: Engines and Transmission
  1. Please help Ignition only ecu needed
  2. fitting pec rods to my Z20leh, clearance issues?
  3. central door locking problem, probably in a Mk3 Astra
  4. Corsa B C20NE / SEH conversion info
  5. mounting an X14XE and F23 box into an mk3 GSi astra???
  6. F20 gearbox differential backlash setting
  7. Gearbox rebuild northeast?
  8. c20let square timing belt on old style round tooth pulley set up
  9. C20XE helix clutch
  10. 20xe,late type head on early block?
  11. Pic. request. MK4 Astra gearstick setup
  12. Y26SE Removing cats with out EML coming on? Maybe a map will sort it?
  13. Zafira GSi jerky and feels flat when driving
  14. Corsa c14se engine fault code - 86?
  15. 01 1.6 8V Astra help needed after a camshaft change
  16. c20xe timing belt slack on the right idler after run
  17. Astra mk4 sri x20xev spluttering at 4500 revs
  18. engine not starting(1.6l 8v)help..
  19. vectra 3.0 cdti v6 performance
  20. Corsa c14se lightened flywheel?
  21. Boost info please
  22. astra sri turbo running out of fuel but computer says still has miles left?
  23. Gc1 code on cams?
  24. C20LET Corsa misfiring
  25. HELP! C20LET Cometic Gasket Failure after only 3000miles
  26. Z14XE Main Circuit Relay
  27. 20xe flooding only on piston number 1??
  28. c20xe exhaust diameter
  29. Power box on a C16xe
  30. new c20let nova
  31. question kkk turbo
  32. X14XE Refusal to start
  33. C20LET Juddering, lumpy.
  34. z20let head sri 140 bottom end
  35. Vectra GSI 2.6 V6
  36. Zafira Z18XE F17 fit X20XEV?
  37. fit F28 to a v6
  38. V6 Tuning. Probe/MX6 Manifolds, DIY porting options and Chips? (Not the edible kind)
  39. c20xe starting and running problems.
  40. Engine Spec's X22SE/Y22XE
  41. cavalier c20xe fuel pressure too high??
  42. Wastegate chatter on gtx3071r
  43. Diff ratio markings
  44. Z20LET blocks
  45. C16XE Nova Conversion - Not getting any fuel?
  46. C20LET splutter/cut out
  47. c20let - more torque than bhp
  48. Signum 1.9 (diesel) hunting when stopped
  49. Vectra 1.9 caliper issues/missing gaiter
  50. Paddle clutch question
  51. XE/LET cam cover breather modification
  52. CorsaC 1.2 16V idle issue
  53. 1.8 Mk3 Astra Van fuel pump
  54. Sensor pin outs for c20let
  55. Relative engine load, no reading
  56. Wire up rev counter to coil???
  57. C20let into Mk3 astra van
  58. f23 or m32??
  59. Boost z20let
  60. 05 plate 1.7 CDTi (100) Astra Coolant leak...
  61. Cav turbo engine management light on
  62. Wiring LET into BMW E30.
  63. C20xe exhaust valves??
  64. corsa b z20let convertion
  65. astra g 1.7dti idles at 1100rpm and sometimes lacks power
  66. x16xe belt help
  67. Tigra A brake upgrade
  68. Differences between Z32SE and Y32SE?
  69. corsa c - starter motor goosed?
  70. highest lift xe cams?
  71. Cavalier CDX and diesel - same F18WR box?
  72. XE on twin 45s starving fuel at high revs
  73. c20let problems
  74. Vectra 2.2 power steering exploded !!!
  75. What chips do you think??
  76. Vxr turbo on zafira A gsi
  77. Z20let P0244 & P0100, intermittent poor idle, air leak sound NEED HELP!!!
  78. R1 carbs TPS
  79. k04 on c20let ?
  80. Mini moto carburetor
  81. c20let upside down manifold
  82. C25xe missfire
  83. c20let turbo
  84. astra mk2 8v turbo water over heating
  85. 2001 2.2 vectra rough idle, smell of petrol and black smoke on acceleration
  86. astra mk3 v6 gsi staring problems pics uploaded
  87. Mk4 Astra GSi New clutch?
  88. isuzu piston
  89. C20LET clutch kit?
  90. Zafira gsi let engine with new vxr turbo
  91. 1.8 corsa c
  92. urgeent help required please
  93. Zlet FPR on zleh
  94. Astra G sport 1.4 16v
  95. F20 Gearbox shorter final ratio
  96. closed
  97. C20let injector upgrade advice needed
  98. Fuel pump wiring
  99. Nova C16XE - What other vauxhall fuel pumps are suitable?
  100. closed
  101. astra 54plate 1.7 cdti cranking over (starting) problem
  102. Forging Z20let
  103. Question about Z20LETs
  104. Astra GSI Turbo VXR Turbo Swop
  105. Turbo Info for C20LETs
  106. Astra mk4 x14xe cutting out
  107. 2.0 16v ecotec shafts > F28 gearbox?
  108. nova c20xe shaft question
  109. saab turbo conversion parts list mk3 astra
  110. arp rod bolts recessing caps
  111. Jumping out of 3rd gear !!!
  112. c20let turbo housing
  113. water routing on let
  114. c20let injectors
  115. Silicone hose suppliers? Cant find a 30deg elbow..
  116. Corsa c 1.2 z20let help on wiring
  117. c20let water return
  118. c20let knock sensor
  119. How tight to do the diff cup on a Nova diff?
  120. C18xe in to a cavalier.
  121. Astra mk4 gsi gearbox. F23
  122. clutch for f28 v6
  123. tuning 1.2/ 1.4 8 valvers?
