- mk4 astra drive shaft same as mk 3? / changing driveshaft
- why is my fuel pump pulsing?
- c20let actuator
- cam sensor help
- timing belt 1 tooth out?
- apexi avc-r boost controller
- What do you think of this air filter??
- c20let upgrade to 350bhp
- C16xe into nova using Multi V Belt alternator (quick question)
- Compression on XE
- Log book changes
- Gearbox feels too tight
- oil spray jets
- rear disk to corsa b
- c20let major problem
- Custom Wiring Loom
- NE and SEH engines????
- Fitting catch tank-16xe
- After 6 months im LETing thanks to mig.
- SPark plug holes filling with fuel? Help please
- calibra rear diff
- corsa 1.4 16v rattle
- vectra went bang
- is it dangerous ?
- 1.7td fuel pump
- 1.7 td astra fuel pump
- common problem?
- cav carb hard 2 start wen hot???????
- injector colours
- c20let inlet manifold and throttle body?
- Can someone comfirm what this Part # is
- how good are mvaux
- Help needed 1.6 cav clutch
- nova linkage
- Let cold start running probs
- nova c20let swirl pot
- afm
- Speedo drive broken in F28
- help please help! c20xe problems
- Which side is fuel feed and return?
- more power from a vectra 20di
- kent,essex,sussex carb tuners???
- c20xe/r1 carb manifold... where can i get one?
- Corsa xe gearbox
- Mounting Blow Off valve into a Z20LER??
- help short shift gear for vectra gsi
- low-temp fan switch??
- Calibra Turbo clutch - which one?
- will this fit??
- Is the afm of cali turbo same as the 2.0l afm??
- quafie atb diff tyre question
- C20XE Coolant system
- Diagnose this car engine problem...Rover Headgasket?
- What BHP you got 1600 16v ??
- Z20LET Wiring Diagram Needed.....
- head x14xe
- mk4 astra c20let gear box best i for it
- Where can i get guides for my head ??
- Lambda sensor wires
- help let cutting out!!!
- X16XEL water pump marks??
- Car cutting out once temp reads above 90
- Astra V6 queries / Omega V6 queries
- calibra 2.0 8v cold start
- ast mk.3 1.4 running cold
- C16XE lower spring retainer removal
- idle please help
- astra 1.7td gm engine 1.7dtl
- Manta Inlet Manifold And Manta 2.1 Carb
- temp gauge...
- info needed on part numbers
- what engine should i use
- nova gte engine
- v6 burring noize? air con apparently?
- c20let pulley
- C20let P.A.S. pipe (fs)
- Exhaust Wrap?!?!?
- engine management light & chips C20LET
- turbo rebuild price??
- Yet another cam belt question...
- Nova big block outer CV's?
- f20 let gearbox problem
- fault code 13 on c20let ?
- Where can these be found?
- management light
- f28 starter info required plus other v6 stuff
- tigra c20let running bad
- 1.9mm head gasket
- Tightening head bolts: mystery bang!
- vectra r reg kicking like a bronco
- XE gated and baffled sump?
- je piston rings and specs
- dump valve (c20let)
- weight driffrences
- Hesitation when accelerating
- best air intake (z20let)
- Which diff for f28
- bhp ecotec
- astra mk3 308mm discs
- 1'ltr Corsa problems
- Spark plug change
- DumpValve Help 4 Z20LET!!!!
- c20xe in corsa gsi
- help with cambelt
- oil pumps mk3
- c20let oil pumps
- c20let oil pumps
- Nova gsi throttlebody and manifold onto corsa sri engine?
- vectra 20 di tune
- snapped cam belt....
- let eds phase 1 power???
- Chipping 2.2 DTI Vectra (2000)
- c20let turbo advise
- diff bearin preload setting??
- doing my head gasket
- xe conversion
- tirga trouble
- fitting new oil pump on let xe
- Fitting a LET and F28 into a Mk2 Astra GTE 8v
- z20let head gasket on c20let, tight?
- PLEASE HELP X14XE engine hesitation
- over heating
- just blown my head gaskit
- g-tec
- Corsa B ECU Reset
- 1.7 CDTI question
- Thread sizes on xe blocks (oil temp)
- no fuel on x16xe
- DIY Stylee oil pressure sender installation (Get broadband)
- Is this my engine number
- help needed on wiring please!!!
