- engine builders
- C20xe AFM?
- R1 Carbs for C20XE
- C20let boost controller question
- c20xe running 3 cyl flash code 81
- Zafira engine in Vectra B
- Z20 LET Noisy Tappets
- Corsa B Trouble selecting all gears
- cant read ecu on 1.4 corsa sport please help thank you
- c20xe running on 3 cylinders
- c20let turbo feed pipe?
- C20xe running lumpy after refitting lambda sensor
- z20let pipe work
- c16se turbo fuelling
- x14xe losing water :-(
- Help non starting no fuel or spark
- c20let timing advice HELP!!
- How do you remove a corsa b 1.0 gear linkage?
- fitting big block onto little block gearbox
- Help - P0340 - Camshaft Position Sensor Circuit High Input
- c20let charge temps too high!?
- Clutch smell on Corsa Redtop please help!
- z20leh belmont, management ideas i.e omex
- will an f25 go onto a v6 with redtop recessed flywheel
- Astra VXR Turbo Actuator
- F20 Gearbox Knackered
- nova redtop fuel pump???
- astra mk4 2.0 dti x20dth keeps cutting boost out?
- eds phas3 power wheel with external wastegate?
- c25xe and x30xe.
- Corsa b track car Engine options - help
- Zlet oil cooling?
- Issues replacing concentric slave cylinder on F23 gearbox
- z20let turbo problem
- c20let boost issue
- Z20let oe dump valve
- does anybody no where i can buy a nova gear linkage
- Turbo reconditioning
- C20let coil pack
- Z20LET throttle pedal
- z18xe 256 cams
- F20 quaife LSD fitting
- how much for a engine rebuild?
- 6 speed box in zafira gsi
- Manifold Blow - Wrong Nuts?
- stock rods and pistons
- Z20let f23 leaking gearbox oil
- z20let phase 3.5 boost pressure
- C20let nos
- xe corsa
- thrust washer cleaning?
- problem solved with backfiring
- fuel pressure regulator working back to front.. any ideas why?
- Z20LET fault code please help
- fuel pumps
- corsa b epas
- corsa clutch problems
- Omega 3.0 V6 coolant leak
- Mvaux/ Matheus - the brazilian turbo bloke
- ESP / TC light on dash
- cv/ main bearing hub bolt torque settings ??
- mbe 956 pin lockout
- C20let 2.5 inch exhaust
- zafira gsi air leak
- c20xe problems!
- corsa x14xe cams
- strengthening manifold?? ideas...
- 2.0 16v ecotec
- F16 to x25xe, What clutch??
- Rwd c20let no boost what so ever
- F20 problem help plz
- c20xe into corsa wiring
- let 5th injector question
- Steel headgasket.
- f28, lost 6th :(
- cavalier turbo radiator into astra mk3?
- what height is best to mount the fuel pump??
- turbo exhaust size whats best
- Looking for transfer for powerful 4WD project!
- Vectra C VXR ecu location
- DTUK PDI Tuning Box
- Are my O2 sensors working correctly?
- Intercooler freezing?
- short alternator belt for 1.6 16v
- F28/Corsa B speedo trouble
- Saab reds
- Abs problem x20xev
- Mk4 Astra 1.6 8V, engine code?
- couple of let questions
- x16xe turbo
- Eco-tec Camshaft Sensor Problems
- xe cams in c20let
- engine identification
- will the 1.6 16v sxi (1999), ecu fits my astra 1.8 16v (1999) HELP PLEASE
- Diesel Turbocharger On Petrol Engine
- Astra VXR eexhaust fits Astra GSi?
- Water air liquid alloy turbo charge cooler intercooler
- C20LET induction filter.
- x16xe vacum pipes
- MEGAJOLT
- E.G.R Vectra 2.2
- coolant pipe help!!
- Problem with XE'd Corsa B
- closed
- z20let engine help
- 20xe wiring help
- nova c20xe twin weber 45's???
- c20let stage 3 lotec !!!!
- my pm box has room now
- help where is the vacuum pipe from here ment to go
- Help with Alternator cav V6
- QED Cam Pulleys?
- ph2 fuel pressure
- Gearbox nerds needed
- error code 10
- Double valve springs?
- z20let zaf help plz
- (A series Manta) XE conversion help
- 3.0 v6 ecu
- X14xe corsa revving but no go?!?!?!?!
- actuator repairs standard turbo let
- Astra G Walbro 255 fuel pump....
