- Corsa b x14xe > x20xev conversion need to pick some brains :D
- c20xe crank re-grind average costs ? advice ?
- forging a z20let/h
- car failed mot on emmisions (redtop ) carbon emmisions(Hg)
- 8v turbo project
- Breather Modifications on WTCC ENGINES.
- Difference between XE and let cams
- c20let oil problem
- nova sri v6 any more bhp mods ? PLZ
- ebay turbos
- Engine Builders
- Vectra 2.0 gls running on 3
- what tensioners fit
- c20let corsa b steering rack removal?
- new turbo help
- air flow metre help
- x20xev arp bolts
- c20xe floodin plugs??
- c20xe water pipe on the head?
- VXR engine in Astra GTE mk2
- XE Management
- what direction fluid radiator for c20let
- 2.2 tid not starting
- Vectra X20XEV not too healthy. Very down on power!
- gt30 and dimensions on an let
- c20xe easy mods for more bhp?
- Power steering issues corsa b
- Vaccume points - C20let & Mk3 Astra
- astra mk3 help
- mk4 astra redtop?
- Starting engine help
- Nova exhaust manifold
- What fuel on high compression xe
- Z20Let oil burning help
- Z20LET Boost Controller Problem
- gearbox mount broken on way home from MOT
- Corsa v6 speedo problems
- Misfire and EML flash under heavy load - 4th and 5th
- mk4 astra van temp gauge
- corsa turbo help
- 1.4 Cam into 1.2?
- 300bhp injectors
- Zafira. What fuel pressure
- can i buy smaller exhaust studs for my let
- new rings and bearings
- c20let vacuum pipes where do there go..??
- This crank any good for anything other than junk?
- Rebuilt c20xe overfuelling
- v6 heads x30xe heads onto a 3.2 y32se? v6 guru needed :-)
- small block webber carb manifold, what is it??
- are these plugs ok for z20leh? NGK platinum BCP7EVX
- changing from coilpack to dizzy
- z20let turbo choice
- Nitrous activation on a car with fly-by-wire throttle...?
- Engine revs stay high. intermittent fault
- help with rough running c20xe
- imersher twin oval
- Z20LET Fault Codes - Help...!!!
- Corsa b V6 ??
- **help..corsa x14xe running rough**
- Oil cooler info...
- c14nz into c12nz
- Vectra B Driveshaft question
- Best Place for Corsa C20XE Performance Exhaust System
- C20let plenum chamber worth the money?
- how to open F23 gearbox??
- Rwd sump on a 16v redtop
- 20seh coil options
- z16se astra fault. symtoms miss fire
- Suspect DPF problem 04 vectra estate (150) please help !
- vxr afm problem
- F18 WR on 13" wheels - Best LSD, ATB, Gripper ect ect ect
- best plugs for a z20
- Corsa X14XE airbox question
- 1.7 cdti Cylinder head
- Which rtv sealant is best?
- x20xev head bolt settings
- X25XE sump on C25xe
- F28 hydraulic mixing fluid and oil?
- Help with f16 release bearing part number
- c20let rocker cover
- Resetting Z20LET ecu
- best exhaust for a carbed XE
- Corsa B GSi Engine - TPS fault?
- What engine to use for conversion
- top hat and tb issue!
- corsa 1.4 16v sorta spitting and losing power struggling to rev up
- let/xe FLANGE!!
- vectra V6 equal length shafts into F28
- corsa c16xe decat fit on x14xe corsa?
- redtop corsa cv joints
- Name the pipe
- new loom plugs
- Massive help needed! opcom diagnosis electrics
- astra gsi z20 fault codes
- c20let steel rods with arp's.
- c20let intermittent boost issue
- penny valve
- X16XEL bad idle
- x25xe spark plugs
- Astra F hatch Swap - advices
- C20xe tensioner question
- Corsa B - No drive
- x20xer engine
- c20let not starting
- Z16XEP/Corsa VXR cam gear to cam fitment
- Nova corsa 2l shafts same or different ?
- C20LET/C20XE Conrods fit X30XE
- 1.9 CDTI 150 Engines
- c20let alternator?
- best set up with saab red injecters
- Gear linkage problems
- XE/LET inlet manifolds
- Corsa C 1.4 Overhates and sluggish
- 1.4 Nova timing marks?
- Tigra 1.6 Overheating and ECU light on
- A few second rattle !!!!
- does my clutch look worn out ?
- kkk16 wieght
- C20XE Rev limits with double valve springs?
- easy gearbox question for you
- nova tank question?
- Corsa C20XE Air Problem?
- Advice with Z20LET rebuild
- running xe for fist time since rebuild
- C20LET/XE/Redtop Carbon Fibre Heat Shield
- X20XEV oil leak from cylinder head
- advice on fitting c20let adjustable fuel regulator.
