- just wondering on any info
- Ecotec to XE
- removing mesh in afm?
- vauxhall cavalier gsi c20xe red top
- Z12XE - Does it have a precat?
- Camshaft swapping?
- Calibra V6-LET
- URGENT! Mbe help needed for MOT! Anyone got a map I can borrow!?
- F28 gearbox
- 16xe powerbox mods without remap - experiences
- Panel Filter vs. induction kit?
- In-car Fpr gauges....
- A question on exhaust heatwrapping...
- Throttle Position Sensor
- 1993 cav
- astra Turbo 99 fuel filter location ??
- marks on pistons
- R1 Carbs Help!!!
- Error 19 - Top or bottom sensor
- c16xe
- Inlet Size - V6
- xe or let ?
- c20seh into nova?
- C20LET injectors?
- c20xe throttle bodies
- Will a C16XE headgasket set fit a X16XEL?
- c20xe ecu wiring diagram
- Distributor part number for Astra C14NZ
- no spark
- mk3 astra gsi idle
- C16XE belts
- AFM and MAP testing.??
- redtop turbo problem
- Corsa x14xe please help
- fitting c20let loom in corsa b?
- which crank?
- Fram filters
- X20XEV induction system upgrade???
- is a c20ne bottom end casting same as c20xe/c20let
- nova f28 g/box mount
- Power Streeing PLEASE HELP
- clutch!!!
- Oil leak from camshaft seal.
- co emmisions
- calibra drive shaft removal
- Let boost problem
- XE to LET Information
- Fault code
- c2.0let cooling
- Best place to buy a 'performance' panel filter.
- f28 gear oil is this right?
- Fuel consumption report
- Corsa C20let uprated fuel pump....WHERE?
- loss of power due to exhuast?
- can i test my crank sensor with a volt meter
- X18XEV head swap
- clutch kits
- C16xe alternative flywheel/clutch
- Very noisy
- Corsa redtop conversions
- Clutch cable change on a Td cavalier
- Nova C20 let keeps dying
- Melted or shattered valve?
- ZLET Oil Pump changing?
- Can anybody help?
- tb for less than a grand??
- C20 LET part no. request
- Megajolt - C20XE
- 20xe Injectors
- carbon cannister
- 2.0 8v tuning plz help
- corsa let+f28
- Evo 5 LET Nova Problems again...
- LET Cam Specs
- Wiring Loom
- What is a Screamer Pipe?
- Engine code query?
- 17 td lack of power and noisey engine
- what gearing
- F13 Gearbox
- Final silencer c20xe differences
- v6 engine into astra gsi
- Anyone bought a tech2 interface from Ebay?
- why are these so cheap?
- Crankshaft sensor from a cavalier V6, and a 3.0 omega v6, the same?
- what is the poly v belt
- fixed alternator and poly v belt
- Corsa LET belt sizes
- Broke my ford again :-D
- corsa xe pulleys
- nova let intercooler problem
- Powerflow exhaust questions
- vauxhall senator 3.0 24v 94
- Dizzy Engine into Dizzy-less Calibra
- 3.0 omega starting problem
- astra mk3 throttle postion sensor
- c2.0let cooling diagram
- exhaust differences mk4 astra turbo and non turbo
- Where is my charge relay?
- c20let valve guides
- Evo 5 chips top and bottom.......HELP!!
- E-Ram Superchargers
- serious help needed!!! fault codes on ecotec
- c2olet pk ecu
- methods of testing an EGR valve - X16XEL..
- Calibra Turbo clutch
- peugeot 106 gearbox and drive shaft identification
- head bolts on a LET
- Wiring an LET loom into a Nova
- ultimate C20LET
- 1600 16v ecotech - starts then dies
- let misfire at high revs only
- 2L cam into a 1.8
- C20XE Inlet Circumference ??
- Let elbow removal
- C20LET error code
- where can i get......
- turbocharging and modifying a 20SEH/C20NE??
- c20let question?
- c2.0let coolant diagram,
- o2 sensor wire
- c2.0let high idle
- f28 problems
- gm head mod
- Turbo c20xe help needed please
- Removing Oil Gallery Grub screw
- F20 4x4 box into 2wd help
- Astra 1.7 DTL Feul pump Exploded diagram needed
- C20Let Calibra EVO5 boost problem
- c20xe wont spark after engine conversion
- c20let wiring diagram
- Spark Plug Gap for GSi2000
- x14xe troubles!!
