- to plumb in a mbc
- can i remove trigger wheel off XE crank if not needed??
- F28 mechanical and elec boxes? Query!
- has any one done a saab turbo lump to vectra?
- C20let z20let oil pump
- 1.2 8v corsa lack of power
- corsa c z20leh conversion
- C20let clutch type????
- Injectors
- oil pressure
- Corsa 1.0 12v cut out - Seems heat or time related
- C20let oil pressure
- C20Let crank help!!!!!!!
- ecu info needed with v6 transplant
- one for the v6 tuners...
- 18se
- x20xev crank pulley diagram/workshop manual pages?
- mk4 with a v6 questions
- Z18XER (Vectra C 2006) into Z18XE (Astra G 2003)
- x16xe turbo help?
- c20xe injector problem wont run
- m14 1.5 pitch helicoil
- Valve spring compressor
- What's needed for engine conversion in 1.4 Corsa Sport?
- my C20XE dosn't like to go slow, please help
- Knock control module for vauxhall tigra 1.4 ecotec HELP NEEDED !
- C20XE missing PLEASE HELP! spent so much money so far!
- calibra clutch cable mystery ??
- 20xe cutting out
- what clutch for fast road and track use?
- Wiring a C20XE into a Corsa X10XE
- will the getrag manta box fit a saab lump????
- C22XE timing belt
- Engine misfiring, car undrivable. I'm stumped.
- thoughts on theese?
- c20let tubular manifold cracked
- LET Fuel pressure...confused.
- Fault codes and strange running !!
- oil cooler question , xe
- c20let miss fire
- Which engine? z20let any good? c20let is good but overpriced
- Corsa B X14XE h/g replacement unknown plug location.
- Are these any good or just a load of cheap parts put together?
- cavalier fuel pump cutting out?
- oil pressure sender/switch
- C20let oil pressure release valve
- cavalier service pdf
- f28 into vectra b v6
- intermittent c20let problem lumpy strt up and missing sometimes
- F28 electronic speedo conversion
- Intercooler = less boost?
- boost prob i think
- x20xev wiring in to frontera
- c20ne f13 1.7td fly
- Vectrta SRi 140 too slow
- 2.3td Frontera intercooler pipe size?
- C12NZ 1992 nova Frost Plug size?
- Z16XEP CTS location
- c20xe turbo cams
- Help Choosing Gearbox
- Z20LET. What phase ECU with this spec?
- Omega 2.5 V6 into Corsa B
- How do u tell if your cams have been re profiled???
- Anyone used chris astley's "el cheapo" valves ?
- Thread size help on C20LET tophat blank
- XE cold start idle
- C20LET Boosting issue.
- Receipts etc
- Water connection pipe from cavalier mk3 redtop to Astra mk3 redtop? HELP??
- Turbo Help
- c20xe ecotec adaptor pipe?
- C16xe emissions problems
- T3 turbo?
- Corsa rack mounts
- c20xe breather mod | blanking explained
- astra mk4 coupe calipers onto corsa b
- Retarding XE cam in Let
- C20XE Rough Running
- turbo help
- 17-18PSI safe?
- astra atlas 1995 1.6 8v new camshaft install ?????
- what aftermarket injectors for z20?
- Fitting oil temp gauge x20se
- x16xe with cam help on re-map?? please!
- c20xe throttle body
- Megajolt map
- C20NE TURBO - Where to put air flow meter?
- c20let clutch
- nova gear linkage help
- c25xe should i get a higher fuel presser regulator?
- c25xe exhaust issues
- c20let megasquirt issues
- what bar does a corsa b gsi run at
- XE/LET oil pump
- How do I get performance out of x16xe
- Diferences between C20XE and C20LET cam rocker cover
- z18xe vectra b sri 130 ecu changed......fault codes and cutting back on power
- saab turbo in a nova how hard can it be
- Vibrating engine/gearbox?
- LET cam bolt sequence and torque settings?
- combo van 1.7 cdti what box?
- looking for price on mounting and brackets
- bike carbs information needed
- Astra G C16XEL Noise from throttle body area.....
- 1.0 12v wiring plz HELP
- Has anyone seen this turbo set up before?
- 2001 Vectra B juddering and Management light.
- f16 or f18?
- best place for z20let tunning bits
- c20xe on LPG
- REDTOP C20XE Bottom Pulley different...
- thread size of standard C20LET inlet temp sensor
- Astra (sri) z20let power advise.
- help with gt3071r turbo position
- Immaculate C20LET
- fitting a walbro in tank pump to a corsa b help please
- C20let Reccomend me a clutch kit and flywheel for 350 bhp
- Early xe rotary arm in mess!!
- Will a f23 fit both these engines ?
- timing belt half a tooth out!!
- c20let bottom timing gear/pulley
- can any 1 help
- Thread stripped on F23 gearbox .
- Is this an ADJUSTABLE cossie 2wd webber fuel reg?
- Standard Top Hat Vs TX Autosport Top Hat
- what gear box for conversion
- Will z20let/leh drop into c20xe mounting points?
