: Engines and Transmission
  1. what gearbox came on the astra coupe turbo
  2. C20XE stuttering under load at low revs
  3. x16xe, what 4 brancher should i use??????
  4. C20LET hesitation on LET under high load/ high gear
  5. How would this help a let with kkk16?
  6. C20LET Fuel pressure issues
  7. clutch?
  8. C20XE head on X20XEV
  9. Coolant boiling over LET
  10. Nova TD (ISUZU) wont start..odd
  11. c20let modified downpipe similar to DSOP anything considered pics please
  12. Corsa diesel cambelt change
  13. Can a smallblock be fitted to a nova with tiebars in place?
  14. help needed about xe inlet cam
  15. Help needed, 1.4 16v bore and stroke figures needed!
  16. Phase 2 chips fitted correctly ??
  17. let into a corsa
  18. Wot Radiator For Mk2 Gte Turbo???
  19. Idle pulley mount late c20xe!
  20. calibra turbo - worn driveshafts??
  21. Shortening cav shafts for xe nova !?!
  22. Would an overbore affect fueling on a phase 2 LET?
  23. phase 3.5 wires
  24. Whats an evap canistor purge valve and how do i test it?
  25. XE into mk3 diesel van? C20LET mini?
  26. Vauxhall Vectra/signum F40 6 Speed Gearbox Manual
  27. Running amal valve/MBC on aftermarket turbo
  28. Exaust and Air filter
  29. STRANGE CHIPS LET is anyone familiar with these
  30. C20LET Crank pulley Torqx socket size?
  31. wiring c20xe in nova
  32. Aftermarket injector loom
  33. C20LET Tapping/Knocking (only bought 3weeks ago)
  34. f28 clutch, look at the pics and see if you can help!
  35. Turbo questions
  36. c20xe conversion problem in my corsa B
  37. uprated in tank pump for c20let corsa b?
  38. "c20xe" sfi in nova
  39. xe running problem help...
  40. oil pump-signs on gear wheels
  41. which carbs
  42. Oil PRV operation.
  43. If i was to turbo my XE....
  44. injectors help
  45. Custom ex. manifold & rack
  46. Clutch for a TD Cavalier
  47. dumb question: how to tell a 2 part sump...
  48. best plugs for a c20xe dissy type??
  49. frontera intercooler on mk3 gsi
  50. Help, fuel problem?
  51. c25xe conversion into mk4 astra coupe 1.8 16v
  52. corsa c engine swap
  53. F28 with electric drive, changing to mechanical.
  54. xev into nova from corsa
  55. New girl needs help!!!
  56. comma oils
  57. corsa diesel struggles to start in the morning
  58. X22XE Pistons
  59. why not turbo a 2.5 V6
  60. Replacing a head on a R Reg Vectra
  61. LET coolant temp sensor
  62. pug 306td changing fuel filter
  63. C14SE to C16SE (is it possible?)
  64. LET performance observation
  65. twin carbs and tickover
  66. c16se turbo ?
  67. Astra Gsi Power?
  68. what oil do i use at first, in a rebuilt engine?
  69. Drive shafts??
  70. Turbo & Supercharger??
  71. engine swap
  72. what can i replace the amal valve with (c20let)
  73. f28 in a nova
  74. losing oil?
  75. xe fuel pump relay
  76. AFM HELP
  77. Auto to Manual X20XEV
  78. What is this??
  79. Cav Turbo 4x4 Transfer box advise please !!
  80. Accusump Install Question
  81. What size cold air feed C20XE Viper Induction kit
  82. looking for a rebuild
  83. Pot type c20xe flywheel
  84. C20let clutch question
  85. Head Gasket on Corsa C
  86. Mass Air Sensor? engine cuts out.
  87. Calibra Turbo Front shocks
  88. DIY Cam Fun - Is It Possible ??
  89. Gearbox on C14SE
  90. What Intercooler is This???
  91. is astra 1.7 diesel turbo rad same as calibra turbo rad
  92. 1.2 Corsa into 1.4 SRi Corsa
  93. x20xev to z20let whats in volved
  94. imoberliser question!! c16se astra f
  95. Driveshaft hubnut to what torque?
  96. where can i get the cheapest clutch 20xe???
  97. HELP vxr injectors what fuel pressure
  98. sfi to tb gasket part number?
  99. picture and dimensions on a calibra turbo air fliter box please
  100. urgent help needed gear box change c20xe astra gsi
  101. Cavalier F25 into Vectra?
  102. Headlights always on even with ignition off
  103. [FAO 2.0 corsa owners] before lsd and after ?
  104. Ecotec key code question???????
  105. Calibra SE2 Cat/Exhaust
  106. Fuel computer from Cav GSi
  107. fiesta 1.25 tuning help please
  108. c20let ecu in a cav gsi question!
  109. Corsa block in a Nova
  110. Power Steering Fluid - Bleeding 4x4
  111. WTF is this engine? Redtop or Ecotec?
  112. 92 Opel Monza 1.6 Gsi gearbox question
  113. Late XE dis pack ignition question
  114. x16xe
  115. Peugot 106 1.1 headgasket
  116. corsa b. m-tech front engine mount
  117. corsa xe help
  118. Unknown Head
  119. C20LET Uprated HeadGasket
  120. Do U Need To Change The Driveshafts On A C20xe Corsa When Fotting A C20let
  121. Oil problem
  122. rebuilding a let
  123. low oil pressure c20let
  124. SEAT problem after oil change
  125. z18xe starting problems
  126. wire loom wanted
  127. Can a cambelt slipping damage the crank?
  128. Flywheel weight of standard nova wheel (F10 box)
  129. corsa 1.2 16v paper clip test?
