: Engines and Transmission
  1. red top oil cooler
  2. Xe gear box or 1.3 gearbox
  3. porous head mod
  4. is a c20xe sri cav suposed 2 prime fule pump?
  5. High powered let fueling...
  6. in tank pump pipe
  7. turbo will it take nos
  8. which is best (engine management question)
  9. [b]need More Power[/b]
  10. Engine management light wont go out!
  11. Clutch!!
  12. Sump Still Leaking Help!!!!!!!!
  13. injector fitting
  14. 1.7TD isuzu lump into 1.0 Nova..
  15. Cav Turbo Ecu + 4x4 light trouble! Flashing 4x4
  16. Exhaust opinions please
  17. Cleaning air filter
  18. corsa c20xe wiring
  19. power dies at start off
  20. xe loom on let ecu
  21. Front engine mount on LET
  22. X16XEL headbolts
  23. putting an extra Cat On
  24. strange whirring noise from ns hub/brakes gte valver
  25. nova head toque setting and angles
  26. Outer gear in blueprinted oil pump
  27. Randomly smoking c20let
  28. Reverse
  29. Toad Ai606 headlight operation
  30. Step by step guide to fitting FMIC's??
  31. XE idle.......grrrrrrrrr
  32. c20xe conversion
  33. c20xe electrical help
  34. C18XE Problems
  35. c20let big breather pipe blowing off under load?
  36. What do you make of this LET tuning advice?
  37. auxilary belt on c25xe
  38. Diesel LowBlow to Isuzu
  39. 120 amp let alternator, what size battery?
  40. c20let big bteather to turbo pipe blowing off
  41. TRIP computer into ecotec calibra
  42. LET Owners/Astra LET Owners
  43. corsa c dash into a nova?
  44. wat brake servo pipe to use on a nova xe?
  45. c20let wngine fault code 94 and 42
  46. Excessive rear camber on Vectra 1.6 LS saloon
  47. Cavalier Turbo's
  48. should i use a oil cooler??
  49. what gearbox?
  50. C20XE Flywheel removing, box on or off ?
  51. vectra oil light
  52. nova xe connectors?
  53. vectra v6/cav gsi drive shaft
  54. Astra fuel injectors
  55. where to get c20let ecu fault codes
  56. MK4 Astra coupe turbo
  57. Nova 1.2 timing point on idle
  58. 1.6 16v XE tuning.
  59. fuel pump not priming...
  60. help on buying a corsa diesel
  61. Turbo Dials for 1992 calibra turbo
  62. c20let problems
  63. quaiffe atb lsd, gearbox noise
  64. sump gasket gone help needed asap
  65. turbo - code 31 - fault or not?
  66. xe nova bump steer !
  67. C20xe Exhaust
  68. corsa 20xe strutbrace
  69. LET and XE are they the same..........
  70. Cheapest Place To Buy A Performance Inlet Manifold For The X16XE (Corsa B)
  71. FK Coil overs
  72. eco tech cams into c20xe?
  73. vauxhalls engine parts pic wanted
  74. vacuum pipe x16xel
  75. nova xe tickover probs??
  76. Astra 53 reg 1.6
  77. Vectra 1.8 16V Club 2000
  78. Turbocharger questions...
  79. Starter/alternator
  80. Coscast heads porous?
  81. Changing a xe head
  82. TBs and Turbo
  83. corsa 1.2 cutting out
  84. 1.6 Astra Automatic
  85. c20let doesn“t want to stop
  86. Dbilas manifold onto astra x14xe
  87. Omega gearbox
  88. C18XE Starting probs
  89. UniChip - Phone Numbers Of Dealers/Remappers/Fitters???
  90. AVO Coilovers
  91. c20xe conversion
  92. Intercooler tech questions
  93. remote starter
  94. Zafira question: BMC CDA and coilover kits
  95. Oil Change
  96. Fuel pressure Gauges
  97. corsa sport x16xe into nova gsi
  98. Resonance On a Corsa 1.4 8v SRi ?
  99. Need More Power
  100. LET inlet manifold
  101. What do pipercross cone filters sound like on a std astra with xe??
  102. what car and how fast have you got out of it.
  103. xe van
  104. help needed to do head gasket
  105. de cat v6 gsi will it
  106. Brake Sensor Valve
  107. 1999 astra sport 1.8 16v?
  108. Coil over kits
  109. what c/r for 400bhp
  110. Looking For Local MIGWEBBER To Do An Engine Conversion For Cash.
  111. V6 Enlarged Throttle Body
  112. DTA basemap for 20XE
  113. whinnin type of noise from my engine
  114. Adjusting Spark plug on N/A tuned engines
  115. its a vauxhall...honest (1.6 16v twincam)
  116. Radiator Drainage plug.
  117. LET corsa holding back
  118. how do I check my fuel rail earth ?
