: Engines and Transmission
  1. Ecotek Valve
  2. Engine coughing......
  3. Quick Mappable ECU question
  4. Used Search 5 Questions Remain About XE Corsa
  5. 2.0l 8v onto a 1.6 8v?
  6. redtop conversion
  7. changing sparkplugs n leads.
  8. Corsa B engine swap. X14XE into a 1.4 SRI 8V differences?
  9. LET higher octane rating.
  10. let runing in?
  11. head differences xe/let
  12. 1.2i and 1.3sr crankshaft
  13. Cruise Control on X14XE
  14. cam timing when taking head off
  15. doing crank sprocket bolt up !
  16. anyone know part number for 1.6 cv joints?
  17. nova sr gearbox and head questions ???
  18. HELP!! Astra & Zafira Head Lights?
  19. Help! Please! XE Probs
  20. C20 xe ecu part numbers recognition please
  21. Which Shafts... XE Conversion have used search...
  22. Diagnostic Plug Location
  23. c20xe coil
  24. mk1 golf camber bolts how do they work ?
  25. c20xe is being a nightmare
  26. Exhaust
  27. V6 into a Nova
  28. xe firing order
  29. f18 diesel gearbox
  30. Drive shaft question
  31. Helicoiling.engine.mount.holes.on.F20.gearbox...
  32. crank pully! can i get it off can i ****?
  33. X14XE Loom?
  34. f18 => f16 or f20
  35. c20xe coolant system
  36. Powercap??
  37. help changing/cleaning tappets
  38. crank oil seal
  39. LET manifold stud removal...
  40. xe corsa trouble FPR???
  41. Exhaust tone what to expect
  42. what are average 2ltr LET con-rod bhp ratings
  43. Lift or durationcauses pistons needing pocketing?
  44. Cav turbo F20 conversion, astra GTE O/S shaft is too short!
  45. Race Engine Problem
  46. enem cam spec ?
  47. power steering belt
  48. Have problem to hit 6500 in third gear
  49. Z20LET C20LET pistons?
  50. !6 valves head
  51. 1.4 SR Engine into F Reg 1.0 Litre Nova
  52. corsa revcounter on 1.0
  53. gte 16v engine number
  54. pics of frontera intercooler on a nova
  55. which cat sensor??
  56. GT 28, how much power they make?
  57. F13 gearbox problem
  58. Throttle cable xe in nova
  59. what gear box is on a 1.7 td astra mk3 van
  60. Corsa XE Misfire/Spark issue
  61. A ew questions about an engine transplant?
  62. C20xe Big Help For Noob
  63. 1.6 16v head to 1.8 eco block
  64. engine oil
  65. Cam
  66. Torque settings for head bolts c16se
  67. C20LET boost hoses dimensions?
  68. URGENT!! Nova Driveshaft question
  69. 2.0 8v block with 16v head
  70. temp sensor c20xe
  71. F28 oil leak from selector shaft!!!
  72. Turbo Replacement
  73. cambelt
  74. Does Anyone have a How 2 - Fitting A Turbo to a 2.2L Ecotec Vectra?
  75. Z20LET operating temperature
  76. Exhaust
  77. Nova Fuel Pump With XE Conversion
  78. 20SER vs 20XE rod bolts
  79. chugging c20xe
  80. Let ECU help needed
  81. 1.0 12v Fault Codes
  82. backbox
  83. Exhaust probs
  84. water pump and timing belt on XE nova
  85. is my engine a goner?
  86. bigger injectors on v6 vectra
  87. Leaking gearbox oil
  88. turbo/v6 driveshafts?
  89. Service queries on Z20LET
  90. F28 oil leak from gear selector shaft !!!
  91. Mpi Fuel pumps query? Corsa XE
  92. Rack to bulkhead bushes - calibra
  93. Advice on cambelt fitting V6
  94. c25xe into a vectra 1.8 16v
  95. Corsa 12v Engine Hesitancy
  96. f20 input shaft removal
  97. fitting an oil temp gauge, were does the sensor go?
  98. C14SE Pic required please
  99. clutch
  100. c20xe not starting
  101. C20XE MK3 Astravan (Exhaust)
  102. fmic need cleaning
  103. LET EM Light On, Won't Flash Codes??
  104. Crankshaft Position Sensor!
  105. Best Value-for Money XE induction kits?
  106. Head gasket
  107. Engine rebuild
  108. Courtenay Sport Engine Transplants?
  109. C20LET simply unpredictable ???
  110. Fuel light and engine temp questions...
  111. crank sensor 8v
  112. X16XE - Speedometer Sensor
  113. Where to get uprated engine mounts?!
  114. HELP asap Hall Effect Switch ( redtop 16v )
  115. blown water pipe?
  116. 1.4 8v to 1.6 16v conversion
  117. help with clutch choices
  118. Hot cams and vacuum drop
  119. four branch manifolds
  120. C20xe - Re-mapping
  121. Injector cleaner
  122. Anyone any advice on ecotec engine stall when hot THANKS
  123. CORSA GSi Engine questions - help me please!
  124. 1.2 8v throttle body??
