: Engines and Transmission
  1. How do you test the glow plugs on a diesel?
  2. Mk3 astra estate engine conversion
  3. c20let conversion help
  4. Corsa Sport missing and backfiring
  5. c20let throttle body connections help please
  6. Buying a 109,000 mile LET Help?
  7. MK2 Astra Radiator
  8. fitting electric mirrors to a corsa diesel
  9. rear turret pics for coilovers
  10. XE Parts - Std or not?
  11. seriously good turbo & price
  12. possible exhaust restriction?
  13. Cant start ecotec - (RWD Mini ) immobiliser
  14. which Oil advise please
  15. gearbox ratios wanted
  16. my immobiliser key fell out and cut of the fuel
  17. Batt light staying on - with engine turned off!!
  18. how can i tell wether my f13 gearbox is close ratio
  19. fitting air fuel meter in c20let gsi
  20. Combo fuel pump.
  21. Cambelt Change
  22. C20LET Compression test results
  23. Astra Mk3 Radiator Check
  24. xe on tb's ignition leads
  25. How much oil should I put in a 2 litre ecotec?
  26. c20xe to c20let how hard is it??
  27. C20XE Grear Selecter rod...
  28. heres one we've no had in a while - breather mod question
  29. C20LET inlet cam
  30. crank case mod???
  31. HELP!!! Crankshaft sensor...can't seem to get to it...
  32. nova xe mounting points
  33. astra gsi gear linkage help please
  34. Engine building oil?
  35. mk3 astra clutch cable is it easy to change
  36. Spanky XE/LET manifold - what do you lot think?
  37. engine management code 48 20xe
  38. cams dis and carbs
  39. let loom into astra sri
  40. throttle bodies
  41. 1.8 Cavalier never gets above blue whilst driving
  42. XE on a standalone management, how much NOS?
  43. fitting mk3 astra gsi fuel comp to non gsi
  44. uprated actuator-will it increase my power/torque?
  45. engine tuning
  46. Coupe 2.2/ Superchip? Regal Chip
  47. c20let fuel rail hose split, help!!
  48. Mk3 Astra Trip Computer says: Oil Lack
  49. Corsa 20xe Driveshafts Where Can I Get Them?
  50. Annoying problem with xe
  51. astra egr valve
  52. Gear selection problem
  53. Starter motor click
  54. fast road cam
  55. petrol consumption with vauxhall corsa 1.2
  56. Trouble with corsa c20xe m-tech short shift...
  57. Standard compression ratio of a X16XE
  58. Is it possible to replace the mainshaft of F16...
  59. LET thermostat...
  60. Xe'd Corsa Won't Start No Fuel
  61. injector question
  62. Headgasket leaking oil?
  63. con rod broke C20LET
  64. con rod broken C20LET
  65. help me with my exhaust decision
  66. gsi 8 valve
  67. corsa 2.0ltrxe running rich. help
  68. Nova camber, caster and toe settings?
  69. std cally turbo radio...
  70. throttle bodies ??
  71. Dizzy pack differences XE and ecotec?
  72. Fuel flow dampener, do i need it??
  73. M-Tech corsa driveshaft spacer, why?
  74. F28 Gear linkage problems
  75. center exhaust box removal
  76. Astra 93 Diesel 1.7 water pump
  77. c20xe cams
  78. recon driveshafts
  79. Bosch injector flow rates
  80. astra 1.4
  81. Turbo diesel induction kits
  82. NE/SEH/XE pistons?
  83. Would you lend me a powercap?
  84. Engine query
  85. Coscast Head Or Gm, How U Tell????????
  86. Our transmission/gearbox woes
  87. Astra GTE Shaft Conversion
  88. XE into Nova, what connects to what ? !
  89. Best exhaust system for Calibra Turbo?
  90. high lift cams in corsa sport
  91. Is it possible C20NE with F13 gearbox?
  92. from 1.6 to 1.8
  93. cali 4x4 air pressure in system?
  94. c20xe goin in my corsa,speedo question?
  95. X16XEL head gasket??
  96. want to build corsa 4x4 red top turbo
  97. corsa b with turbo brakes
  98. does anyone know the difference between the 2.0 8v ecu loom variants
  99. hhas anyone ever come across a vtuning-porous fixed head thats became porous again?
  100. Xe To Let
  101. 1.6 sport astra...how can i make it faster!!!
  102. Nova 1.0L starter motor
  103. all nova driveshafts............
  104. Head Gasket question
  105. vectra misfired then cutout
  106. links for injector info / sales
  107. Astra mk4 TURBO????
  108. will a red top fit the 4x4 box of sri cavalier
  109. 4x4 corsa or nova
  110. sticking valves?
  111. 2ltr 4x4 corsa
  112. C20Let Valve Pic What Valve Is It
  113. Very obscure fault after engine rebuild.
  114. C20XE Corsa Overheating
  115. x16xe dieing
  116. c20xe corsa running problem
  117. Changing seals with head on
  118. Omega ECU Chip Number?
  119. Aftermarket HID Xenon Kits....
  120. cat off, straight thru on :-)
  121. Removing heater on LET Mk2 Astra track car - good/bad idea?
  122. crank sensor no sig
  123. Astra Mk4 Sri exhaust
  124. oil leak, i think.
  125. nitrous
  126. LET (Yellows) Injector Question
  127. C20XE heating up
  128. XE wont rev over 4000
  129. LET crank dimensions
  130. would this turbo be worth putting on 300bhp let...