  130. let boosting probs!
  131. astra let electric speedo help desperately needed
  132. corsa xe help
  133. 1.2 to 1.6
  134. c25xe coded key
  135. keeping air con xe into arctic2 1.6 16v
  136. fuel pump voltage rating????
  137. red top with flat spots
  138. C20 Xe Ticking on Cold Start
  139. Calibra 16v SE2 Clutch & Accelerator.......Help
  140. urgent help needed c20xe conversion
  141. MK3 1.8 Carb Cavalier distributor, coil etc. Is a rev limit built in to the module?
  142. tappets
  143. anywhere in somerset to get upgrades for ecotec engine
  144. is it possible
  145. intercooler and gearbox
  146. lamba sensor
  147. mk3 astra gsi clutch cable ?
  148. Question about final drive gear
  149. c20xe throttle positon switch
  150. LUK clutches. Any good for stock calibra turbo?
  151. Oil spray jets
  152. C20xe into a C20LET Calibra
  153. Cally ecotec driveshafts
  154. F20 driveshafts from MK2 GTE into Mk3 GSI
  155. what should a standard kkk boost to ?
  156. c20let fault codes read-results!
  157. fitted kent cam now car wont idle (c14se)
  158. engine code for 1993/4 1.2 corsa?
  159. corsa 1.4 c14xe overheating
  160. mods required for bhp increase 20let
  161. Z20LET on a C20LET
  162. gte16v fuel plug?
  163. cavalier sri bhp ?
  164. Corsa XE conversion, multi v pully setup?
  165. Does thicker oil..
  166. what type of oil for a 1.2 8v?
  167. hydraulic clutch pump, question
  168. Astra mk4 - Z20LET transplant
  169. X20XE from Omega to a Vectra - problems
  170. c20let fuel problems update
  171. Power problems
  172. the ultimate C20XE guide?
  173. oil on 1 glow plug?
  174. let evo5 chips.+lots more/what next
  175. calibra turbo won't idle properly
  176. best radiator for a nova?
  177. f25 gearbox
  178. need help with a xe cally non starter ??
  179. Ebay Hydraulic Lifters.. Any good?
  180. Astra 1.4 Cambelt Change
  181. dump valve causing probs
  182. corsa turbo - probs? - soon as boost comes in fuel cuts ?
  183. help i have no fan!!! on my c20xe conversion
  184. nova with tigra engine?
  185. 1.6 16v Breathin like a goodun
  186. c20xe corsa driveshaft query
  187. how to bleed the water system c20xe???
  188. fuel at the fuel rail????
  189. gear linkage experts!
  190. matzel style inlet question?
  191. calibra turbo calipers on to nova
  192. E16se injector numbers
  193. manta coil
  194. f28 into let nova
  195. Flywheel type for LET with f28 box...
  196. Astra SRi 2 litre 8 valve 0 261 200 538?
  197. p2 chips fitting threads.
  198. What is the top speed of a f16 cr g/box
  199. how much £££ to make my let 300bhp?
  200. engine not gettin fuel
  201. XE Not firing right...
  202. Calibra engine swap
  203. 20XE Nova and GTE shafts - How strong and Anybody snapped one?
  204. C20let with f20 fitted...
  205. emissions on 20xe corsa
  206. C20XE installation
  207. c20xe corsa conversion
  208. Woohoo! Another XE fitted, I'm back on the road!
  209. c20xe corsa driveshaft/CV help
  210. C20XE nova experts?
  211. 2 Post Car lifts - Single phase, and 3 phase differences?
  212. smoke and sparks from 20SEH
  213. Smell of burning oil at high revs.
  214. Tourqin up the head in a 16xe
  215. driveshaft question
  216. C20LET on Evo 5 chips. What plugs / oil to use?
  217. Help identifiying xe wiring colours please
  218. Hoping you can help... Corsa 1.0 ECU/EMO
  219. c20xe to c20let
  220. Head gasket or oil/waterway crack?
  221. c20let pistons
  222. vectra c inlet pipe???
  223. valve stem seals. c20xe
  224. F20 or F16??
  225. how much does f23 gearbox weigh
  226. C20xe Power Delivery Problems
  227. Gearbox oil, how much?
  228. C20XE k&N induction kit onto a Z20LET?????
  229. xe/turbo exhaust question
  230. nova xe-let
  231. pics of peoples tubular manifolds on there c20lets please
  232. c20let corsa problem
  233. Oil breather smells .
  234. where to buy a turbo from
  235. Whoosh noise when removing plug lead LET
  236. Sandwich plate for oil gauges
  237. low voltage @ tps any ideas why......
  238. Cylinder head
  239. XE Conversion astra MK2
  240. calibra turbo
  241. x25xe tecnical info
  242. do i need a new ecu to go with new head
  243. kkk16 turbo vs t3 cossie turbo! how much better are they?
  244. Tuning the 1.7 dti y17dt engine what can be done?
  245. can you help with my xe problem?? vauxhall cant!
  246. Corsa misfire 16xe..
  247. c20let and 20xe wotparts are shared?
  248. Omega/Manta Gearbox
  249. Saab red injector number
  250. ignition coils
