on carbs, what are my options ignition-wise
- C20LET AE or MAHLE pistons, which are stonger?
- C20LET downpipe olive/gasket and studs
- Fuel Consumption, Z16SE..ideas?
- 1.4-1.8 corsa Sri loom! *conversion gods in here please!*
- x20xev rebuild?? info needed please!
- x18xe1 breather
- C25XE - Coolant reservoir sludgey?
- corsa c 1.2 was running now not starting... HELP
- turbo conversion help
- Wats the best boost control for c20let running t3t4
- cambelt change
- corsa c20seh /ne starting and running problem?
- just enquiry
- 1.8 Vectra Lambda Sensor
- nova td needs alternator!!!!
- F23 z20let gearbox stiff selection when warm
- tunning 20ne/20seh
- 1.2 8v Tuning
- How do you choose a turbo?
- Is this a starter motor fault??
- rad fan switch on 8v calibra help
- Mk2 astra redtop converting to c20let engine "whats needing swapped"
- vectra small block to big block
- will it be worth selling my c16xe
- wot bhp will i get out of a 1.3 8v on 40s
- Corsa Engine not running right.
- Z20LET idle issues. please help :)
- corsa front anti roll bar yes or no for trackdays
- Turbo'd C12NZ. Could it work in theory?
- Skoda 1.8T owner confused by servicing a 1.7 DTi Astra MK4.
- C16XE 170-180bhp ????
- C20let missfiring?? under load over 4+k revs..?
- corsa gsi egr
- HeadGasket On 1.7 CDTi Astra
- z18xe compression test results
- XE bull**** or fact?
- wheres the best place to buy arps
- C25XE starting problem
- High idling X25XE, recurrance of old issue. Help please :)
- clicking/ticking coming from ECU
- C20LET Running Issues!!!!!
- 2002 Vectra DTi
- automatic to manual
- anyone heard of blueprint phase 3 chips
- Corsa b 20xe front drive shafts and hubs
- Corsa c20let downpipe advice needed.
- Vectra B V6 running rough
- 1999 2.0DTL Astra Fault Reading
- Are Astra GSI Calipers The Same As Cavalier GSI?
- is the z20let head the same with the z20leh head?
- 1.8 smallblock conversion questions
- astra turbo 2001
- Peoples thoughts - issue with my c25xe (with vid)
- what oil for c20let
- What oil for a 2003 1.7 DTI astra?
- kkk oilsesals
- C20LET Turbo Oil Seal Failure - Need help
- F15 gearbox problems
- C18XE expert needed in dewsbury,batley,wakefield area!!
- X12XE engine issues
- z18xe headgasket
- put c20let in corsa b
- piggy back chips on c20let ecu
- Swirl pot setup
- C20LET Phase 2 spec but unsure what turbo
- Td turbo conversion
- white smoke on over run?
- mk3 astra gsi and f28
- F20 speedo mechanism....
- car exhaust smells like rotten eggs
- kkk16 and exhaust pressure
- EML on my MK3 Astra
- Confirmation on clutch cylinder required
- Stanadalone Management
- c20xe ecu code help?
- c20let misfire
- X14XE to X16XE conversion question
- how can i make my 1.4sr quicker???
- 1.4sr engine
- 2.0mm cometic gasket on let what torque setting
- Help please GT2871r forged Z20LET
- Help! astra gsi c18xe idling like a yoyo!!
- XE only firing on 1 cylinder
- gt2871r roller bearing help
- Wiring in a c20xe! (DIZZY) QUICK QUESTION!!!!
- let leads to dizzy
- how much oil does a let hold
- C20xe on carbs problems
- Can You Still Get a GOOD C20XE?
- C20xe exhaust
- H steel rods with ARP's for C20LET
- opel tigra overheating and stalling
- Dry sump on C20LET gen
- Y32SE in FWD Calibra
- want to make my nova td faster than it is???
- want to make my nova td farster tshn it is???
- xe exhaust sizes
- Should i buy a Zafira (a) 2.0dti or zafira (b) 1.9cdti?
- anyone help me with vacuum pipe locations on a c20let
- diesel into turbo diesel
- Hi, Over Reving engine damage?
