- Code 75 c20let
- What boost should/can i run?
- MK4 Astravan Turbo Whine
- C20LET Lifters Tapping Problem
- Igntion kit for twin weber 45s
- Oil leak?
- c20let running on redtop loom and management???
- Corsa B hydraulic clutch conversion?
- 18E Carbs or injection?
- C20let corsa, Wont Start!!! No Fuel Spark or Eml
- v6 into a corsa b?
- astra vxr recirc valve issue
- Distributor Options
- z20let, x20xev inlet cam
- MBE mapping?
- cav turbo knocking
- zafira a 1.6 16v idleing at 1500
- has anybody actually used an evo turbo on a c20let?
- Smokey x16xe?
- c20let poor cold running fixed
- v6 cconversion
- Evo5 chips
- LET, FPR and Saab Reds Question...
- Who has done c20let in mk4 astra conversion help needed???
- Performance inlet manifold for z16xe engine?
- Gearbox Identification
- XE in a KitCar
- C20LET - Oil gallery plug behind manifold gasket - help?
- squealing clutch
- F28 Speedo Ring?
- Yet another smoking LET thread...
- Zafira SRI 2006 diesel. Battle with car dealer. URGET HELP REQUIRED
- Garret T3 on c20let anyone on here running one ?
- 2000 tigra 1.4 misfire
- Nova 1.2 High Oil Pressure
- Dipstick Problem With Astra H Sport ( mrk 5)
- who has mk4 astra c20let cause need some help :D
- Oil in Coolant
- let mk3 astra no heat inside (airlock???)
- Z20LET upgrades?
- C20XE coolent system help
- Oil out of exhaust, 20XE
- Please help.....Corsa fuel pump issue
- Any good LET sump gasket tips? Can never get a good seal!
- Corsa c redtop and carb help needed please people
- t3 turbo
- x16xe to nova
- tdo4 no boost and funny noise subaru
- how do you bleed coolant on a mk4 astra 1.7DTI
- Supercharger 1.8 sri
- Saab 9-5 V6 turbo, what camshafts?
- 2004 2.0 T SRi EDITION 100 losing blue smoke
- put corsa b engine into my corsa c now no spark???? PLEASE HELP
- Astra 1.8 16v sport wont idle at all
- f28 with tranz x lsd HELP!!!!!
- closed
- C20xe looms
- loom issue
- C20LET Late alternator with early inlet manifold - advice needed please!
- Difference in standard throttle body
- Are std rods/crank matched in any way?
- c20let knocking at 1500 rpm
- question about a piited cylinder head
- Torque settings for arp rod bolts
- XE - V Alternator... ANYONE help asap?
- SilicOne hose resting on exhaust advice plz
- Carbs to throttle bodys
- z20let flange
- ecu chip qestion
- Head Bolt permissible stretch on c20xe
- corsa b mounts?
- Fault finding P0170 Z18XE Zafira 1.8
- z20let engine help
- Go for ARP flywheel bolts or std ? ('93 c20let)
- C20LET Turbo Upgrade?
- help needed asap on my corsa c20let
- Metal Head Gasket Question
- honda engines in vauxhalls
- Whats the best gearbox for c20let?
- vauxhall combo turbo???????
- corsa tubular manifold and injector questions
- c20xe throttle bodies
- help z18xe turbo
- Reusing a baffle plate, rebuilding xe
- astra spi gearbox question
- xe exhaust
- 1.0l 12v Corsa B converting to 1.4/1.6 16v questions
- x20xev gearbox on c20xe??
- ECU plug in for Corsa B
- 20xe which head gasket to use ?? standard or uprated MLS
- any gen on z20let into corsa d ?
- just a quicky
- Vauxhall Nova Headgasket replaced. Now to re-timing, Any ideas?
- t34 Oil inlet feed restrictor?
- Just got a audi A6 eststat 1.8 5v turbo few problems
- very smokey corsa sport
- bike itbs on a c20xe
- Corsa With 1.2 Conversion to 1.6 8V Out Of Astra
- c20let conversion no fan / whats needed to put on switch
- Fitting the f20 rear mount to a f28 gearbox
- C20XE Dispac Camshaft trigger / sensor
- Corsa x16xe Dbilas throttle bodies
- Quick question regarding new camshafts
- Xe down on power, thoughts?
- kkk k16 turbo rebuild kit any good?
- F18 GearBox's.
- Bosch/Vauxhall part number for map sensor
- Coolant probs , will this be ok ?
- Replacing the cylinder head
- Gearbox noises??
- couple of last problems with engine conversion
- 16SV vs. E16SE
- help with vernier please
- auto box fault
- F16 C20XE questions.....