- Center bearing info
- chaiss mount measurements
- changing the ecu on astra x18xe1
- 18s and 16sh heads are the same?
- zafira gsi troubles PLEASE HELP
- megajolt c20xe map
- f20 leaking help
- ASTRA SXI Z16XE manifold removal need help
- need help
- Zafira SRi-T 2006 M32 Gearbox,will Astra VXR gearbox fit
- Siezed oil relief valve removal techniques?
- kkk16 water feed
- 20xe clutch
- how to tell what box im running
- diff or not help please ??
- what shafts and cv joints for an f18
- astra g ecu
- how to tell if air flow meters not working
- k16 rebuild
- will a corsa gsi box fit a c20xe engine ?
- How to fit 2.0 vectra hubs to a corsa b?
- help.
- Which fuel pump to run corsa c20xe??
- Broken rocker arm on C20NE how to replace?
- Oil leak c20xe
- Td to xe astra wiring
- Engine won't crank when warm?
- Saab turbo into Nova...
- 1.2 -> 1.6 16v wiring help please
- what fuel pressure is z20let vs z20leh
- c20xe nova not getting enough fuel
- Best standalone management for c20let.
- Corsa C20XE fuel pump question?
- FSE power boost valve set up on C2OXE advice please
- C20let chip fitting
- C20LET Idle Problem
- ecu learning
- Cat converter question
- Corsa C Cdti 1.7 Boost Gauge
- oil pressure light & pressure sender help please
- Help with c20let vacuum pipes
- 3.2 breathers..
- whos tightend xe pulley bolt to 250nm?
- corsa let with f28
- C20let/Xe dipstick
- Cavalier SOHC 20NE .....plug 1 keeps getting oiled!
- F28 syncros
- 1.6 Mk4 Astra Gearchange
- mk4 astra conversion
- Astra G v6 , need help
- Clet high oil pressure when revs are up!
- camshaft choice - 1600 8v.
- Flywheel question
- v6 3.0 cams
- corsa 1.4 16v 1998 5dr electric supercharger
- cheap diy v6 tuning?
- LET hesitating and juddering at part throttle
- Corsa C Z20LET conversion
- Missfire help needed!!!
- Quaiff or Trans-X?
- More torque for a c20let?
- F23 Gearbox Oil
- Corsa C20XE Driveshafts and Inner CV Joints?
- Nova 1.3sr engine
- c25xe ecu question
- help..air/fuel
- Arp head bolts
- Arp head bolts
- Cutting out problem with my Opel 1.6 Gsi Monza
- possible piston ring problem?
- ultrasonic cleaning
- corsa 1.4 sport engine
- Clutch bleeding issues
- cavalier c20xe help needed
- 8v rubber sump fit v6?
- Vectra F23 gearbox on a zafira?
- Petrol smell........
- Vectra Gsi not running nice.
- C20XE Dizzy - No Spark or Fuel
- no clutch pedal mk4 astra
- valves impacted pistons? cause?
- steel head gaskets
- f28 speedo
- torque settings for arp bolts
- enem cams
- corsa b c20seh
- F28 driveshaft oil seals same as f20??
- Max Boost On Phase 2
- f28 speedo drive
- mot failure?
- 1.6 corsa will not run!!
- xe/let cams
- F16c diff and gear set into an F20 casing, can it be done ?
- Commetic head gasket or regal gasket
- Dispak c20xe running lumpy
- C20LET wiring - what are these two plugs?
- What clutch and flywheel can i use? C20LET with F23
- oil pressure sender adaptor
- High revs/low revs on corsa c16xe and blue smoke
- v6 pads
- vectra f23 weak points
- fitting z20let to locost
- saab 9-3 cut out???
- C20LET headbolts
- What HT leads C20LET .
- Oil Pressure/Pump NIGHTMARE!!! help please!!
- best air filter on mk4 astra?
- Clutch help!!!
- Vectra GSi Failed Emissions Test
- 18NZ out/20NE in
- C16XE Engine Rebuild help
- Need a 1.2 Corsa C Engine
- cavalier gsi "chip"
- F25 with a let?
- c20let chips
- LET AFM Suspect
- Code 116, 16 and 19 - are they related - c20let
- oil pump stuck
- borg warner erf turbo
- fuel pressure reg?
- boost controller
- corsa eating headgaskets
- f28 plugs
- Whining noise from gearbox?
- some high bhp advice please chaps
- Cheapest place for big block inner cv joints???
- Dta starting problems....
- c20LET wont drive - cuts out/loses power