- Code 73?
- Where to buy Quaife LSD for F23
- c20let running problems
- corsa 1995 1.4 8v
- c12nz cambelt issues
- Z16SE info!
- removing crank pulley (engine out the car)
- Astra Mk4 C20LET intercooler kits?
- corsa vxr injectors into c20xe
- phase chip differences
- Vauxhall astra mk4 1.6 8v Club 2003 Burning oil+Dirty spark plugs.
- camshalft confusion
- corsa with 1.4 8v drives fine, then doesnt
- T3/4?
- Removing the selector turret on F17 box
- slightly odd missfire (c20let)
- Mk5 Astra 1.8 Fault codes
- URGENT - Anyone fitted an alloy sump to a smallblock 8v? Pickup pipe query
- 2.0 8v AFM Choice
- Z20LET & Z20LEH Oil Pumps
- corsa b 1600
- will standard z20let management cope with running Evo turbo?
- corsa idling problem
- wideband sensor
- What gearbox do I need ?
- f23 spline count for inner cv
- help with corsa b c20xe
- Whats the difference between these Helix clutches?
- standard corsa b tank and swirl pot?
- What gearbox do I have? 2002 Vec C GSi 3.2
- £3000, what can i do for maximum power?
- x16xe speedo sensor
- Thicker Head Gasket
- turbo upgrade?
- Blowing exhaust manifold on coupe turbo
- corsa z12xe into a agila
- How many washers?
- astra mk4 sri turbo huge electrical problem
- astra mk 4 gear linkage
- calibra propshaft
- Zlet Oil Pump & CLET Pick Up
- OMEX 600 mapping specialists
- Thinking of buying a Vectra 140sri BUT alarm problems
- c25xe AFM on c20xe with M2.5
- big end bearing 19.3mm vs 20.3mm
- c20xe gearbox options.
- 1998 corsa b conversion
- last prob hopefully c20let
- computer on a calibra
- corsa f28 gearbox mounts
- z20leh/z16leh into a corsa c?
- 20XE Corsa running problem
- vectra v6 standard fpr 3.0 or 3.8???
- isuzu corsa c?? engine confirmation
- c20let arp mains
- c20xe sump gasket question?
- Phantom XE fault codes
- C20XE Questions...redtop engine in my 8v Astra gte
- C16XE loss of power
- mk3 astra 1.4 8v help
- changine to carbs
- 1.2 8v changed to 1.4 8v. Now bogging down
- What Turbo For C20Let Engine...
- Timing belt ?
- Radiator fan stuck on.
- Does standard z20let/ko4 turbo fit on corsa vxr manifold?
- x20xev STEAMIN from exhaust?
- C25xe ping bang rattle!! Lol
- Z20let bhp
- Right a dont if this has been asked before
- F28 into a Cavalier V6
- corsa vxr turbo rebuild
- Throttle bodies , carbs
- 2.2 vectra enging leaking water into spark plug No4
- C20NE in a 1994 cavalier. What cam shaft??
- C20xe missing slightly on light acelleration
- autosprint 288cams problem
- can any1 help with wiring a z20let engine loom in to a corsa c 1.2 body loom?
- best exhaust for vectra b sri 130
- v6 waterpump
- Can arps rod bolts be fitted without changing shells
- corsa driving me mental!!!!
- 1.6 8v corsa b?
- redtop running problems
- can anyone supply me a wiring diagram for a z20let and corsa c 1.2 ECU/engine harness
- air filters, where from?
- C20LET F28 clutch help???????
- td isuzu cav tuning
- What fuel pressure?
- kkk turbo gasket question
- 8v flywheel size issues!!
- C20let gt28rs won't run high boost?
- F28 cali 2wd conversion
- Astra Mk4 1.6 16V: bad idle and running rough.
- x10xe wont start help
- Wideband lamba fitting distance
- are these injectors ok for 380bhp
- Engine Re-build Quick question !!
- C20ne Turbo
- 20seh turbo
- bigger turbo conversion
- fuel rail gasket and exhaust donuts
- Xe van exhaust options
- whats involved in fitting a t3 hybrid to my c20let ??
- Fitting a F28 in my vectra gsi
- Oil Pump & Oil Pressure Light
- what sort of power for standard z20leh?
- 20seh Turbo Conversion
- v6 conversion to cav rev counter problem.
- which cam is which x20xev
- will a 215mm clutch fit a 1.7 isuzu turbo diesel flywheel?
- Corsa 1.2 16v corsa idling problem please help
- Vectra 6 Alternator...grrrrrrrrrrrrrrrrrrrrrr
- c14se
- nova- 1.6/2.0 twin carbs or turbo
- gearbox will it fit?
- smallblock sump bolt sizes - Alloy sump
- Zlet Oil Pump on a Clet Which Oil Seal?
- oil light
- m32 gearbox issue
- X16XE Starting Problem
- 20XE timing (dizzy)
- 1.3 CDTi whine