- f18 gearbox info
- Corsa b c20xe twin webber 40s mbe programmable ecu
- M32 into MK4 with Y17DT
- corsa accelerating slow
- Corsa B - c20xe new project HELP multi vee or vee belt
- Mapping session at "track and road"
- x18xe1 options
- vectra sri dti loud ticking noise when accelerating
- C20NE Bellhousing bolts
- help in my vauxhall nova
- 2004 VAUXHALL Vectra 2.2 SRi Shudder when driving up to about 60mph
- vauxhall vectra 2.0 dti 2001 (y reg) eml light.
- 2000 Corsa 1.6 16v won't idle properly
- What could cause C20LET smoking on idle when hot.
- Z20let boost problem
- STD Rods - ARP Tightening Torques [c20let]
- Help with EGR on X14xe
- Re:20xe
- c20xe ignition coil control module HELP
- Z20Let into mk4 astra saloon
- zlet sensors and vacuum box, are they needed?
- 2L wiring loom problems
- c20let evo turbo
- 3.2 j & g cam question..
- F15 5th gear gearing
- c20let kkk16 turbo
- whats the best vauxhall engine??
- turbo rebuild help
- Anyone know where to get...
- gearbox question
- C20let wont start
- t35 .48 or .63 housing
- C20let/XE pot type flywheel / speedo clocks
- xe engine into belmont sri
- EDS PH2 Problem
- Concerning Noise From Gearbox side of C20XE
- changing flywheel when converting from a f20 to an f28 question..
- can anyone recommend me a backbox?
- Blocked exhaust/breathing?
- can't find answer... c20xe and c20let cams
- f28 Pinion bearing? Grrrrr!
- Instaled c20xe in my astra mk3 1.4 what colours
- vectra flywheel & clutch
- Poor Acceleration and my cure you would never think of.
- External And Internal Wastegate Gen
- late c20xe coilpack HELP need Ignition Module
- c20let mount kit help please?
- Opel Monza GSI from South Africa help needed
- Some people have no idea...
- closed
- early c20 xe hall effect problem.
- A/B plug near Fuel pump relay on early xe?
- oil level blanking plate
- Corsa losing drive
- Astra coupe z18xe starting problem
- Z20LET Hanging Revs Sticky Throttle
- Flat fly to F28 clutch?
- F28 short shift help
- fuelin an xe nova
- Help converting an astra 1.4 mk3 to c20xe (total noobie)
- astra mk3 1.4 ..mk3 gsi C20XE engine swap
- saab in coupe ?
- eds ph3.5 z20let boost problem
- x16xe from Vectra
- pinion bearing f28
- injectors for 300hp
- F20 gear linkage removal
- in boot fuel tank
- What Fuel Presure Reg For Webers 20xe?
- c20let no oil pressure
- c20xe gearbox????
- X16xe into corsa x14xe starting probs
- Z18XE high lambda reading
- 1996 corsa sport 1.4 16v starting problems
- x18xe1 engine number location
- Fitting Dry Sump Kit to 20XE ??
- c20xe cam cover bolts torque
- Mahle and gm piston rings
- Fitting f28 using xe flywheel/c20let flywheel
- C20XE Help please...
- v6 rev counter in corsa
- 4 branch manifold for mk4 astra?
- Competition engine mount options for Type 1 Corsa B
- strange F16 gearbox problem on C20XE please please help!!
- C20LET showing fault code 15
- corsa b 1.4 16v sport
- cylinderhead different x20xev z20let/leh
- Z20LET Question
- c20xe exhaust snags
- Timing markers on 8v's
- Piston Pocketing
- Final drive for F20 gearbox in rally Corsa
- XE ECU chip fitting?
- Z20Let turbo rebuilt - now overboosting???
- HELP early xe wiring
- Over size pistons?
- corsa F20 gearbox mount
- Im a tool and trying to bypass the for sale rules but aint quick enough!
- z20let wiring
- Rebuilt engine running very hot.
- c20xe stalls under load after battery change
- whats cams c20xe
- G-reddy type s bov
- Engine flush (c20let ) good or bad???
- x20xev/z20let flange
- Engine build
- f28 rear mount ripped out ????
- cheap option with diesel van engine swap
- z20let advice please
- Corsa B C20XE Idle Problem Burning Fuel
- Straight Cut Box
- high idel on early xe??
- Wheres the best place to get uprated clutch from c20let
- corsa c inlet manifold and head gasket help URGENT
- astra v6 power steeringproblem
- C20XE
- short shift Astra mk2 (F20)
- Vectra gsi problem please help
- x16xe flywheel on a z18xe
- urgent help with inlet manifold and head gasket corsa c
- coolant leak.
- help x18xe1 issues
- Fitting a F28 in to a FWD
- V6 Vectra. tick over
- c25xe gearbox opinions
- Can someone explain heads to me please?
- Astra GSI exhaust - coupe
- Mk3 GSi c20xe Problem... & MFD
- Omega B Carvan MV6 3.0 HOT
- Nova Engine Question
- Quaife lsd worth the money or not?
- Signum 3.0 CDTI water loss and cold radiator ?
- c20let popping and banging
- c20xe hunting idle and eml sometimes
