- Ecotec - 8v flywheel?
- Inlet Manifold Flaps on Vectra C CDTi SRi (2005)
- Nova sr pierburg problems
- Strange noise....
- vectra missing thought it was coil pack but it not
- corsa gettin hot with c20let?
- exhaust for 2 door mk2 cavalier
- C16XE Advice
- Z20let oil light
- Z20let best place for map
- mk4 astra gsi turbo issues
- Z20LET Problem
- Tunning fuel pressure via wideband?
- Gripper LSD, preload set up
- corsa b kangaroos / sluggish when cold any 1 know what this could be?
- Are my bearing the wrong size?
- Paranoid about my LET plugs (pics)
- corsa c20xe high clutch pedal
- Astra diesel 2002: starting problems
- Is this a Healthy Lambda Signal?
- help needed with the break in of my engine 16xe
- Supercharger project
- Help: Cause of no Long Term Fuel Trim data
- c20let, not idling properly
- m32 box on to c20xe/let/v6
- Z20LET Flywheel
- Gearbox fitting question
- what do i need to fita l pressure gauge to my c20let corsa
- C20let code 55
- LET Missfire.....Help please
- new piston rings for wossners
- C20xe & f18
- c20xe crazy jumping revs
- Vectra B Z20LET
- 3.0 - 3.2 con rods is there a difference?
- c20ne coversion to red top what i need to do?
- Corsa C SRi CDTi... RS Tuning Remap v AMD Remap v DTUK PDI Tuning Box?
- exhaust size
- C20NE fuel pump
- Vectra 1.8 SRI Vectra C Pipe Mod?
- confusion about bike carbs
- Boost question LET??
- Mot question on weber carbs
- c20xe rwd conversion info?
- Vectra B backbox question
- Omega X20XEV running rough
- corsa 1.3 cdti not starting?????
- EGR Antilag project test
- vacuum pipe for turbo housing
- 2.5v6 with 3.0 cams
- Which spark plugs should i use with Z20let running 300bhp+?
- nova c20xe gearbox spacers?
- C20LET Dump valve stopped dumping???
- kkk16 details needed please
- rebuild or replace z20let engine?
- Can the kkk 16 handle phase 3.5 or cs5 chips? Boost and fuel settings??
- vectra 2.0 16v in to corsa b
- Flash code 65 on a c20xe
- loss of power on x14xe
- Where can I buy the sleeves needed when converting F20 4x4/F28 to 2WD?
- LET engine only sparking on two cylinders
- C20xe AFM
- EDS phase chips with power wheel + fuel pressure Q
- c20let what injectors?
- f23 what clutch ?
- help with a mk 3 astra sri 8v
- v6 power steering pumps
- is this linkage suitable for f28?
- need help with c20let head
- Astra mk3 1.8 gsi c18xe 94'
- z20let, bigger turbo ?
- Can you help my poorly Tigra? :(
- c12nz, car broke down, replaced aic valve and distributor cap. starts, but with smoke
- Let cooling question
- astra mk3 redtop 9 to 6.5 kg flywheel, upgrade or downgrade?
- mk4 astra gsi exhaust Q
- astra 2.6 v6 tunning
- C20XE Rocker Cover Bolts
- Astra Coupe Turbo 2001 rattling noise on acceleration
- How do you setup your gears after replacing a gear linkage?
- GTE 16V header tank low level check control sensor
- c20xe nova not pulling properly
- Astra backbox Question
- Bigger Brakes astra van c20let!!
- C20XE Complete Rebuild Help
- Vaux Astra 1.6 LS '99 EGR Valve Problems
- Engine get very hot
- 2003 Corsa, Replacement engine now spare connector.
- fwd to rwd
- C20XE Crank Tolerances
- are oil jets really required for 360-380ish bhp z20let
- head gasket- tigra- a bit of help :)
- How long do 2.0 DTis last?
- 06 plate zafira 1.8 ecotec
- help needed identifying 3.0 g cams for v6
- Astra mk4 2.6v6 converted
- code13
- Y26SE into Mk4 Astra
- astra g oil change
- c20let turbo feed pipes were d they go?
- Corsa C Combo F13 driveshaft help....
- C20XE airbox 'drilling'
- X25XE Heads
- new injector problems
- low level oil warning light need help
- C20LET bearing clearances
- Copper headgasket
- z20let ecu transplant and timing question
- Cam Sensor
- fuel pump replacement
- f23 gearbox build with lsd??
- Courtney sport chips c20let? Any info or ideas welcome :)
- Courtney sport ch
- Astra G - X16SZR - 8V - Need Help Identifying These.....
- Where to buy C20let AFM ?
- Mk3 Astra van c20xe which tank to use?
- How hard to convert Nova to C20LET?
- C20Let problem ?
- C20LET cold start / cruise problem
- C20let cs5 chips.. Any info helpful :)
- phase 2 ecu help
- c20let phase 2 chiped ecu help
- how much oil and what grade is best to use?
