: Engines and Transmission
  1. Astra gsi c20xe idle problem
  2. fuel flow damper cavalier gsi
  3. Fuel pressure regulator ?
  4. V6 Omega Hesitant/Slow + EML
  5. Going dizziless on let what do i need
  6. knocking noise form poss inner cv?
  7. nova 1.4 16v carb setup
  8. Corsa C20XE?
  9. Z20Let piston advice
  10. My Problems this week!!
  11. c20xe wont rev
  12. astra mk3 gsi c20xe rough idle
  13. fuel rail earths..
  14. difference between f10 and f13 5 speed gearbox
  15. bottom end 16xe
  16. A move to 5/40 to quieten noisy lifters?
  17. mk4 astra 1.6 twinport (z16xep) cam cap order/torque
  18. C20XE smoking on gearchange?
  19. astra battery
  20. Arp bolts on steel rods
  21. wastegate
  22. C20LET T3 power
  23. C20xe won't start
  24. Corsa 1.5TD(isuzu) wont start from first
  25. Ext fuel pump distance
  26. c20xe corsa gsi non start
  27. How easy is it to make an exhaust for my c20let corsa?
  28. c20let ... fuel but no spark
  29. fueling injectors chips
  30. 20xe noise
  31. C2OLET Main bearing bolts
  32. C20let no spark no fuel, Trying to run with out car loom.. help
  33. 1.6 petrol turbo corsa 08 plate
  34. oversized shells
  35. Corsa 1.4 16v turbo.
  36. HELP - removing lower pulley... locking fly wheel? MK3 ASTRA 1.4
  37. C20let does anyone know this engine?
  38. compression ratios ??
  39. C20let Water Pump Fitting
  40. C20LET 1.3 or 1.9 Cometic - Help needed please!!
  41. Help with a fault code please?
  42. Astra OPC cams
  43. 1st & 2nd Gears hard to engage Mk4 Astra GSi
  44. x18x1e Astra mk 4 hydrolic clutch
  45. c20let non-starter
  46. Red top c20xe RWD Gearbox options
  47. help with gearbox
  48. where can i get a longer power steering pipe
  49. 1.3 nova engine turns over but wont start
  50. X20xev fitted into a frontera?
  51. vxr injectors in my z20let
  52. C20LET Cam pulley timing marks
  53. cav 2.5 v6 to a tigra
  54. Calibra V6 auxiliary belt hellp please
  55. Have I Fooked My Piston
  56. Anyone got diag of LET fuel lines and flow direction?
  57. Thinking of engine change
  58. c20let uprated map sensor, where from??
  59. inlet mani foe 20xev
  60. f28 help and suggestions
  61. Vauxhall Movano running issues Help!
  62. X12XE Oil light comes on when hot???
  63. F20 final drive swap
  64. C20LET Piston and Conrod Advice Needed Please
  65. my car does not feel fast
  66. f23 gearbox compatability?
  67. KMS engine management advice needed please (for XE/LET)
  68. corsa gsi brake problem
  69. speedo trouble redtop corsa
  70. 68mm throttle body for C20LET
  71. C25XE *Potential Issue*
  72. what size ports on an XE head?
  73. C20let inlet manifold bhp
  74. hybrid turbo
  75. spluttery on boost
  76. water pipes
  77. astra 2.0 di intercooler or not
  78. Tubular manifolds for turbo's
  79. Corsa GSI clutch advice
  80. Please help, gear box probs
  81. Anybody Fitted SBD ITBs To A MK3 Astra?
  82. C20LET Wide Belt Alternator
  83. my car keeps back firing
  84. superchips phase 1 question
  85. will any parts off a c20xe fit the x20xev engine?
  86. 2.0xe head porting
  87. Anyone got a diagram of v-belt set up on late LET?
  88. XE Jenvey TB's... which manifold to clear Calibra master cylinder?
  89. Vectra 2.2 fuel economy
  90. DPF on Zafira z19dth regen issue
  91. Big block conversion, cv joint question
  92. engine gone bang
  93. c20 xe coil on plug?
  94. mk3 1.7 isuzu zafira
  95. which walbro needed?
  96. fitting chips in ecu, where does fuel one go and boost?
  97. MK4 Astra - Fuel consuption
  98. strange EML light problem mk3 astra LET
  99. help needed-Z18xe conversion
  100. What size Boost pipes
  101. 350bhp help help
  102. little boost until 4000rpm
  103. Corsa 1.2 (X12SZ) Intermittent starting fault.
  104. what engine for carbs? small block
  105. z16xep (scratches on liners) too far gone ??
  106. o2 sensor from narrow to wide band
  107. o2 sensor from narrow to wide band
  108. Astra Mk3 1.4 8v Merit!?
  109. c20xe gearbox fitment
  110. Let Phase 2 Shopping List..
  111. Zlet oil Pump Cooler Bolts?
  112. Bleed valve for 1.5td
  113. Tigra 1.6 lack of power after head swap
  114. which filter? itb c20xe
  115. c25xe V6 wiring problems.
  116. vectra gsi steering wheel wobble
  117. f16 box speedo not working
  118. My car keeps cutting out !!!!!11ONE
  119. Where can i bulk buy oil filters?
  120. WHat pistons to use
  121. Need help my engine keeps cutting out
  122. c20xe dbilas throttle bodies
  123. CALIBRA 4x4 REAR DIFF LSD?
  124. will zafira driveshafts fit astra
  125. which fuel pressure regulator for c20let??
