- ecu remapping
- LET into mk3astra Gsi,intercooler/eng mounts
- nova c20let mount! help!!!!!
- supercharged x20xev
- Smoking turbo again!!
- X16XE EGR valve problem keeps sticking open
- V6/Turbo Brakes
- c16xe engine loom into nova wires...some odd ones?
- Which radiator on a Corsa Let?
- corsa gsi
- Whate driveshafts on an xe nova??
- LET ECU and Tech 1 question
- is it worth getting a performance clutch
- Ecotec airflow meter
- c20xe running prob
- oil pressure on xe corsa
- boost valve
- C20XE wont start.
- Flywheel - heat cracks
- highest BHP an XE can handle?
- Astra GSi Turbo Smoking???
- astra 1.6 8v fan belt
- Turbokit C20LET C20XE Stage 3 Super Response vauxhall
- new 2ltr 16v nova conversion with no spark
- arp head studs
- 16xe manifolds onto x18xe1/z18xe head?
- Removing bottom pulley C20XE- Help??
- confusion then loss of power
- Do my spark plugs look ok?
- Oil leak from sump sensor
- what box on a z20let?
- cam with longer duration?
- Cavalier diesel digi-dash?
- injectors vid
- Plastic crankshaft sensor?
- f28 gearbox / L-S-D convertion
- Let Not manging Boost
- Corsa XE Inlet Manifold question (with Pic)
- Help xe plug holes filling up with coolent
- c20let oil pump
- 2.0 xe oil in water tank!
- gearboxes
- juddering problem on R reg. Astra 1.6 8v
- Engine mount/drive belt problems
- What Engine Oil For X16xel?
- WTF is going on with my TPS??????????
- Corsa LET, F20 to F28 - Worth it?
- Corsa 1.0 12v Conversion To A V6
- How to diagnose Dizzy Cap And Coil
- Mounting a 20XE/LET into a Corsa C??
- Bottom end rebuild? my 'no oil pressure' outcome...
- X18XE1 - Z18XE1 Misfire
- nova engine swap xe for let
- Anti Rollbars On Xe Nova Yes Or No
- gearing ????
- X16XE sparks plugs - have a look at this please - what do you think?
- X20XEV wiring questions
- 1.8 ecotec... My F18 blew up!
- xe fuel pressure reading
- oil pressure problem and tapping once warm
- new lifters in v6 still ticking help
- unichip price??
- c20let oil pressure problem
- Exhaust temp sensors
- Crankshaft
- Problems since my boost pipe blew off
- exhaust back box
- C20XE - what hoses do these connect to ?? help !
- Another Clet wiring question
- Finally got my breather system sorted from my 2.2 mod (56k ok)
- Throttle bodies for Z18XE
- 2ltr turbo conversion
- Cam Bearing Caps
- Corsa Gearbox !
- gearbox swap!
- LET head refitting
- 1600 turbo second opinion
- any 1 know where i can get a tps from? and how much?
- ECU & key chip
- few f28 gearbox questions!
- Adjust calibra 4x4 handbrake cable (osr)
- C20XE corsa clutch cable
- engine management light : Vectra GSI
- fitting a twin exit exhaust?
- Who makes stuff from Carbon ???
- ASTRA X16XEL Performance
- Z20LET oil pump on a C20LET block
- Corsa 2.0 Inlet Manifold removal help
- X16XEL teething problems
- turbo cams
- Cam lift/duration etc.
- What the hells just fell in to my downpipe ? (LET)
- f20 onto c20let
- nova fuel tank
- Safe rev limit for XE with 45's
- alternator belt pics?
- carbs filters?
- Corsa XE 1/4 mile times??
- I've just blown up my Corsa Let
- need to know what this connects to
- XE rods in 8v
- ecotec series con rod pillow blocks
- c20xe wont rev past 3500rpm
- superchip
- which air filter ?
- Astra 1.4 8v MPi Problems. Possibly Not Getting Fuel???
- LET into 7-type of thing?
- MK4 Astra SRi Engine Mod
- C20XE Ignition module???
- X16XE spark plugs - every 40 000 or 4 years?
- car juddering badly
- 2.0 diesel boost problems?
- smoking engine??
- Let Running Problems
- Adjusting Actuator ?
- c16xe engined kit car???
- Late Vauxhall ECU's.. Strangeness..
- engine oil for c20xe
- engine cooling fan wont cut in!
- clutch problems
- calibra turbo 4x4-compression figures
- calibra turbo 4x4-- not starting
- Blown engine, part 2
- XE into corsa 12v fuel pump wire where is it?
- on the LET manifold is there a reason for ...........
- Can I use Quicksteel (Metal Epoxy) on a split oil pipe on cav sri?