- Dizzy assistance
- engine conversion
- c20xe mounts - for anglia 105e
- c20xe wont start
- dropped valve
- kent cams
- Looking for Trhottle video
- 1.5 TD ponderings
- Can I Do Paper Clip Test On My Car With Imobiliser Armed???
- cavalier transponer rewiring help please
- bad fuelling. over fuelling
- let wiring
- custom exhaust places nr sheff or that area
- engine loom
- 20se conversion into corsa b.
- How many stages in headstud torqueing??
- MBE 967 mapping query
- nova diesel
- mk4 xe/f23
- X20XEV onto a F15
- gearbox noise?
- let engine loom
- Understanding Cams
- let conversion gear mount question?
- X16XE Fuel vapour pipes, two vaccum pipes left over?
- Coolant Temperature Sensor
- oil spray jets c20let
- Kit Turbo In My Tigra
- best head gasket for c20let
- Z20LET idling fault?
- 2.2 Petrol Headbolt Torque Settings
- Ecotec engine number
- oil light wiring
- Gear Selector
- let 6 speed
- Astra Twin Port stalling and rough idle
- gearbox in opel tigra
- Tigra Immobiliser Problem
- Calibre Turbo Injectors
- C20LET F28 first gear sensor??
- Car will not start
- alternator bracket
- X30XE induction.
- c20let cutting out
- Starting problem.......
- happened to anyone else??
- rounded water pump bolt
- kkk flange?
- Where is the coolant going?
- Transponder and chip on the key?
- LET cambelt cover
- Redtop Radiators
- spark on mbe c20let running dispac
- My astravan wont start :(
- is it a oil sensor? xe
- SAGUM dispac - firing order????sbd tb kit boys help
- Running on 2 cyls SBD TP208
- Distribuitor For 1600 GSI
- help cavalier ecotec problems
- converting a 4x4 to RWD?
- Fitting Valve Guides.......
- Baggy Sloppy Gearbox
- antifreeze
- astra gte ecu loom question
- How do i fit dump valve to cali turbo
- Gearbox Or Gearbox????
- How to repair this two fault codes of C20XE---> 57 & 94
- what are these plugs on a c20let loom?pics
- Half omega half vectra engine HELP
- ignition outputs
- Independent rear suspension onto astra
- X20XEV Ph2 GSI Cutting out HELP!!!
- nova gte/gsi engine into 1.2 corsa?
- engine parts
- xe coil pack p/n
- do i need this wire
- Nova C20LET on Evo 5 ... misfiring when on boost...
- nova c20xe exhaust
- Calibra Turbo Clutch Replacement
- Fitting Vxr Gear Lever
- V6 into MK3 Astra?
- Cylinder Head - NOva GTE
- need to know 4.18FD speed vs gear ratio
- let into astra expansion tank question
- how to change a WATERPUMP
- valve springs - xe/let
- corsa BHP
- Fuel pressure on XE Redtop
- differences between vecra engines?
- SBD TP208 air filter back plate
- pj ecu
- my nackerd waterpump
- where can i get this fitting(mvaux waistegate????
- Twin 40s, To be or not to be???
- Difference between C16NZ, E16SE & C16SE
- C20let matrix product codes EPC CD?
- high Co/HC cat or Lambda.??
- Ecotec - engine fault Help please
- Good spec Bottom end for a XE?
- engine warning light
- How much oil for the f28 gearbox??? ASAP!!!
- Does the paper clip ECU FAULT CODE reading work on DIESELS?
- mk2 gte turbo
- astra mk3 gsi c20xe smoking round corners
- removing inlet manifold c20let
- corsa MOT emissions failure HELP! ASAP!!
- ARP con-rod bolts
- change engine
- c20let smoking??
- can you over throttle? as in too much
- vectra 1.8 16v revin at 4000rpm
- bike carb ma xe
- Simtec 56.5 ECU immobiliser wiring
- c20xe ht leads
- C20LET spark plug pictures, standard, uprated, high boost
- C20LET engine number?
- Corsa B: F20 removal, input shaft