  126. Tech info needed x12xe and z12xe camshafts
  127. connecting hoses for wastegate/turbo
  128. Urgent help needed c20let holding back!!!
  129. v6 + f20
  130. Oil or some sort of liquid on xe manifold?
  131. What Clutch for C20LET Van with F20?
  132. c20xe ks700 head how much hp
  133. Early C20XE Diagnostics??
  134. Vectra C 3.2 Auto Elite Fault Codes
  135. Z18XE gearbox conundrum!
  136. Replacing corsa b front bearing?
  137. steel water pipe for let
  138. how to wire ecu
  139. Short stroke crankshaft options - C20XE
  140. C20xe short con rods
  141. programmable ecu c20 let package
  142. priming fuel on an astra 1.7td
  143. lead positions on dizzy
  144. c20let uprated oil pressure relief valve
  145. help clutch needed for my z20let f23 good for 400 plus lbft
  146. oil pressure sender
  147. Play in vxr turbo
  148. Whats the differences between Elec/Mech F28 box?
  149. Techies please - omex 600 Full throttle gearshift C20xe
  150. C20LET Penny valve
  151. Anyone know about vw tdi engines? HELP
  152. Vectra B V6 Using Oil
  153. phase 3.5 and low compression pistons is it ok
  154. corsa 1.2 8v air flow problems i think :/
  155. WANTED... astra turbo driveshafts
  156. 1.2 for 1.4 Engine Swap What Parts Are Needed To Change?
  157. c20xe corsa not running
  158. c20let cylinder head repairs
  159. Pinion gear?
  160. Corsa B 1998 1.0 12v x10xe
  161. 20NE turbo..... oil feed reducer needed??
  162. who has my old engine now?
  163. gb13 suzuki swift gti engine (nova)
  164. Hi, My Corsa c 1.7DI heater's dont seem to getting hot...HELP?!?
  165. C20let core plug sizes
  166. xe inlet mani early/late question
  167. corsa 1.6 sport and gsi shafts.
  168. what clutch and flywheel???
  169. zlet oil cooler to clet block pipe help
  170. Whats the most powerful cav/cally turbo in UK?
  171. C20XE 2.8 Corsa Stopped Running
  172. vxr injectors on 1.6 16V corsa
  173. c20xe crank sensor
  174. corsa gsi
  175. astra gear box
  176. astra gear box
  177. vmax evo 6
  178. mk4 astra help
  179. Anybody got c16se low compression pistons ??
  180. Camshaft help 20XE
  181. Corsa B 1.6 8v turbo 160BHP! NEED NEW HEADGASKET
  182. Are the txautosport alloy rads any good??
  183. What bhp should the xe exhaust cam be fitted
  184. 1.8 16v ecotec engine vectra sri 130
  185. phase chip sets
  186. z18xe air filter
  187. Mk4 Astra 2.2 16v lumpy idle/possible missfire...
  188. arp big end torque settings xe in nm
  189. 93' Cavalier Redtop Tuning
  190. mk4 saab conversion?
  191. C20LET starting problem
  192. ZLET pump gasket
  193. fuel leak from fuel rail
  194. z20let & x20xev same bolts?
  195. Z20LET tuning advice
  196. c20xe chips question?
  197. Did the design of the c20xe manifold change over the years?
  198. Inlet manifold
  199. 2.0 corsa shafts/cv joint and hub question
  200. Is the f18 a straight fit to a 20seh??
  201. bleeding the cooling system on a 2.0 8v
  202. need help flat spot on c20xe please help!
  203. C20xe Starter problems
  204. Best plugs for 2.0xe?
  205. What the 2.8 V6 turbo engine like ?
  206. ecotec to red top swap over
  207. corsa 1.6 16v engine type help?
  208. 3ltr twin turbo omega
  209. decent clutch? ideas
  210. which carbs to use on c20xe
  211. c20xe conversion in a mk4 astra
  212. boost issue
  213. Fitting 2.0dti to 1.7dti astra/van
  214. C20let bhp help
  215. fuel hose
  216. Where does back big rocker cover breather go?
  217. c20ne equal length shaft?
  218. Oil in throttle body X16XEL
  219. vauxhall cavalier sri non start
  220. corsa 1.6 16v uprated cams bhp?
  221. c20let standard plug gap ??
  222. what turbo and manifold for c20let
  223. Rebuilt kit for turbo
  224. corsa c not starting and ecu light on
  225. Driveshafts for a C20LET corsa.
  226. Z18XE won't separate from F18 gearbox
  227. throttle body advice
  228. Nova, Astra or Cav 20NE RON plug pic needed
  229. vectra gsi clutch and flywheel
  230. gear linkage, quickshift, nylon bushes HELP
  231. mk4 astra sport fuel return??
  232. Can you help me choose bigger turbo please, 1.7 isuzu td
  233. firing order... 1342 from the top of dizzy to bottom?
  234. Y20DTL EGR Cleaning
  235. causes of XE overfueling?
  236. what ebay downpipe for calibra turbo?
  237. corsa c20xe
  238. c20let, saab red or VXR injectors??
  239. Would you reuse this cometic gasket?
  240. Increasing C20LET BHP
  241. valve guides?
  242. astra f ecotec running problem
  243. 2002 coupe turbo engine
  244. 2.0 XE ENGINE Airbox v Cone filter
  245. 2.0xe tunning chip,fuel oressure reg or both?
  246. 2.0xe 4 branch-e bay-any good/has anyone purchased one?
  247. Powercap for 2.0xe-Is it worth changing?
  248. 2.0 xe cream and blue injectors-max power capability?
  249. F28 speedo drive
  250. corsa fuel pump
