: Engines and Transmission
  1. c20let boost isues
  2. c20xe ignition amplifier
  3. "MAP" sensor ??
  4. c20let auto tensioner pully
  5. DewIsmotorsport c20let custom inlet manifol
  6. f20/f18 5th gear mod
  7. C20xe sump gasket??
  8. 2.5l v6 vs 2.6l v6 vs 3.0l v6?
  9. gearbox and clutch for xe conversion corsa
  10. dial gauge on a xe inlet cam advice!
  11. Zafira Gsi tuning
  12. gearbox advise
  13. few extra bhp from my 1.2 8v corsaaa any ideas?
  14. Oil leak, really need help
  15. cams for a 1.4 8v
  16. Calibra Rear Axle -
  17. mpi head on a spi bottom end
  18. What turbo flange type to go for C20LET
  19. Where does this c20xe connector go??? pics inside
  20. c20xe year help
  21. 20XE running in mileage
  22. C20xe air flow meter same on other cars?
  23. Anyone run an f20 on their V6?
  24. Mantzel inlet help?
  25. c20xe stem seal diameter
  26. Help astra sri not starting
  27. BMC CDA in Corsa B
  28. rocker cover breather mod
  29. Will Cali/Cav equal length shafts fit a Vectra B?
  30. C20XE dipstick
  31. zafira gsi problems!!
  32. stuck for ideas
  33. z20let regal phase 1 - thirsty
  34. c20 upgrade to t3
  35. F20 box onto vectra Gsi 2.5
  36. 2000 astra sri manifold
  37. F25 gearbox strip?
  38. turbo housing an good
  39. Help!! X14xe pipe mess!!!
  40. vectra gsi 2.5 v6 or c20xe with cams?
  41. 2.0 8v turbo
  42. Astra 2.0td fuel pump / EDU Question
  43. C20xe engine using loads of water
  44. X16XE Problem
  45. power steering help urgent
  46. c20let head bolts
  47. C20xe starting problems
  48. help: clutch issues
  49. z20let cdti airbox mod
  50. f28 electrical
  51. C20Xe piper cams
  52. cosworth pistons c20let
  53. Can't get any gears after box refitted - Astra Mk4 1.8 Coupe
  54. vec 2.2 dti engine wont rev above 2k ok when brake pedal pumped a few times
  55. mahle pistons
  56. No spark with MBE on a C20XE.
  57. 200sx manifold..
  58. c20xe questions
  59. exhaust wrap
  60. will a power steering pump off a mk3 astra gsi fit on a 1.4 astra engine?
  61. what engine??
  62. corsa b immobiliser/cenral locking
  63. corsa c20let f28 gearlinkage
  64. megasquirt/mircosquirt ecu's how easy and reliable are they???
  65. Vauxhall Nova Engine Swap......good idea or not?
  66. power steering advice
  67. 20seh cam timing WAY out.... opinions please
  68. EPAS with LSD!
  69. Whats engine for a MK3 astra Van R reg???
  70. z20let stutter
  71. wideband sensor
  72. Astra mk4 Sri turbo (Z20LET) chatter sound
  73. Can anyone Help, why is my X20XEV idling at 1500 when warmed up?
  74. C20xe corsa Gsi knock sensor problem
  75. z20let astra behaving a bit wierd
  76. Oil fill on F17 gearbox
  77. 1987 astra merit 1.2 engine swap
  78. Performance clutch
  79. c20let turbo help
  80. posible engine swap need help? please?
  81. Astra Mk3 C20XE, Check Engine Light,Engine stutters.
  82. X16xe - ecu
  83. Dose anyone use Castrol R40 ?
  84. corsa c starting problem
  85. X14XE - Corsa - Water leak
  86. xe ocasionaly runs on 3 cylinders
  87. Air induction for mk4 astra gsi?
  88. Diesel fuel pump relay
  89. corsa f28 linkage all sloppy...
  90. C20LET - ECU chip removal
  91. c20xe ignition leads NGK/BOSCH/Splitfire/Ebay
  92. 1.6 spi help
  93. zafira 1.9 cdti dpf removal
  94. petrol and diesal
  95. C20LET hybrid K26/16 turbo
  96. WIll be changing headgasket and rocker cover gasket on 1.2 8v OHC. Any tips?
  97. what distrubutor to use on c20xe for carbs (twin 45's)
  98. Z20LET into Mk4 Astra
  99. Astra pumping in WAY too much fuel
  100. building for more power.
  101. C20XE - Corsa - Changing gear linkage
  102. C20LET - What fuel pressure
  103. 95 cavalier carburettor conversion query
  104. Corsa 1.4 xe 16v running on weber carbs.
  105. quick actuator question
  106. questions for corsa b
  107. Vectra c any engines to avoid?
  108. x16xe loom to x10 loom
  109. are these injectors ok?
  110. Astra Mk3 GSi - V6 - Won't start
  111. C20XE - Nitrous - 400bhp shot
  112. front gearbox mount bolt hitting gearbox cant get nut on please help
  113. Bosch part number for 3 bar map sensor
  114. Corsa X12XE to MBE 20XE help please.
  115. z18xe running (missfire) issues
  116. what clutch to buy?
  117. boost gauge reads 0 at all times
  118. c20xe idle control valve
  119. code for standard z20let turbo ??
  120. Is it a LET or XE cam?
  121. c20let rear wheel drive gearbox??
  122. xe baffeld sump,pics???