  125. 1.4 corsa 8v power
  126. strut braces and wheels-corsa c20xe
  127. 1.3 rally nova breaking drive shafts
  128. F28 repair info needed
  129. driving with no backbox
  130. C20LET injector question...
  131. Engine Probs *again*
  132. Just finished taking cyl head off, a few surprises (pics)
  133. ECU Light (C20XE, Corsa, See Inside )
  134. C20let sparkplugs - Which ones??
  135. E16SE induction
  136. 2.0xe nova wireing problems
  137. XEV main girdle torque settings?
  138. head gasket
  139. Gearstick seems to pull really far back! corsa gsi
  140. C16XE Problems
  141. F28 fitting to X30XE
  142. C20LET injectors
  143. Z18XE tune probs
  144. Add up to 20bhp with this modification?? --->
  145. induction kit viper or BMC CDA
  146. c20xe air con brackets
  147. Air filter
  148. LEt no boosting properly?
  149. when you up thr bhp figure....is it noticable?
  150. My 200ts blues
  151. Engine damage
  152. Which Haynes Manual for my C25XE ???
  153. calibra turbo exhaust query, bore>.....
  154. Why won't it start (LET)??
  155. c20xe dizzyless to dizzy
  156. 2.0 8v Engine on 1.8 8v gearbox (Carlton)
  157. throttle switch
  158. Engine removal from GTE
  159. C20XE Alternator belt?
  160. What number torx socket is required for C20XE head bolts?
  161. F.A.O. chip
  162. Nova GSi Radiator engine: E16SE
  163. C'Let loom - converted to standalone ecu ??
  164. XE/cosworth fuel rails
  165. Corsa Turbo Q?
  166. Corsa XE problem (Oil light keeps coming on!)
  167. F18 or F20?
  168. XE cooling pipework diagrams needed
  169. air filter
  170. Omega 2.5 v6 Major Oil Leak
  171. da da da noise from engine
  172. power cap question
  173. Gearbox whine .
  174. Supertourer xev upgrade
  175. How much presure should be under the cam cover of a C20XE?
  176. Nova TD intercooler query
  177. Cam markings
  178. C20XE Weight
  179. Fuel pipe fittings
  180. misfire
  181. Vectra 1.8 Ecotec/LPG wont start....
  182. nova 1.3sr crankshaft damaged
  183. length of head bolts on xe??
  184. c20 let in an astra sport
  185. whats the difference between machanical fuel pump and normall one
  186. auto vectra v6 gearbox problem???
  187. Turns over....wont start!!
  188. Nova fuel tanks
  189. astra g 1.8 running a bit wierd
  190. Astra 1.6 automatic help
  191. Cav gearbox compatibility
  192. Removing Rear Axel Astra GSI how??
  193. Spark plugs
  194. something wrong with engine??? please help
  195. Fuelling - SPi to MPi
  196. Nova Gearbox Swap
  197. F18/F20 Gearbox difference??
  198. F18WR on a Corsa XE???? Hot or not??
  199. Cosworth 'Grey' injectors
  200. c20xe timing
  201. x16xe - Carbs
  202. Engine Conversation C20ne To C20xe
  203. C25XE to X25XE
  204. n00b question - redtop manifold
  205. Problem with fueling
  206. Smoke out of the exhaust
  207. corsa 2.0 16v to 2.0 16v turbo
  208. Astra GTE 16v Fuel problem
  209. Electric turbo?!?!
  210. c20xe wiring help for mk4 astra
  211. 16in Turbo wheels on Mk3 Cav hatch.
  212. Mk4 Astravan C20xe Nearly Finished !!!
  213. Rebuilding XE, NO pressure relief valve
  214. Are astra,cavva,calibre big block driveshafts the same?
  215. 20XE airflow meter.
  216. can i get an ecu chip for my corsa
  217. Newbie needs abit of help...
  218. What are supposed to be the advantages of a power cap on the xe.
  219. Urgent Help Needed ASAP (engine probs)
  220. changing tappets
  221. fuel pump questions
  222. c20xe timing
  223. how can i get realistic power gains by not spending to much
  224. is it possible to convert a clutch from cable to hydraulic ?
  225. engine tapping
  226. Bypassing the keychip immobiliser on Cavalier
  227. new astra induction kits
  228. car wont start
  229. sequential and non sequential injection??
  230. Engine Stands
  231. Manifold ordered, will my system match up ok?
  232. 1.2 to 2.0
  233. Oil spray bars on LET block
  234. V6 throttle body onto XE?
  235. engine conversion cutting out
  236. Clutch release bearing
  237. Supercharger for vauxhalls-EBAY
  238. XE18XE1 running problems
  239. faulty crankshaft sensor effect starting?
  240. Washing the engine
  241. Intercooler for my Cav turbo, want a Big one, which one???
  242. turbo conversion and rev counter
  243. s.tourer drilled 20xev air box
  244. Omega engine problem
  245. LET fuel and ECU relay noise?
  246. let and xev aux belt pulley same or not?
  247. EDS Phase 2 Chips. Whats the switch??
  248. Compression ration for a 1600 turbo
  249. cam duration- why it means nothing
  250. carsa gsi rebuilt and now wont start