- Which oil in my let? I have 15w40 in, is that right?
- water pump probs on sri 130
- C20LET Code 116 - Boost preasure too high, What do i do??
- SBD throttle bodies prices, are they worth it???
- M.O.T and engine conversion
- Matheus group buy clutches - balanced?
- will unplugging tps cause any problems?
- XE Timing Advance
- c20let boost
- exhausts
- Help, engine mount issues - mk3 Astra Turbo
- Getting around immobilisers in engine swaps....
- Lambda / Oxygen sensor
- catch can problem?
- calibra ecotec probs
- when oil heats up does pressure rise or fall?
- 2 litre engine into corsa Gsi
- Engine problems
- 9 pin block connector for engine loom ?
- C20XE corsa
- x20xev cylinderheads please help
- XE and Ecotec inlet manifolds the same?
- pistons and pins
- XE Oil in water and head OK
- Valves, Where from and how much
- nova xe running crap!
- 1.6 cam in a 1.3??
- changing fuel filter on Corsa / Tigra
- breather on a c20xe camcover
- Wheres the Tophat pic gone all labelled up?
- Turbo Fueling / Management Simtec 56.5
- Champion GTE change head to coscast or not??
- Gearbox Slave Cylinders
- cavalier coilovers
- Help!! Air con relay location - Corsa B
- C20let nova
- Different Injector Colours
- need help on my engine again
- astra mk4 bonnet catch
- astra m4 de-cat
- throttle body mod to ecotec
- dbilas throttle bodies on a let
- 3.0 V6 Cams, Part numbers?
- warning light lights up when the engine is hot
- 1600 16v head
- ne1 who as done a c20xe into a corsa i need ur help pls!!!!!
- Car feels very underpowered :(
- Egr Problem Help
- standard vauxhall (non forged, non machined) pistons - will they take 200hp
- smallblock xe rods - will they take 200hp?
- ST200 X25XE help required!
- Engine Mount Q
- Blown engine, much help needed
- intercooler Repair
- 1.8 astra weird engine noise
- 99 Astra 1.6 16v. Cheap power upgrades ??
- another loom
- C20XE oe manifold
- let ecu chips
- mk4 astra 12mm camber suspension bolts ??
- Many problems in my Corsa B XE conversion
- C20XE only firing on no.1 cylinder
- corsa c 1.8 16v oil?
- Engine conversion diagram or help needed
- which injectors to use in an xe?
- 1.6 8v spi to 1.6 16v, whats needed?
- Cavalier 16v XE Rear Engine Hose
- 1600 turbo pistons
- turbo wanted!!
- new dump valve....wont idle right
- C20XE fault code 31 ......
- GSXR 750 injectors
- xe nova running problems.
- 2.0 16v ecotec oil pump same as 1.8 16v ecotec
- What mount for F28 into V-plate corsa?...HELP ME!
- How to recognize inlet/exhaust cam
- XE Loom to Nova Sr..
- Mk 4 GSI Turbo more power wanted, ideas??
- Performance Fuel Pumps
- SFi/ecotec pipe/powercap debate.
- 'Performance' Gaskets?
- cometic headgasket
- Timing belt on c20LET
- X16XE Exhaust manifold
- Engine problems C16XE
- Wtf? Whats going on with this XE Camcover?
- help with removing the oil cooler off a c20xe.
- xe exhaust manifold gasket help plz
- Cleaning head/block surface
- f28 question
- Let ecu plug diagram
- F20 exploded diagram?
- Fuelling/tuning????
- xe sump still leaking !!!!!!!!
- Nova LET, Boost or Clutch probs ?
- turbo conversion
- paper clip test not working
- Fault Codes?? Astra 1.6 16v
- Carburettor help........
- Engine balancing
- Adding Synthetic oil to normal mineral oil
- S144 Hybrid actuator question
- cam numbers
- corsa xe conversion wiring help needed
- C16XE Idle problems
- astra gsi mk3 f28 fitment
- **CHECK**crank sensor??????
- valve spring compressor
- Corsa sri 1.4 misfire...
- c20 let cavalier smokeing sometime
- C20XE... engine number code? What means mine?!
- let fault code 113
- Will air/fuel mix flow over a wooden surface
- let intoo a corsa help needed
- What Fuel Pressure for a Phase 1 LET
- Problems with C20XE Engine conversion
- C25XE - X25Xe
- More advice needed (RE: Nova engine)
- astra mk2 digi dash into mk1 nova xe
- Corsa b clutch peddle.
- Another ecotec fault code, just for good measure
- setting up the carbs on my xe
- C20 LET into corsa b
- ecotec code 73 (cav)
