: Engines and Transmission
  1. Tapping noise after oil change
  2. Brake upgrade options, Calibra Turbo
  3. Astra Mk4 C20let
  4. possible head gasket problem on C20XE
  5. fuel pump relay location
  6. Where can I get some M6x20 bolts from?
  7. just had the head tested (valve leakage)
  8. does the let go in from above with head on ?
  9. corsa gsi...missing/eng light on
  10. Best Induction Kit Manufacturer?
  11. head gasket question
  12. misfire 20xe
  13. What size clutch does a Tigra/Corsa 1.4 16v have?
  14. Removing LET sump!??
  15. XE & LET coils the same ?
  16. Let Loom - Wtf!!!
  17. Corsa XE conversions
  18. Turbo Oil Return
  19. xe smoking
  20. xe problems...again!
  21. XE throttle body
  22. Quick question about fuel pressure and XE's
  23. coscast head question
  24. Water system C20XE?
  25. oil spray's a must ?
  26. Ultrasonic cleaning of injectors
  27. XE V's LET PAS Tank Size?
  28. XE flywheel on XEV engine?
  29. are ngk lamba sensor good as bosch for an let
  30. C20LET Actuator Options
  31. Accessory belt change question
  32. BCP7EVX NGK Platinums gap on C20LET Phase 2
  33. are ecu's different on dizzy/dizzyless c20xe's?
  34. 1.7 diesel gearbox and clutch fitment advice
  35. Fixing an F28 gearbox
  36. location of knock sensor?
  37. much oil does the f28 take?
  38. C20XE corsa gsi wiring
  39. TXB - What oil and level check ??
  40. 1.4 8v tuning
  41. Corsa 1.4 8v 1996
  42. 1.6spi fuel pump enough for a 2.0 seh ?
  43. Best Plugs for LET ?
  44. Transmission fluid - F20
  45. redtop conversion
  46. C20LET Ecu Question
  47. Possible exhaust blow problem
  48. grinding from sump
  49. ecotec codes will not flash
  50. fuel pressure regulator blanking plate
  51. Fitting a 2e3 carb for a 1.8 on a 1.6 cav.. Any probs?
  52. how to modify the throttle body - X16XE
  53. Xe to Let Conversion Questions
  54. Diesel head gasket, or more serious?
  55. Which Graphite Grease do SBD use ?
  56. C20LET : Ring groove depth ?
  57. Under the Rods.
  58. smoking let
  59. crap fuel economy
  60. C20xe Engine Number Location? Do V6 Brakes Fit Easily Onto A Corsa?
  61. where to get a 3.5 fuel pressure regulator?
  62. where to get thick gaskets for the x16xe/c16xe???
  63. Gasket sealant or not?
  64. Breather drilling or this lark?
  65. C20XE starting problems!
  66. Positive Camber
  67. c20xe runnin on 3
  68. xe boiling over whats wrong
  69. Engine conversion - speedo miles out
  70. Kkk26 Info Needed
  71. fuel connections c20xe
  72. converting C20XE lump to turbo
  73. Polishing inlet manifold
  74. Cleaning LET AMM
  75. quick oil question
  76. 8v Big block Clutch Options
  77. C20let Injectors ????????
  78. camber on a cally t
  79. Changing the waterpump on XE corsa
  80. 20XE No oil pressure
  81. 150hp 1.6 16v - what spec
  82. Flat top pistons from QED
  83. symptoms of leaking gasket from turbo to head
  84. Just started corsa xe, few probs
  85. Cally Turbo exhaust popping
  86. Superchip installation - pics inside
  87. xe inlet cam in let with garrett turbo
  88. nova gsi engine
  89. Does a dump valve have to be fitted close the throttle body ?
  90. AFM pinout
  91. jumping out of gear
  92. Xe corsa wiring problem
  93. What throttle cable on corsa XE?
  94. 20seh ecu em light idle valve?????????
  95. Nova GTE Engine Managment Problems
  96. Engine flush made my car cut out, any1 know why??
  97. Help Please!!!! Gear box Change!
  98. do i have to swap the injectors over?
  99. Redex intensive fuel treatment, is it safe to use?
  100. Oil temperature sender
  101. astra mk4 1.8 ecotec cooling saga
  102. C20let blowing oil out.
  103. c14nz pissing water
  104. c12nz power
  105. nova sr c20xe conversion
  106. Pressurised Crankcase .. oily breather pipe
  107. 1.6 mk3 astra "grinds" on full lock?
  108. 1.6 astra seriously rumbles at high speeds
  109. cav gsi engine loom in to astra gte 8v
  110. 2ltr Engine conversion from a 1.0 corsa B
  111. Tapping noise on a C20NE
  112. easiest way to 'hotwire' starter engine in the bay itself?
  113. Blocking the hole for the secondary Air Injection
  114. corsa indicators dont work???
  115. C20LET rebuild questions..
  116. 1.4i 8v tuning
  117. ECU 0202 misfire problem
  118. redtop cams what are they?
  119. V-Max Evo 2 chip..
  120. Huge BHP sideshafts for a let.
  121. Oil and/or oil filter change
  122. lambda compatability
  123. crankshaft pulley splined bolts...
  124. fk coilovers
  125. Astra 1.6 spi .
  126. xe red top engine age ?????????