- 20seh ecu code?
- MSD ignition coil
- F28 hydraulic conversion
- taking c20let ecu apart
- why does my speedo not work??
- Vectra B X30XE conversion
- F28, Which Synchro
- astra & zafira vxr use the same gear shift cables?
- Astra 2.0 di no turbo boost engine management light on help
- Pros and Cons of cams, turbo conversion, diff and ecu?
- Converting nova shell from petrol to diesel, whats required?
- c20let flywheel and clutch question
- fuel system
- c20let ecu getting really hot
- Tigra 1.6 16v Alternator Belt Change
- Mk3 Astra/ Vectra 1.8/2.0 similarities
- will this work for a corsa???
- C20let corsa ECU Chips
- c20let ecu ???
- converting F28 to FWD
- F28 gearbox speedo
- X14XE & X16XE Gearbox's.
- ARP mains settings
- Forum Rules - Thread Titles
- fitting c12nz single point injection in a nova ("ecu" wireing probs)
- where to get FPR
- spanner light on dash
- should my fuel pump be running all the time on my corsa b c20let with ignition on
- Engine with very small head gasket leak, what oil to use?
- solid lifter conversion
- tigra v6 conversion
- Anyone Help - i'm stranded in South Mimms
- would a corroded pin on the ecu plug on my c20let stop it boosting
- Cambelt tensioner bolt
- cause of white spark plugs?
- Oil leak
- Thick mayo under oil cap
- corsa c20let misfire and no boost
- Corsa B 1.7 Diesel glow plug problem :(
- x30xe on c25xe managment what chip?
- M&E test thread
- sri to gsi
- Any GM V6 boffins around?
- fuel lines
- 1993 corsa sri engine problem?
- compression test
- C20let Internals, turbo and ecu suggestions?
- 16v Conversion in a Mk2 Astra 8v
- diff between 1.2 and 1.4 8v heads?
- c20xe cold idle
- later 1600's vs earlier ones.
- let head gasket
- f28 quaife diff fitting instructions or tightening torques for box
- to chip or not to chip?
- Turbo Oil feed Help c20let
- c16xe fault
- Corsa C 1.2 2002 - ECU light on
- Nova Sport cylinder head
- CHIP FOR or ADJUSTABLE FUEL REG 2.0XE WHO SELLS THEM AND HOW GOOD ARE THEY?
- X16SZR tappy
- 7000+ rev limit
- longitudinal engine mounting in corsa b???
- Custom exhaust
- Vectra 2.0dti problems
- 20xe rear plastic water pipe
- C20seh tuning and rebuild parts??
- C20LET on XE 4x4 setup with F21 gearbox
- Quick oil drain valve
- 1.7 cdti timing belt - recomendations
- Light weight flywheel?
- c20ne with F13 gearbox
- These genuine??? chipped ecu
- Arp rod bolt fitting (pro series)
- final drive
- Water Pipe Part Number
- 2.0 8v into corsa b
- dis pack to h&h ignition distributer
- Astra 54 Plate 1.7 TDCi - Fuel EDU UNIT "Location"
- Setting up a apexi avcr on a LET, programming etc
- 2.2tid saab camshaft
- C20XE Timing kit
- paper clip test
- z22se being strange
- What's this engine mount off ?
- Mains and Rod shell sizes? using 20xev block with xe parts?
- 1.4 nova race car, whats best engine??
- Red top c20xe
- Torgue setting for arp 2000's in steel rods
- fitting oil pressure sender to c25xe cavalier
- Z18XE is this universal between Vectra and Astra??
- Mk4 Astra Diesel Info Required
- 1.6 16v into a 1.0l corsa b
- Newbie Advise Please
- mounting z20let into corsa b?
- Anyone know the code for z20net turbocharger?
- which adj fuel reg for vxr injectors on ph 3 c20let?
- Minimum c20xe head thickness?
- C20LET cambelt tensioner allen key size
- another way to runcorsa speedo???
- What Do Glow Plugs Actually Do?
- calibraF28 info help please
- Corsa 2.0 8v wont start
- gear cables
- Cavalier turbo (vivaro intercooler)
