- Vectra B 2.0 16v - Rev limiter at 4k
- c20xe flywheel vs c20let
- Corsa engine conversion
- LET Oil sender fitting point (adaptor needed)
- modified c20let or turbo an xe?
- Can you fit nylon gear linkage bushes to a Vec B?
- Car overheating when revving but not when idling.
- Quick retarded question :D c20let corsa coolant pipes
- c20let ecu help
- C20XE - Corsa - New fuel pump needed?
- let missfire on boost
- HELP! Zafira 1.8 not idling right and seems to be back firing out of injectors :/
- Engine Code Question
- F20 Onto C16XE
- battery relocation corsa c20let
- How much isit to get let head
- C20xe coscast head water channel
- C20XE Rebuild - No History - Help Required
- C20XE - Starter Problems
- C20LET - Missfire on morning start up
- supra turbo engine (1jz) into carlton......who has done this?
- X16XE
- c20xe clean up
- C20XE - Service\Injector removal
- C20XE Corsa speedo - Not working
- Oil Cooler Pipe Length, Is This Too Long?
- Can anyone please tell me what this is (c20xe block)
- mk2 astra gte engine problems
- C20LET - More power needed
- will a mk4 astra ecu work on my mk3 (same engine code)
- 1.3sr onto a 1400 bottom end will it fit
- best oil to use in fresh rebuilt c20xe?
- f28 gear oil, whats best to use?
- C20LET - Torquing crank bolt
- Management light comes on
- Nova 1.3SR head on a 1.4 Bottom end?
- 2001 Vectra B 1.8 - Loss of power
- 630cc injectors for c20let????
- ecotec adaptor plate? andpower steering on c20xe corsa sport
- Corsa B - Quickrack question
- Redtop revs sticking on
- Astra G 2.0 16v Limp Home mode. Help
- need help on 1.6 cams?
- zafira gsi
- Vauxhall diesel engines whats good?
- calibra firing problem
- 1998 astra mk4 engine loom querie????
- 53 Zafira Z20LET TURBO BLOWN!!
- Getting water out of the oil.
- X25XE Butterflies
- Engine Rebore C16XE
- c16xe problem help please
- compresion on xe turbo
- C16xe lamba sensor? Helpp
- Does the z16se have both a crank and cam sensor???
- Help with fault codes. Just done HG. 51plate 1.8 Zafira Auto.
- best engine to put in mk3 astra and best things to buy for them??
- z16se poor running when warm
- pin test
- Astra mk4 Diesle van 2006, what geabox?
- Manta Big Wing Sump On C20LET ADVISE NEED!!
- T40 nightmare
- are c25xe a bad engine or have i go a bad one
- c20let eds phase 1, what boost does it run?
- Will this de-cat manifold fit?
- Corsa Immobiliser Problem After engine Change
- Innovate lc-1
- cam identification
- Fuel pump issue (Nova C20LET)
- C20Xe corsa paper clip test
- Astra 2.2 z22se
- z20leh turbo bearing upgrade
- Corsa GSi driveshafts - Please Help
- Thoughts on this AFR reading
- x16xe fuel system problem
- 1.0 12v conversion
- corsa 1.4 16 valve,r reg head will a 1.6 astra head fit both are 16 valvers
- Help- car wont start
- x14xe corsa b sri struggling to start
- C20let Engine I have a question
- redtop air flow meter. HELP
- need help with my rev counter
- Drive shafts f28
- most power from c20xe
- 1.8se engine to f23 gearbox ?
- 1400 nova what is the most reliable power i can hope to achive
- X16xe inlet manifold on c16xe?
- inner c.v joint mk3 astra van c20let
- closed
- Z18XE cams etc
- 1.4 16v into a 1.2 8v
- turbo my 1.6 corsa?? help
- wideband how far down can i fit the sensor
- twin 40 delorto's on 1.3sr
- X16SZR running bike carbs - info needed please?
- c20xe problems
- C20xe dastek unichip
- Calibra turbo clutch
- C20xe fasten unichip
- fitting a 8v/ecotec sump baffle to a c20xe
- 1.8 vectra b emmisions warning light
- Whats a better engine for rallying a Nova - 8v or 16v?
- Who is running a xev blocked let
- MK2 astra GTE cabby non start no power to fuel pump
- enlarged throttle body from flebay are they any good yes / no
- what fuel pressure regulator???
- x14xe injecters not opening
- Z17DTL head rebuild help
- Daewoo Lanos Vxr Engine Z20leh
- drive shaft problem on mk3 astra turbo
- Z18XE from Vectra in to Astra G - Help!
- zafira gsi white smoke
- Running in advice
- corsa f28 ball joint spacers
- Throttle bodied C20XE questions thread...
- fitting f28 help
- Z18XE head help! :( Lost collet in head!
- c20let making strange noise
- C20XE into a corsa C
- mk4 conversion
- Which oil sandwich plate do i need for cooler + gauges?