- Corsa B Fuel Breather??
- Some mapping questions
- Astra 1.8 bertone wiring
- 16 sport into 12 8v
- Is this an SBD pressure relief valve?
- idle problem confirmation
- c20let fuel feed...
- High spec C20LET Nova, advice on remaining parts to buy please?
- c20xe bottom end
- F20 onto c16xe help?
- F28 stuck in 4th
- F28 with plate diff - look in the hole
- Z20LET oil relief valve in C20LET pump
- 2 litre 8v Turbo advice
- KCAST 1603B cams
- Snap Bittwin Daewoo racer & Astra Mk2
- Power cap question corsa c20xe
- power boost valve on C20XE please help
- How the fook do you get the sump of an 04 vectra cdti 150 ( oil pick up in the way)
- need help. f20 related.
- Converting an xe block to let
- how do you remove the injectors on a 1.0 corsa b ecotec any 1 know ?
- clutch fitting problems
- Piston rings problem C16
- C20XE inlet camshaft question
- Best engine to Turbo for Astra F ?
- Mk5 Astravan Coolent Leak... Heater Matrix? Found Drip To.. :-S
- m4 astra coupe c20let
- Tigra X14XE don't fire up
- R1 bike carbs, What connections
- c20 let injectors
- c20let ECU pipe
- C20XE Corsa with GOTECH Management not firing up, But all good signs!
- bike carbs
- Genuine v-max evo5 chips and power wheel
- f28 into v6 flywheel setup??
- Please help! reading ECU fault codes X20XEV
- Astra mk4 2.6 v6 convert to z28net
- c20let tapping top end!! bad!! Help!!
- MAF sensor good or bad
- Z20LEH/LEH Rods/Pistons
- oil filter housing gasket?
- Cavalier gsi 4x4 one piece prop
- EM Light on high boost?
- c20let bedding in rings+shells
- tx autosport I beam rods
- Speedo reading 2x
- Astra G 1.8 Sri running problem (with fault codes)
- vauxhall corsa 1.4 16v 1998 gearbox oil?
- whats the purpose of the one way valve on a let throttle body
- C20XE Engine Mount Pic
- help with some C20LET head queries!
- cavalier shock and springs?
- How to run a return feed for corsa c z20let conversion?
- petrol pipe fittings to c20let fuel rail...what size are they ?????
- z20let compression test done
- c20let pistons in x20xev
- Astra Envoy 8v
- Xe / let cams
- hose
- advice needed c20let evo 5 chips
- c20let wont idle when engine is at normal temp
- wiring for fuel pump Cav Turbo
- rocker cover breather pressure
- Z20let rear boost solenoid?
- megajolt
- quick q - will a calibra xe decat fit an 8v?
- C20LET HELP!! in East Yorkshire
- fuel pump not priming?
- exhaust help urgent!!!
- C20XE dodgy idle - still ongoing!
- any good diesal men
- Fuel leak problem!!! advice please
- C20LET - Dump valve help
- Taking off a F28 in 10mins
- y26se Vectra fan running constantly, poor starting
- C20let starter wires
- idle control issue
- Early 20xe missfire?
- Silicone Hoses
- Z20NET in a Corsa B
- Twin weber 45 manifold
- C20let backfiring under full throttle
- cleaned ICV now it wont start c20xe
- z20let xev cams
- GTE radiator question.
- LET bearing clearances
- What's this engine?
- Changing F28 Final Drive?
- boost solenoid astra mk4 coupe z20let
- planning engine build
- cavalier gsi 4x4 prop question
- x16xe air con removal question
- Corsa C20LET, RC 750's Problem?
- F20 gearbox
- astra 1.7dti starting starting problems
- How to convert automatic to manual
- Aluminium Radiator for vectra 2.5i v6
- Help!!! Where to find a 6 speed 1.7 Diesel gearbox for works astra CDTi van 2008
- Big block driveshafts
- astra gte 8v
- what causes a 1.4 8v spi engine to over fuel?
- how can i report a member on here that,didn`t sent me a bumper.its been a while now
- k16 hybrid?
- c20let how the oil system works
- 2.6 throttle body diameter?
- Wats neeDed to fit a oil pressure gauge to c20let
- c20let problems, cam caps and starter smoking!?!
- About to start c20let do i need to bleed fuel lines?
- whats the max bhp astra vxr injectors can handle?
- will a vectra 2.2 starter fit my c20xe?
- Corsa c20xe F20 - Quick Linkage help?
- Clutch problem, c20xe. F20
- MK 3 Astra: Burning oil smell
- Twin 45's. Fitting and setting up advice needed
- part number 2.2 rocker cover gasket
- z20let rebuild
- Rod change F23?
- LSD fitting
- Equal length shafts - Which cars?
- Xe exhauist manifold onto ecotec, anyone got pics?