  119. Astra GSi mk3 FMIC 'Hoses'??
  120. Engine wont start - Help
  121. XE Conversion... NO FUEL!?!
  122. xe question
  123. More power / torque (Omega) ??
  124. How to fit FMIC
  125. Temporary FMIC pipework connectors! Urgent!
  126. Power Steering on XE Conversion
  127. Nova XE - Rad's
  128. cavvy v6 engine wiring
  129. fuel aconomy
  130. Which Gearbox fits a X Reg Astra 1.8 SXI
  131. Any mobile mechanics in london? Clutch change
  132. turbo help
  133. Ported and polished head
  134. EDS Phase II problems---> need a FMU
  135. can audi fd5por plugs be used with nitrous
  136. need more power
  137. Nova XE Bottom pulley Q?
  138. turbo fuel tank sender orientation
  139. V6 engine onto F20
  140. What plugs and oil for Phase 3 LET
  141. AP racing organic clutch with billet steel flywheel
  142. Phase 2 Let people
  143. Nova engine mounts
  144. xe corsa help.
  145. £250 for recon turbo
  146. ICV located on a Corsa B 14 v16?
  147. Fuel Consumption
  148. nitous fueling???????
  149. rattling ecotec ideas please
  150. 1.8 Engine Urgent Help (Z18XE)
  151. induction kit in the air box?
  152. Astra 1.7td (Isuzu) torque settings and valve clearences please??????
  153. astra coupe decat pipe
  154. When To Use An FSE Adjustable Fuel Pressure Regulator?!?
  155. paddle clutch
  156. v6 tc light no power (calibra 1994)
  157. best air filter
  158. z18xe gurus
  159. More XE problems
  160. power part 2
  161. xe nova running lumpy
  162. camshaft lug-bugger!
  163. please help please help i need power and sum1 must know!
  164. 1600 ecotec VS 1600xe
  165. V6 - Poor Fuel Efficiency, Popping Noise on Start Up
  166. C20 LET loom identification
  167. F20 on TD Cav ??
  168. over fuelling running a let engine in
  169. 264 deg CAM
  170. engine conversion
  171. fuel tank question
  172. water injection
  173. corsa 2ltr xe converion ?'s
  174. XE Nova - Not starting
  175. Small block head for twin 40's
  176. Clutch stiff when hot - let
  177. afm????
  178. Engine cover
  179. Setting the timing after a belt change
  180. pic of starter
  181. Boost Gauge
  182. C20LET Diagram.
  183. C20LET cutting off boost when hot
  184. Engine mount replacement
  185. Stripping my XE nova, RIGHT NOW!
  186. Is always restricts of the incoming air bad? venturi effect
  187. z20 injectors-c20let
  188. C16XE/MBE Rev counter???
  189. 1600 ecotec VS 1600xe
  190. dizzy/motronic?
  191. Injectors very tight fit!
  192. How hard is it too put a 2.0 ecotec into a MK3 estate?
  193. Corsa SXi 1.2 Bottom ends..
  194. New Hub for Corsa B C20XE
  195. Nove Gsi With 2.0 Throttle Body
  196. rev limit on stockish head...?
  197. small block T40 Alt adjuster
  198. c 20xe
  199. what throttle cable 2 use on a xe nova?
  200. fully adjustable coilovers
  201. c20xe hitting limiter
  202. Omega Exhaust Front pipe no cat
  203. astra gsi let linkage please help
  204. Fuel pressure
  205. C16XEL Cutting out/stalling
  206. GTE 16V runs poorly at constant throttle
  207. Lightened flywheel or lighten flywheel
  208. Clutch from vaux/wallace
  209. Found in Leeds scrappy - V6 Cav
  210. Cali Turbo Rev counter
  211. Corsa B with Let brakes??
  212. engine mounts. astra mk2
  213. astra XE conversion
  214. Is my engine dying?!
  215. Blue smoke on overun and light throttle LET
  216. New astra VXR 240 Gearbox, and the F20/F28
  217. calibra wont start
  218. High Oil Pressure 2.0 8v
  219. distributor problem (let)
  220. HELP PLEASE head bolts
  221. Is There A Difference Between The Heads Of The X14XE & X16XE???
  222. gear ratio's for boxes!
  223. 2.0 or 1.8????
  224. Hello, iv just bought an unfinished corsa 2.0 turbo
  225. z18xe fueling - engine swap
  226. MK3 Astra GSi Cat
  227. engine mounts - 16xe into nova
  228. ECU Remaps & Turbo problem
  229. Bosch ECU Help - Location of maps?
  230. 2ltr Ecotec coil pack
  231. Better Boost control ??
  232. kkk turbo question?
  233. Do I have correct Loom?
  234. Fuel sender problems
  235. Mk 3 Astra Coilovers
  236. c20let gear linkage in astra gsi
  237. where can i get a service kit for my gsi corsa inc belts on the net-cheap ?
  238. Vacuums on C20LET Astra GSi
  239. c16se wiring in a mini , help
  240. What Head Can I use on a 1360 nova engine
  241. C20XE/LET Head Flow Bench rates ?
  242. Specific Cams needed for GT35R........
  243. Where Do I Find The MAP Sensor???
  244. Airbox > Induction Kit
  245. Which is best for manifolds? Janspeed or Sportex?
  246. gsi air con
  247. Full Service on a C16XE?
  248. engine management light
  249. F28 gbox parts
  250. LET rebuild parts