- corsa b 1.2 engine help
- Possible differential trouble, Calibra V6
- Z20LET Remaps?? anyone on here doing them in east sussex / kent ara
- What pistons in my LET?
- z18xe head flow
- c20xe metal opel dohc 16v plug cover...Whats it worth?
- x14xe exhaust cam pulley
- C20LET lower inlet manifold breather banjo
- C20XE Knock Sensor usage from cold?
- 3.2 v6 + F28 + mre into a Vectra B?
- power boost valves
- Oil feed pipe leaking....
- c20let tapping like mad
- strange boost problem.....very strange
- Rover MGF Cat ?
- c20let turbo to afm pipe on z20let
- 1.2 8v engine swap
- corsa b 1.2 8v cts location (urgent)
- Corsa XE fuel pump relay connections
- 8v sump gasket with built in baffle
- X16xe custom inlet??
- MBE manangement on a let
- Vectra b gsi facelift revving slowly and loss of power!
- Best cams for Omega 2.6
- nova gte engine starts n dies
- New Exhaust and enlarged TOPHAT Fitted on Z20let, now get a whistling noise???
- Maching an XE piston to lower CR
- Modifying a C20LET, £800/1000 available
- Vectra misfire. Ideas pls?
- semi synthetic or fully synthetic oil???
- Possible ECU problem?
- engine rebuild cost?
- Schrick cams for C20XE/LET
- 1.4 corsa sport egr vavle fault again??
- stroking a c16xe
- x14xe fault codes - any ideas guys?
- 1.5td corsa boost
- Clip on fuel filter tank side
- Sensor next the temp sensor
- x14xe custom induction pipe (cheap power box)
- corsa 1.6 sport fuel pump on a c20let will it handle 1 bar plus
- engine bore / piston advice
- mk3 astra fuel issues!!??
- How should the engine run without the air flow meter connected?
- 1.2 8v not starting?
- Anyone running omex 600???
- corsa combo 1.7 running problem
- Severe XE Misfire - Have Fuel & Spark!
- another starting problem with an xe
- X18xe1 Con Rod bolts?
- C20LET wont idle unless you rev it
- z20leh with xev cams. need advice
- F28 gearbox experts, help please...
- gear selection problems
- Let mods?
- Wideband Basic lambda readings help (R1 Carbs on XE)
- PH2 C20LET with F18: what clutch?
- can a backfire on cranking cause engine damage
- cable clutch pedal to hydraulic on calibra?
- X16XE Engine + CBR600RR Throttle Bodies
- 6 speed on v6??
- zafira cruise contol pics required please
- c20xr gsi cavalier starting and running fault
- corsa gsi problem any 1 help
- whats the firing order on a c20let with coil pack
- Cavalier V6 Fuel Pump Relay
- Vectra v6 loss of power but no eml on
- My 1.7dti
- Fuel tank vent valve
- Ford Zetec timing up - anyone done one?
- vectra v6 conversion
- Which H T Leads?
- corsa b gsi problem
- C16XE Engine Conversion
- engine change
- Cavalier V6 Fuel issue
- C20xe running problems
- C20LET / Z20LET Inlet Gasket
- bottom end rattle
- C25XE Starting Problem
- Opel corsa1.7 to 1.7dt Isuzu
- vxr cams
- c20xe refresh assistance
- Transfer box oil cooler
- Which alternator - XE?
- fault codes
- where to mount external fuel pump?
- C20let crank sprocket can you get Uprated ones?
- How much more i can get using TB's instead of Mantzel
- using wideband to setup c-let with forged pistons and steel rods with evo 5 chips
- 1.4 and 1.6 engines
- Head Swap
- saab into a mk4 astra ?
- anyone knowledgeable on the Y20DTH 2.0 DTI engine
- astra mk4 2.0 dti tuning? and diesel pump questions
- z18xe timing nightmare
- 20seh r1 carbs and megasquirt?
- weber carburetors
- Are these early or late type?
- xe inlet on let.
- does the let have a spearate ecu and starter loom
- XE oil leak, sump gasket
- Who here runs 300/350bhp on chipsets? how are u getting around the MAP sensor
- fuel tank pressurising and leaking from filler neck??????
- Can anyone tell me which F18 box I have?
- astra mk4 c20let misfires then cuts out PLEASE HELP!!!!!!
- vx manifold
- Early or late XE coscast head?
- cav 1.6 dizzy setup,to run carbs on ne/xe engines
- C20Xe cams in c20let
- Sump gasket sealing ?
- speedo trouble corsa
- speedo trouble redtop corsa NEED HELP ASAP PLEASE !!!!!!!!!!!
- c20let fault code 19
- LET Refresh
- 2.0 redtop problem
- Astra weird problem !!!!
- How to check c20let cams
- 1.2 16v corsa B sump nut socket size?
- has anyone put a saab engine in a cavalier yet
- Blue smoke
- Part number for Bosch MAP Sensor.
- HELP with hoses
- closed
- astra van running poorly after changing injectors
- slipping clutch maybe?
- Astra being sluggish
- corsa 8v problems
