: Engines and Transmission
  1. Vectra v6 x25xe full rebuild NO START!
  2. Vectra vxr into astra g????
  3. C20LET No Oil Pressure?
  4. astra h, sri 20t code p0704
  5. Vivaro Engine Problems
  6. Blown Head gasket C25XE cav V6
  7. fitting c20xe
  8. mk3 gsi turbo build ,,what turbo set up
  9. Help heat exchanger
  10. urgent help rear mount on 4x4 Cav GSi !!
  11. Corsa B 1.7D won't start
  12. Vernier pulley jamming the engine!! HELP
  13. Jetting / Settings for DHLA twin 40s
  14. corsa ecotec 3 cyl engine
  15. Drive belt tensioner question
  16. More codes
  17. Radiator Bleeding; Mk3 astra 1.6 8v SPI
  18. Klasen-Motors Cast-Iron Exhaust-Manifold for Garrett-Turbochargers
  19. c20let bigends
  20. wossner piston ring part number?
  21. 2nd hand paddle clutches - what are they worth?
  22. Redtopping a Mk4 Astra
  23. bought an 1.6 8v - what to do with it?
  24. 1256 help please
  25. c25xe throttle body enlarging/ tc flap removal
  26. c25xe fault code help
  27. Some questions for Megaqsuirt 2 or 3 c20let
  28. Help conversion shafts
  29. front gearbox mount F28
  30. Can anyone identify what LSD is fitted to my gearbox?
  31. Z20let running no dump valve
  32. 1.2 Chain
  33. a little jumpy
  34. Single V crank pulley
  35. 2.0 corsa...what radiator to use
  36. c18xe cylinder head
  37. swirlpot
  38. x16xe/L help please
  39. vectra b hydraulic clutch problem
  40. AFM issue will it cause damage
  41. Astra 1.6 club MK4 lumpy and slow?
  42. Z20LET Airbox
  43. info on x20xev?
  44. astra van starting prob
  45. rear diff Cavalier
  46. 1999 astra 1.7 TD wont rev past 3000 rpm and loads of blue smoke
  47. Astra Mk4/Zafira clutch slave cylinder F23 gearbox
  48. c20let random spark issue
  49. Which gearbox?
  50. Fitting a Webber 2WD cossie adjustable fuel regulator?
  51. C20xe crank
  52. X18XE Engine
  53. kkk16 Turbo Oil Feed Restrictor Bolt
  54. help needed with a corsa c semi auto!
  55. Overheating - steam pouring out under the bonnet X20XEV
  56. help, i need a recon z20let
  57. xe cam into c20let help
  58. fuel pump on cav gsi
  59. Ecotec Valve Stem Seals
  60. Possible Head gaskit failure
  61. corsa xe mounts
  62. Rebuilding engine, hydraulic lifters?
  63. V6 into astra mk4 van
  64. 1.0 12v engine fault
  65. Rebuilt xe blue smoke on start
  66. c20xe in corsa c
  67. C20LET EDS phase 2 spark plugs and actuator questions
  68. xe conversion, cv joint question, for corsa b
  69. Vectra gsi PROBLEM with tc light flashing
  70. New Car, thinking about LPG
  71. Oversized valves +2mm inlet on my head is it worthing? and prooblems..
  72. Quick exhaust question
  73. zafira gsi gearbox
  74. tigra exhaust
  75. What ECU code should an Astra GTE 16v non-lamda sensor
  76. Low Oil Pressure
  77. c20 torqing?
  78. f16 on x25xe
  79. Engine swap - mk5 astra - vectra c
  80. fse blanking plate
  81. Strange boost problem
  82. vauxhall diesel zafira service
  83. c20let cosmetic gasket
  84. C20let bearing help
  85. silicone joiners for carbs to manifold
  86. EDS Stage 3.5 z20let
  87. piston rings xe v's let....
  88. would like to no where to t piece dump vavle on z20 let
  89. vectra c engine swap advice please
  90. F23 gearbox, what oil?
  91. xe lightweight flywheel
  92. A few "Saab engine conversion" questions...
  93. Twin plate clutch release bearing issues
  94. Air temp sensor on top hat .
  95. Garrett gt3071r on c20let
  96. x25xe into mk3 (again!!!)
