- LET shafts vs XE shafts
- coscast?
- Haleluiah! Idling sorted - what's this pipe for/TPS position?
- 8x18 - 5x110 - et35.......
- Pictures of 2 litre corsa engine bays please.
- Radiator fans staying on after engine is switched off...
- velos pusle inlet
- LET stuttering!
- Drive shaft problem
- F18 vs F20 gearbox?????
- uprated head gasket
- Hammerite spray can or paint on..
- conversion finish
- X20XEV and nitrous?
- x25xe & c25xe, same ecu???
- V6 exhaust mani, built in cat????
- C25XE vs X25XE ECU's
- help c20xe won't start
- Creamy substance in breather hose
- Gearbox Bolt thing...
- astra gsi won't start
- calibra turbo calipers
- Crankshaft
- first time nova xe
- xe help
- let head problem
- Engine mounts for LET
- help - Fuel pipes
- throttle boddies !!! questions
- fault 93 + 94 on early xe???
- valve stem seals on LET
- Cam sensor mod (ecotec obviously)
- Corsa 1.0 12v To XE engine, wiring question?
- external wastegate for let
- nova engine swap?
- 2l 16v /v6 exhaust the same
- V6 and Turbo driveshafts
- injectors cleaned-now won't start!C20LET
- Oil Cooler Fitment Help
- Oil Cooler Needed Urgently!
- Cambelt
- Oil question (ok, its an Esc*rt)
- How do I let a turbo cool down??
- e.d.s phase 3 in a 2.0 let nova
- 1.4 16v
- Fuel Cut Off
- intercooler question?
- modded linkage HELP!,c20xe in corsa :)
- Unichip
- xe cam pulleys same as let?
- XE/LET firing sequence
- Engine management light help please!!!!!!!!
- Quaife ATB LSD - F20
- Is A New Cam Worth It?
- decating my mk3
- Where to lighten the X16XE small block?
- Need Help With Engine Upgrade
- engine management light
- dump valve non turbo
- engine number rubbed off?
- are all 2.0 8v afm's the same
- astra c20let wont rev past 5000
- C20XE Corsa Fuel Problems
- Vehicle speed sensor on a X16XE in a Nova
- sump plug!!
- Astra Diesel Cold Start
- Advice on Starter Motor
- setting up the c20 let on the rollers
- Ecotec help please lads.
- phase 3?
- Stick This One in Your Think Pipe: Starter Won't Spin
- c20 let piston rings
- Did a compression test
- Sports Cat any good?
- xe tickover problems!!!!
- What Simptoms would a Bust Inlet Manifold Gasket Give On A C20LET?
- Spark Plug recommendation plz (C20LET)
- Fitted Phase 2 And Now Car Wont Start?!
- dump valve for astra coupe
- cam in a 1.4 8 valve sri corsa
- Back box Or De-Cat?
- Engine Management Light!
- intercoolers
- Flywheel question!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Where is the Oil Pressure sensor
- drive shafts
- How heavy is the XE with F20 attached.?
- XE diementions?
- phase chip etc
- 1.8 16v mk4 sport, NO POWER
- Best induction kit to get?? help please!!!!
- Quick driveshaft Q
- F20 on C20LET????
- let piston sizes
- Redtop or ecotec turbo?
- is this gearbox ok?
- LET ECU question????
- let wiring loom help
- nearly finished conversion
- nova xe mounts
- taken engine loom out help need in astra gte mk 2
- LET ECU standard chips???
- turbo actuator
- Lambda on C20LET
- C20XE Dizzyless Lambda Sensor
- Coscast Head
- cav front camber
- Calibra induction issues
- 3.5 phase spring
- Oil? In here?...
- Daewoo Boxes have LSD?
- new engine management?
- calibra 4x4 back firing?
- calibra fuel pump
- where to take my car??
- nova xe recomended springs
- nova redtop oil cooler
- Oil Everwhere???!!! HELP!
- will i beat rs turbos?
- c20let ideling bad
- What mount and linkage is this?? (PHOTO)
- Corsa B C20xe
- ** Fitting 1.4 16v into 1.2 8v Corsa
- XE Wiring info needed please...