- 2003 Corsa 1.2 16v - Wiring issue
- x16xe missfire at 2krpm to 2.5k rpm !
- spare plug on engine after changing engine
- Question for engine type
- how to fit turbo on a vec b 130 sri
- c20xe prob again!!!
- Early Vs Late C20XE
- xe running problems when warm???
- frontera intercooler
- engine just stopped, wont start
- mk4 astra c20xe andx25xe on carbs.. bit of info/help please
- z20let rebuild who to trust
- Astra f f28 shafts
- Mk3 astra; auxillary belt tensioner
- corsa b 12v help
- smokey forged c20let!! need some advice please
- how hard is it to put a saab turbo engine into a cavalier mk3
- Z17DTL EGR valve
- anyone in n. ireland who is outstanding at mapping??
- Mk 4 Astra 1.6 8V LPG X16SZR - Any Pics Of Vacuum Pipes???
- z20let running z10 ecu?
- x16xe to x18xe1? corsa/tigra
- inlet cam in a c20let
- engine wire question c20xe
- Vectra 2.6 v6 how much nos
- C20xe won't take throttle and running lumpy
- oil pump not pumping
- where can i get a 6 paddle clutch for a f20 gearbox?
- f18 gear linkage recon?
- Engine Identification Help
- Zafira 1.8 16v core plug location
- Vectra B GSi Camshaft problem
- v6 cam change... shells/bearings???
- c20let code 26, cant find the fault
- standard fitting 3.5 bar fuel reg for c20let
- Anyone know someone who can swap gearboxes.
- has different combos of cams been dyno'd or proven in the V6
- where can i get corsa b gear linkages form?
- xev oil pump on xe?
- Zlet cam cover options
- Cover plate to flywheel bolt size/pitch
- anyone running a TX autosport T3 manifold
- Best setup for 400bhp from a C20let?
- Help please difference in ECUs?
- help with 20seh
- burning oil smell and cat problems
- What Gap for these plugs in my c20let
- What fuel pressure for saab reds on evo5 chips
- anyone fancy mapping my leh corsa c whilst at pv?
- C20GET Head Studs
- Mk3 astra x20xev conversion help?
- speedo in mk3 v6
- corsa b f20 gear linkage
- mk4 308's onto mk3?
- Vectra F25 into a MK3 astra?
- 1.7 isuzu engine blocks
- Removing Gear linkage on f23
- C20let leaking rear crank seal?? HELP!!
- 1litre box on a 1.6 engine
- Neso Racing ?!?! Not Racing at all :-(((
- saab power as c20lets cost to much plus wanting to be diff i would like to go do
- possible camshaft problem
- Corsa strengthening kit
- Turbo size vs spool time
- oil cooler into v6 calibra
- y32se tuning advice and info
- Saab Power
- c20let no boost 4th an 5th?!
- Calibra C20let downpipe size?
- Corsa c20xe engine mount problem
- striggling dit my dtuk box to my corsa
- f28 onto zlet, what fly wheel and clutch
- c/x16xe head cams
- poor running c20xe
- Will c20let yellow injectors be ok on evo5
- seh cam
- C20xe Fault Code 48
- x16xe wont rev over 4000
- hydraulic clutch on f28, conversion.
- C20LET Problem
- Anyone done this before? Zafira VXR/ GSi Boost pipes
- xe cam in c20let setup help please :)
- C20xe corsa mounts.
- Z14XE rev limit
- xe / let cylinder heads
- X16xe g/box and flywheel help?
- inlet manifold for z18xe
- HELP!!! c20let idleing at 1500 rpm
- zlet water pipes
- Changing F20 Gearbox on Cavalier SRi
- Poorly C20LET - struggle on high boost
- How do i fit an oil pressure gauge to my v6?
- EDS Phase chip copies?
- Play in C20LET Turbo Housing - Repairable?
- help nova c20let miss firing back firing on boost
- Cleaning alloy... Head etc
- c20let oil pump
- Twin scroll turbo's
- vectra z18xe engine
- Early 20xe running problems
- 1.4 ecotec sluggish when warm
- K16 water unions/blanking plugs
- Flatulent pooper moment - V6 cooling system/bleeding?
- C20let Vacuum hose
- how to get power from zafira gsi ?????
- Gearboxes
- t4 turbo - power expectations?
- What bhp should i expect from my c20let
- gsi inlet manifold gasket
- x25xe into astra g
- Equal length drive shafts
- xe/let oil cooler thread size
- Spare Connector?
- gearbox trouble
- f28 into astra gte16v
- turbo chatter on my z20 let
- Astra Mk4 1.6 8v X16SZR Engine Management Light and Shakes When Turning Off
- corsa c20xe stuttering
- Choosing big turbo for hi spec engine
- C14SE MAF Sensor Location???
- Astra 1.8 SXI 2001 Engine Change
- x16xe idle
- x14xe camshaft identifying????
- Convert an F23 hydraulic to cable clutch