  123. Cam timing (LET)
  124. Corsa 1.5TD Need Exhaust valve
  125. C14NZ question...
  126. will this friction plate fit the f20 box
  127. what engine is in my omega
  128. 1997 Vectra SRi 2.5 V6 missfiring
  129. C20LET - Oil pump
  130. T28 - Turbo actuator
  131. C20XE - Mk4 Astra Van - Missfire
  132. C20LET- J reg Astra Mk3 GSi - Fueling problems
  133. Z16SE/MPi Throttle valve behaviour - is this normal?
  134. 2.2 Petrol Omega - Snapped timing belt
  135. Linkage hitting the rack on xe corsa
  136. valve spring compressor
  137. C20LET - Smoking
  138. astra mk4 1.6 SPORT KANGAROOING???
  139. Vectra C - Clutch pedal issue or clutch gone?
  140. C20xe will not turns over but will not start
  141. C20XE\LET - Timing cover
  142. fitting v6 caliper brackets.
  143. C20LET - Mk3 Astra - Fuel pump and boost pressure help needed
  144. Nitrous oxide kits?
  145. C20LET - Tapping\Knocking at 1100rpm when warm
  146. EDS PH2 C20let engine: how much boost should it be running?
  147. Mk5 Astra - Concentric slave cylinder keeps bursting
  148. C20LET Lambda Sensor Relocation?
  149. Calibra 8v - Clutch change
  150. XE Coolant temp sesor - which one?
  151. astra dump valve issues?
  152. where to get new engine hoses?
  153. c20let boosting issues running out of fuel i think ( new reg update )
  154. organic helix clutch will xe fit the let
  155. HDi Electronic Boost Controller
  156. C20XE Big End bearings standard or oversize ?
  157. c20let oil pressure what should it be
  158. Xe astra o/s/f mount
  159. What is the best T35 manifold ?
  160. C20LET Running problem
  161. linkage
  162. x20xev runing problems
  163. Help! 1.8 8valve MULTIPOINT
  164. bigger throttle body for 16v (X20xev)
  165. Let boost control solenoid
  166. mk3 gsi c20let runnin f18 and want to convert to a f28
  167. Tigra A engine conversion? any advice!!!
  168. Astra GSI TC XE loom on non TC engine
  169. C20LET - Running lumpy
  170. 19 Row Oil Cooler For 350BHP LET OK
  171. 2.0 DTI Queries - Fuel Economy and Starting
  172. running c20let on individual coils
  173. drain plug on a f20?
  174. Astra Mk2 GTE f28 short shift
  175. XE Corsa - CV joint issue
  176. is the c20let crank the same as the c20xe???
  177. SEH intake manifold
  178. code 66 Carbon Monoxide???
  179. C20LET - Fault code 114
  180. my 20xe rebuild to a 20xe turbo
  181. help with removing drive shaft (inner cv)
  182. what injectors on a c20xe?
  183. K16 Water pipe to header tank question,
  184. What turbo is this?!
  185. XE Corsa - Running issues
  186. Signum 3.0 V6 CDTI Cam Belt
  187. C20XE - Fault codes
  188. calibra turbo rear engine mount
  189. F28 torque rating?
  190. gearbox problems
  191. Redtop into an 8v Astra GTE
  192. cavalier gsi ignition problem
  193. 2.1 c20xe
  194. Coolant & Antifreeze Explained
  195. c20xe with high lift cams
  196. c20let water feed
  197. Massive air leak or electrical problem?
  198. manifolds
  199. x16xe head on x14xe block is it worth it???
  200. dimensions for x14xe manzel type power box?????
  201. will f18 from avectra fit an astra g with c20xe
  202. engine conversion on mk4 astra?
  203. Dismantling a Calibra equal length drive shaft!
  204. Z18xe corsa ... engine a bit ticky for my liking
  205. noise in engine - any ideas?!
  206. X16XE Head Skimmed.
  207. P reg 1.4 Spi Mk3 Astra - Loss of power
  208. Does an f20 gearbox have a shorter bell housing than an f16?
  209. F20 Gearbox Oil??
  210. 1.6 16v sport problems
  211. c20let f28 gearbox mount broke
  212. corsa redtop
  213. zlet problems
  214. Best make Valve stem oil seals:protect
  215. Nova 1.4 Bottom end gone
  216. astra gsi-corsa redtop driveshafts
  217. Calibra equal length driveshaft bearing.
  218. c20ne lacking power?
  219. what way to turn a adjustable fuel pressure reg to run safe....
  220. c20let hydraulic lifters
  221. Air leak...PCV?
  222. head gasket change
  223. C20let heavy Miss-fire underboost???
  224. Flat battery now car wont start and many fault codes!
  225. possible sump problem
  226. Calibra Turbo (aftermarket) intercooler piping questions..
  227. what injectors to use - C20LET
  228. Zaf gsi miss-fire on idle
  229. mechining xe pistons to let
  230. 1.6 Forged rods
  231. ever seen a clutch arm like this?
  232. Megajolt - c20xe engine advancing different to map
  233. C20LET Boost issue
  234. Inner cv joint keeps popping out c20xe corsa
  235. Carlton 3000 24v starting problems
  236. No heaters after head refitted Mk3 Astra
  237. Vec C DTi fuel filter housing compatible with Vec B
  238. corsa 1.6 16v turbo help?
  239. 2.0 8v help emisions
  240. c20let on f20 gearbox, flywheel and clutch? HELP!!
  241. C20let cam help
  242. RC 750cc Injectors - Part number required
  243. CAN i use the 'late type' head bolts in the 'early type' block (c20xe)
  244. red plug on 2ltr 8v engine inbetween injectors
  245. turbo
  246. c20xe onto f23 gearbox clutch /flywheel need help
  247. 2.6 V6 vectra SRI
  248. Super Touring Cam belt intervals
  249. NCT/MOT
  250. NCT/MOT