  127. Glo plug change,but engine hot!!
  128. where can i get C20LET parts
  129. C20XE Crankshaft sprocket.....reverse thread ? :S
  130. Annoying LET boost problem...
  131. Fitting Bailey Dumpvalve on Z20LET
  132. 20xe nova, lots of smoke after hard corners
  133. Removing EGR improves performance?
  134. Pics of my pistons and crank...
  135. c20let wtf runnig problems
  136. cavalier exhaust
  137. Contol Indicator Light
  138. astra gsi c20xe over heating problems
  139. XE instead of XEV?
  140. cavy shifter in nova - it feels worse than the standard linkage. why??
  141. rebuilding a 16xe price of parts and info on running on carbs...
  142. x20xev-z20let
  143. XE ectotec adaptor??
  144. auto on / off of headlights??
  145. red top cutting out
  146. what gearboxes fit what vectra???
  147. Charge Air Cooler covered in oil?? Help
  148. Feckin' engine! (fuelling prob on LET)
  149. corsa c20 xe conversion, help with engine mounts
  150. re-built engine,, how many k miles to run in???
  151. anyone used yamaha R1 carbs on their 2.0
  152. Fault code EGR valve
  153. mk2 gte 1800 8v wiring to a 20 xe?????
  154. m vaux turbo problems
  155. cat box okay?
  156. Changing sump gasket C20NE
  157. 1.2 16v sxi corsa
  158. Engine number
  159. ecu chips how to check/dismantle???
  160. Oil temperature sensore in X16XE
  161. corsa gsi bhp?????
  162. Advice required on T3 Turbo please
  163. Turbo problem backing off in 6th...
  164. can oil pressure be accurately measured from a gallery in the head?
  165. XE in to GTE 8v
  166. V6 engine photo/similar needed
  167. LET/XE dizzy: how do I get rotor arm off?
  168. turbo rear hub removal, help please
  169. x1.4xe running poor help!
  170. dangers of running nitrous
  171. Standard C20LET Rebuild Parts
  172. wot oils best ???
  173. miltec exhaust
  174. Fuel pump not working!!!! (Help)
  175. C20XE What size/type of bolts to plug up oil cooler pipes?
  176. blocking EGR valve on Z20LET
  177. Cav Turbo & gsi tranfer boxes same??
  178. high temp resin/putty i can block a hole with?
  179. 4x4 problem!!!
  180. X16XE ECU In A Nova
  181. 1.0 corsa back box how much? easy to fit?
  182. cav egr bodge needed! also mot queery
  183. nova 1.4 sr parts list
  184. when using carbs...
  185. Nova + XE + Fuelling = HELP!!!!
  186. water leaking from near bulkhead
  187. C20LET carbon canister... info needed
  188. Corsa B C20let Engine Codes
  189. Had the head off now theres a light on?
  190. XE rev limiter question
  191. Headlights, dip/dim relay etc
  192. fault code help c20let
  193. 8V Sump to 16V block
  194. LET: Oil pressure releif valve part number?
  195. X25XE engine loom onto a C25XE engine?
  196. Cav T down on power ?
  197. corsa 1.2 16v running like ****
  198. V6 question here, pistons?
  199. Phase chips and acturators
  200. Let engine numbers
  201. 1.4sri stuttering
  202. 1.4sri stuttering
  203. another quickie
  204. water in oil... 20XE
  205. salad cream in crank case breather
  206. LET missfire on idle
  207. Need to replace standard LET pistons any suggestions?
  208. c20let steel h gasket
  209. Exhaust
  210. amal valve
  211. Decent LET pics
  212. engine management light cums on when using a different ecu! why?
  213. Diesel engines for astra Mk4 help!
  214. will the engine be stright swap??
  215. help im pised off with my turbo
  216. oil cooler c20xe
  217. Nova gear box issue help please
  218. HELP - dump valve postioning
  219. carb xe fuel pump wiring
  220. astra van c20let anyone done this b4
  221. Small block to F20 g/box
  222. fuel pump relay
  223. Turbo spin up / boost on standstill
  224. Cav GSI non-starter
  225. kkk turbo not boostin over 11 psi--fooked wastegate?--
  226. Astra 1.6i 16v SXi Misfiring Problem
  227. cylinder balance test on car with box-type coil?
  228. 1.4 Astra airbox into a 2.0 MKIII GSI?
  229. mk3 astra fuel pump
  230. X16Xe, oil pressure and electrical
  231. GTE 16V loom into a Corsa
  232. xe fuel pump wires
  233. Classic: F28 into a corsa c20let dummies guide?
  234. z20 let engine mount
  235. help with a diesel
  236. C20LET ignition problem on 2-3 cylinder
  237. oil lights wount go out on my corsa b!
  238. varley red top batteries
  239. ngk spark plugs
  240. XE fuel rail fuel direction!!!
  241. Blitz chips for C20LET? *problem*
  242. fuel wont pass the FSE
  243. Oil pressure warning light on throttle bodied 2.0 XE
  244. Cav v6 (Transponder ECU or NOT)
  245. Most Powerful Z20LET?
  246. Astra SRi.... Which Gearbox?
  247. C25XE second water pump/belt question
  248. HELP!!! Vauxhall Corsa 1.2 Semi-Automatic
  249. Engine swop - ecotec to redtop
  250. Dropped 5th gear on a F20