- LET exhaust - RS Turbo!!!!!
- Age of C20LET
- which induction kit??breather mod?
- Nova Engine Conversions
- engine management
- 20 XE wiring loom .
- oil restrictor in block !!!
- LET gear linkages
- Oil leak...help.
- Help! Bit clueless about gearbox
- c20 xe loom ecu swaps
- boost cut on let
- Exhaust Manifold problems AGAIN!
- Fuel pressure reg question
- poor fuel consumption
- pushing a clutch to its limits
- GSI backbox onto an 1800 sport!!
- How long do OE exhausts last?
- Lambda postion on a turbo?
- XEV lightened flywheel
- How to get quicker throttle response??
- calibra non starter
- Help! Let down by Haynes manual, gearbox removal question
- C20LET Lamdba Sensor Question?
- engine
- 4-2-1 manifold for an ecotech 2l 16v
- exup style valve in let
- Boost cut / judder
- how much bhp from ditching the cat
- Exhaust Preferences
- ecotec cams.....
- xe conversion plz help
- driveshafts, cv's and bearings???
- Nova engine conversion help
- 4x4 transfer boxes
- Dump Valve moving?
- LET Exhaust
- intercooler on a non-turbo'd motor??
- c20xe info
- wot is my engine
- head bolt torques, x14xe
- 1.4 merit astra power and overheating
- Buying a turbo, what to look for?
- what airbox to use on xe'd corsa b
- 4x4 pas and a rubbing noise from front
- Engine differences?
- calibra turbo with flat spots
- head gasket kit, any other parts needed?
- Will nova GTE drive shafts fit SR hubs?
- cambelt change on 18xe 16v
- Are the electronic guts of the XE and LET AFM the same?
- misfire on my xe...
- Corsa C 1.3 CDTI - whining noise?
- 20XE Data Link - Live Readings??
- LSD ,Do Vaux Box's Have Them ?
- is the XE starter the same as the LET? Urgent!
- Can you estimate a cambelts age by looking at it????
- Emissions on throttle bodies
- Crank shaft size
- 1.4 Si engine
- Whats the normal operating temperature of a 1.6 Vectra
- Z20LET or C20LET
- calibra fuel pump relay
- Sealant for oil baffle in cam cover?
- turbo
- Ram Induction Lexmal on Corsa B
- No EML on calibra 16v wont start
- People in the know about XE's please read!
- Recommendations for turbo unit repair on Astra coupe
- TXB Operation
- Overheating in Cavalier X20XEV
- Help me Identify my car
- Fitting T3 Turbo to Astra GSi
- Cavalier engine mounts.
- Location of temperature sensor on astra mk3
- location of speed sensor
- No clutch..
- dump valve on diesel
- C20XE to C20LET?
- Exhaust
- gear linkage
- LET exhaust system
- V6 Carbs/TB's
- Holding crankshaft pulley
- blanking off unused LET dissy
- New tappets
- C20ne Timing belt tension
- used cams
- Difference between a E16SE and C16SE?
- re-programming cally trip comp
- Engine Conversation, advice needed
- power steering qu
- oil pump on astra 1.7td van
- cav turbo exhaust
- Nova XE ecu loom wire
- Cav Gsi Engine/loom Swap
- LET rebuild
- cav let problem
- where can i get a power boost valve
- 5th gear whine, gbox oil leak
- power estimation please
- Astra GSI 4X4 Turbo Possible??
- XE high idle
- fuel pump
- Some Velo's Queries on mapping?
- red uni chip
- F13 CR gearbox
- building loom for dta p8pro (pics)
- a new problem LET thread from me to piss you all off
- Option for 2nd Dizzy on XE/LET?
- corsa 1.7 diesel glow plugs
- xe corsa rev counter
- calibra fan belt broken, now not starting
- Engine hesitating
- X25XE Oil capacity?
- Faulty injector.
- fueling on xe nova???
- High Oil Pressure - XE ?
- standard LET injectors
- Checking an EGR valve
- opel vectra 1.6 '03
- Noisy exhaust???
- injectors 2
- C20XE compression test results (high?)
- cav turbo clunking sound
- Rev Counter not working --- Calibra Turbo