- C20XE Dizzy options.
- Were to buy V6 tuning parts?
- Cam belt on xe??
- engine code
- short-shift for gsi
- Cleaning iridium plugs?
- Adjustable Fuel Pressure Reg
- Mk5 Astra 2.0t SRi (5 door) 'S' button?
- Vectra V6 help.
- F18 to F20?
- anyone know what would cause these codes. x18xe
- vectra 2.0 dti fmic and fitting
- Search for the missing spark
- engine code help
- Twin 40's...
- diff help
- C16SE ECU engine managment light wiring...
- C16SE oil pump, oil pressure sender...
- Dump valve quiet ?
- Clutch dodgey maybe?
- gear selection sloppy help.
- Engine managment Light
- Fitted my Recon Diesel Pump to 2.0l 16v astra diesel but not running?
- Corsa 20XE M Tech Quick Shift
- x14xe head gasket advise
- Original Height of cylinder head 2.0 8v ???
- Irmscher chip
- Clutch problem on C16XE
- nova sri to gsi conversion wiring
- GearBox ratios
- ekotek valve
- vectra 2.0 16v gearbow problems help!!!!!!!! please
- ecu problems
- Remapping
- Anyone near Bradford fancy helping me change water pump & cambelt on a redtop??
- Redtop - One stop ultimate tuning guide?!
- breather mod
- voltage vs AFR from standard xe lambda sensor
- C20LET running problems
- Corsa C20LET
- C20let head bolt torque settings
- sergestions for nova TD
- My C20let is smoking! HELP
- ECU Readout [Pin trick]
- Big Petrol Leak!!
- oil change after piston ring run in
- help!! vectra gsi tuning
- C20NE misfire
- lsd for f28
- C20LET downpipe, thread for lamda semsor M18 x 1.5 ??
- what spark plugs c20let??
- X25XE into cav
- "porous" head fix in situ? Just how bad can it get? lol
- Gearbox Issues!
- rally gearbox (RWD) for C20XE
- c20let manifold vacumn pressure
- c20xe temperature
- f28 clutch frication plate - anyone have one?
- c20let bigend bearings
- holding back really badly
- fan on bumper side of rad, which way do i want it spinning?
- water pump failure? what to look for?!
- Clutch problem
- Help me choose a turbo for my engine
- Wont run with fuel pump on?? C20xe
- 8v sump gasket on c20let! tap tap tap!
- High tickover (XE)
- My plans Z20LET
- X20XEV Holding Back/Hesitating
- C16XE
- Nova 1.4SR head on a 1.2 block?
- Cally turbo phase 3 boost prob help!!!!
- 8V Turbo.
- xe into a nova, help please
- mk3 cat
- what should the psi be on td astra ??
- xe and let dizzys??
- c20let idle speed control valve interuption??
- mk3 astra airflow meters and exhausts!
- snaping a 8v rod
- bizzare let cambelt problem
- Lpg Conversion!
- c20 xe loom
- quick question
- f25 question
- v6 inlet systems
- What fpr for a c20let ph2?
- this headgasket look right?
- Fuel pressure reg for v6
- Sump gasket help needed
- Gearbox for Astra G
- F28 2WD rear engine mount, broken, options
- Fitting bike carbs tech guide (pdf)
- New Gearbox needed
- Turbo/Supercharger on an X30XE
- XE misfiring - Was fine earlier?!
- let, boost drop off????
- C20XE engine earth
- i need to compare 3.0 v6 or redtop
- Fuel pump question, got a bit muddled
- 3bar reg & blue injectors..
- Getting the most out of a C20XE
- quaife diff
- Corsa C 1.3 CDTi engine problem
- extra bhp
- oil cooler
- Corsa X10 > X14xe conversion fault code question
- Having a daft moment - XE/LET oil capacity
- which AFM 2.0 8valve ???
- c20 xe oil pump + pistons
- ATS 1.4 16v
- 0-60mph?
- Omega Strut Braces
- Length of a nova short drive shaft?
- need my driveshaft out, do i have to .......
- C20LET running problems fueling?
- X16XE block over-bored to 1650cc
- XE running lean apparently...