  131. g-max kit,cav 4x4?
  132. transfer box,speed hump?
  133. Any GOOD Dyno Tuners in/around Leeds?
  134. Transfer box temp sender, swapping from 2 to 1 wire?
  135. calibra exhaust
  136. Problem with my C20 LET
  137. 4x4 tracking
  138. Corsa b combo van gear box...
  139. c20xe coil wiring
  140. corsa xe problem eps and speedo
  141. Fueling question/ internal tank
  142. Nova gsi loom wiring
  143. coilover fitting
  144. Engine code fuel pump relay help
  145. c20xe wiring into nova gsi loom help
  146. Nova LET problems
  147. How much boost can i run on my Phase 2 Cav turbo??
  148. Does ITB's and Lambda Sensor go together?
  149. Seriously erratic Idle - XE
  150. Help 2l nova driveshafts
  151. Let oil spray nozzles
  152. My new sbd type C manifold nikel! (pics)
  153. Removing and fitting of a f20
  154. Which strut brace for a c20xe nova with the sfi box still on
  155. Help.....central locking not working(spark)
  156. Heavy duty con-rod bearings for 2L 8v
  157. BHP Of Astra Sport 1.8 16v
  158. Heater Probelm Calibra Turbo '96
  159. changed oil using vaux 10/40 now it taps
  160. Egg in me Rad,fixed Rad,How do I get egg out?
  161. What Spark Plugs
  162. Fitting/filling new lifters of 20XE
  163. Drilled Air Boxes? Are They Worth It?
  164. let fuelling problem fixed
  165. converting astra mk3 x16xel into c20xe red top
  166. coil lead sparking, injectors firing and icv clicking when ignition turned on
  167. ecotec piping question
  168. f20 gripper diff.will it fit the f28 like the atb does?
  169. Fuel pressure? General Query.
  170. ebay remote engine start any good?
  171. v6 engine pics wanted
  172. c20let into astra gsi urgent help please
  173. Regal nova c20xe silicone hose kit
  174. c20xe....no spark?
  175. Engine Mount Bolts F28/F20 Turbo/GSi
  176. map sensor
  177. * E16SE into 1.2 8v Corsa B...What fuel pump?
  178. C16SE pistons diam and bore size
  179. higher fpr
  180. Motronic 2.5 or 2.8???
  181. Walbro 255 Fuel pump - WHAT KIT???
  182. C20LET lumpy idling and cutting out
  183. Suspension for c20xe corsa? Koni?
  184. If I was to build an LET from scratch...
  185. mk 3 astra heater relay location?
  186. C20LET injectors
  187. c20let imobiliser
  188. Induction Kits On 1.0 12v Corsa
  189. f28 into mk2 astra?
  190. Uprated oil pump question
  191. cav td seat belt tensioner
  192. 190lph sytec fuel pump ok for 300bhp?
  193. changing rocker cover gaskets on Mk3 Astra help needed...
  194. X16XEL Tuning?
  195. Red Top Corsa GSI Running Problems!
  196. which oil for vaux Tigra? 10-40 or 15-40?
  197. Are let / xe crank sensors the same?
  198. c20let fault code 71 ats
  199. GTE exhaust. Which box is cat?
  200. Oxygen/Lambda... problem
  201. Calibra turbo...................THE END
  202. corsa x16xe (no performance)
  203. gearbox sender
  204. High idle on my ecotec
  205. Astra VXR turbo part no and eng' code
  206. Superchips for C20LET..........help
  207. Fitting Walbro 225 Pump Cav Turbo
  208. rear gearbox mounting astraf
  209. c20let into a automatic calibra?
  210. 20XE How To Regain Lost Power
  211. why does 4x4 keep switching off when warming up?
  212. do 1.4 single point injection astras have throttle bodies
  213. Engine mount trouble
  214. 20xe mods
  215. why the differences between the X14xe?
  216. Nitrous Question
  217. New corsa SRi 1.8 tuning...
  218. Misfire running rich MOT failure
  219. 3.0 ECU Map
  220. calling all 20xe owners (in nova), need abit of help.
  221. FSE power boost valve fitting!!!
  222. ARP head and conrod bolts
  223. LET rings that won't make me skint?
  224. Vectra Head Gasket replacement
  225. astra gsi turbo having problems help needed
  226. Difficulties & Disadvantages of F28 in nova?
  227. ecotec troubles
  228. Corsa 20XE wont start!
  229. Engine Transplant Astra SXi
  230. Is it possible to put fuel lines on wrong way round?
  231. Fuel Computer For Vectra P Reg
  232. Cigarette lighter
  233. Lightened Flywheel ; Whos Got one? Your Thoughts?
  234. LET CONVERSION ON A TIGRA (help)
  235. Fuel pipe how to remove?
  236. Transmission refill location C20XE F20
  237. All Parts Required For Let ??
  238. What uprated fuel pump for the LET
  239. X16XEL flywheel locking tool
  240. astra F LET intercooler size
  241. Astra mk4 SRi Turbo question
  242. intercooler for mk2 astra??
  243. correct main cap bolt for c20let
  244. LET Tophat
  245. octane plug for race fuel
  246. engine trouble
  247. power steering nova
  248. 1995 corsa sri 16v engine dose wot it wants :s
  249. gsi/ xe sri cat the same?
  250. which turbo do i go for c20let