  124. spark plugs c20let
  125. corsa b 1.2 sxi 16v sounds like a diesel :( ?
  126. whats the lift in mm on ixe nlet and exhaust cam
  127. mk2 astra rear brake probs
  128. saab live mapping
  129. fpr on v6 removal
  130. C20let removing air con problem...
  131. 1.6 8v z16se fault codes
  132. Vectra z19dth over boosting / boosting at idle
  133. C20LET woes
  134. 2001 1.8 16v code 1555
  135. X16xe and c16xe how similar?
  136. Difference C16XE engine and X16XE
  137. C20LET lambda spacer?
  138. Alternators: Replace 110? with 100A?
  139. Corsa B Running Hot
  140. Gen me up on Saab engine in MK3 Astra
  141. Corsa B 1.2i revs staying high in gear changes, erratic idle, help needed please
  142. Should an Integra gearbox sound like this?
  143. c20let cutting out when hot.
  144. Will this work.... Turbo Swap from 2002 Astra to Calibra
  145. C20LET FORGED TIGRA help needed in Manchester/Stockport
  146. C20LET Rebuild parts.
  147. Astra GSI Blown Turbo
  148. C20ne rebuild/uprated parts?
  149. X18XE in Mk3 Astravan
  150. Z12XE Snapped Exhaust Camshaft, few questions
  151. F20 Box help
  152. Modded C20XE - gearbox help
  153. gt28 fitted to z20let
  154. Corsa C 1.4 Warning Lights Query
  155. Which C20xe?
  156. how to get more power from a c14se on standard injection?
  157. omega low revs, lumpy running
  158. anybody running phase3 on a c20let
  159. Question about negative pole wiring, Mk3 Cav
  160. X18xe1 vs x16xe... Long shot comparison.
  161. anyone with C20LET inlet on XE?
  162. Sluggish Astra 1.9 CDTi
  163. Adjusting a FPR on C20LET...
  164. How do solenoid valves work? P0400 fault on Y20DTH Zafira
  165. oil filter coming slack?
  166. 3.0 v6 block querry
  167. Astra Coupe 2.2 Fault code P0378, won't start
  168. 2008 cdti 6 speed gearbox whine, diff bearings?
  169. 1.6 Flywheel options
  170. oil in sparks plugs
  171. Z20LET Power Mods
  172. clutch kit for f18 gearbox?
  173. C20LET piston damage
  174. c20let no spark
  175. Cam Differences X18XE1 (Vectra 1999 1.8)
  176. Anyone running an f28 2wd.......
  177. Astra gsi mk4 potential mods
  178. 2.4l/2.3l hybrid build does it work? Does it rev?
  179. z16se camshaft
  180. Couple of c20xe questions!
  181. Power loss after head gasket changed
  182. C20xe corsa not starting
  183. C20XE with Mahle 86P pistons.
  184. help with kent cams c20xe
  185. F28 inner CV Q
  186. C20LET Cordsa B rad fans not working
  187. [INQUIRY] What oil do you use for your c20let?
  188. Oil light corsa b c20let
  189. am back with a problem lol
  190. Oil pressure xe
  191. X16xe manifold
  192. xe inlet cam in let
  193. arp stud and nut kit thread?
  194. zafira gsi jerky and flat spot adive needed
  195. gearbox help
  196. MK3 astra fuel problem.
  197. Engine full of Water
  198. Engine a little tappety
  199. Let help!
  200. anyone any good at using winols to label my maps
  201. ZLET Issues stalling rough idle
  202. vauxhall/C20LET Parts
  203. c20xe ecu's will this work?
  204. C20xe Help!
  205. C20let boost fault
  206. f18 on c20let
  207. c20let head sunk in between com. chambers?!
  208. Oil in inlet manifold
  209. General help please
  210. Zafira 1.8 2002 - 02
  211. op com live data is my car fooped?
  212. noob gearbox question
  213. Corsa b 1.2 16v cutting out
  214. Can I reuse a ZLET metal head gasket?
  215. zafira gsi smoking like in a bond film
  216. c20xe crank in z20let
  217. z18xe Corsa C. Diagnosis please!
  218. help finding bolt size x20xev
  219. Help identifying hose on C20NE
  220. running problems
  221. F20 Gearbox help please
  222. C20XE spark plugs
  223. where can i get a lower round tooth let pulley made
  224. Rebuild or Not? X20XEV
  225. help needed how to remove track rod end from the leg on a mk3
  226. C20LET with X20LET Oil Pump
  227. Mk4 Astra Van Low Pressure Turbo Trouble Codes Help
  228. C20let big end bearings anyone got 0.25 and 0.5 they can sell??
  229. Where to get a gearbox urgently?
  230. toyo t4 turbo any good?
  231. C20xe which is best early engines or late engines?
  232. C20let with gt2871 cut out
  233. 1.6 8V 03 reg Astra coolant light
  234. help needed with c20let turbo
  235. c20xe head gasket advice ??
  236. Run Astra without Air Condensor radiator
  237. Astra mk 4 1.7 dt gm engine van not starting
  238. corsa v6 exhaust
  239. were to run boost pipes on a mk3 astra let
  240. 2003 1.6 8V engine running problem
  241. Corsa C Knocking/Grinding sound
  242. is it possible to buy a round tooth cambelt pulley for a 2.0 xer crank
  243. engine conversion
  244. Help...transmission c20ne on a Corsa/nova A
  245. Mk3 Astra not starting
  246. is there a specific engine number sequence for e16se and c 16se engines
  247. C20NE turbo mixture adjustment
  248. x16xe with powerbox - spark plug type?
  249. Is this peco backbox for a corsa b?
  250. 20 seh/ v6 throttle body