  97. What are people's opinions on K-Seal?
  98. difference between z20let,z20lel,z20ler
  99. Z20LET Clutch GMan
  100. Courtenay Balancer Shaft Deletion Kit Z20LET
  101. C20XE Code 015
  102. C20xe, Mild Kent Cams...... Or not?
  103. f28 quaiffe atb
  104. Astra g coolant probs
  105. C20let Lean off boost but fine once on ... ?
  106. 1.0 8v into 1.7d corsa
  107. Please help!!!
  108. C20LET wont rev over 3500rpm without eml and popping and banging.
  109. C20XE Compression question
  110. x16xe idle hunting and flat spots
  111. inner cv joints for 2ne ito corsa
  112. C20XE Mods, Coilpack Type.
  113. r1 fuel pump
  114. 20xe wont start, possable ecu fault?
  115. z20let manifold blowing
  116. vectra x20xev and astra x20xev
  117. f28 clutch upgrade
  118. Very Bad Caster Help (Nova with F28)
  119. Twin 45 / 48 Inlet manifolds
  120. c20xe Cam Sensor (coilpack type)
  121. BCR8ES plugs
  122. 1.3cdti corsa, found coolant in gearbox bellhousing
  123. c20let hard to start and missfire under low load
  124. C20xe: Code 48 and Lumpy Idle / Revs
  125. mk4 c20let power steering problem
  126. Redtop dyno report running weak at full throttle 2.0 xej
  127. C20let won't start
  128. vectra c 2.2 sri derv boost pipes
  129. C16xe idle issue
  130. Corsa 1.8sri FSE / POWER BOOST VALVE
  131. p0443 code causing eml can you help someone with no idea please ?
  132. Interchangable ECUs
  133. KKK16 Failing?
  134. ecu pin number for lamba input
  135. C20XE throttle bodies, aftermarket management.
  136. C14SE EML problem?
  137. Tunning z18xer
  138. F13 Equal Length Shafts
  139. How do coolant caps work ?
  140. 1.1 corsa
  141. lumpy idle
  142. LET Conversion, final few questions!
  143. C20XE > Transaxle
  144. best place of oil temp sensor?
  145. Misfire on 2 & 5 on vectra V6
  146. Best head gasket for hi boost ??
  147. misfire at low revs
  148. f20 0r f28 in a corsa turbo?
  149. Help after cambelt and head gasket change- vectra
  150. manifold builders?
  151. c20let fuel
  152. Astra mk4 2.6 v6 cut out fuel pump not working
  153. Everything for PH2ing a LET
  154. f28 diagram required help
  155. eds ph 2
  156. corsa c20xe mods worth it?
  157. Using high octane fuel .
  158. 20xe injectors?
  159. x17dtl bad diesel knock?
  160. 750 yamaha throttle bodies
  161. mk3 gsi tap/tick
  162. Heat wrap...
  163. Supposed VXR Bottom End - LEH/LER??
  164. C20 let running problems
  165. c20xe head bolts
  166. spec to bore block for 87mm wossners?
  167. Best place to buy piston rings from?
  168. where to?? gas flow, port and polish z20let head
  169. c20let slight misfire
  170. Tigra cutting out
  171. Help Needed: EML Light Intermitantly Flashing X30XE
  172. Gearbox Guru's - Hex Vs Straight
  173. Questions that I need answers too...
  174. another v6 tuning thread
  175. VX220 question... 2.2 to Z20LET
  176. Cavalier Turbo running really rough.
  177. vectra timing belt help please
  178. Z20LET
  179. Garrett GTX3582R
  180. c20let with x20xev engine mount and zleh belt and roller setup
  181. c20let after market management?
  182. Help bypassing secondary air pump on a v6
  183. help with 3.2 throttle body mod...
  184. X20XEV Calibra Tuning
  185. Breather Mod For C16XE
  186. corsa sport engine mount
  187. corsa c20let gearbox mounts
  188. td05 turbo where to put breather c20let
  189. Corsa XE - weird coolant temp sensor fault code
  190. Small Block Tuning
  191. Ok - there's tight and .........
  192. vectra c z18xe misfire
  193. vectra c air flow meter
  194. Part number required for Vectra V6 Throttle body gasket please
  195. EML light since new exhaust fit
  196. Z14XE no power, no codes, no hope!!!!! help
  197. XE keeps dying
  198. C20xe rods in x20xev??
  199. Pressure relief valve removal
  200. 1.4 sr nova oil pressure switch
  201. v6 lambda sensor plug location?
  202. cavy 4x4 prop rubbers
  203. Vectra C oil in coolant
  204. Running a coil pack on a c20let
  205. c20xe into Vectra cheaper than fixing x20xev?
  206. corsa b c18xe conversion wiring
  207. c14se/c16se ecu?
  208. Cant get my F28 into reverse !!!!
  209. k04 questions
  210. X20XEV ladder
  211. C20let Conversion questions
  212. saab 2.3 gearbox onto c20let?
  213. c20let mk3 astra rear f28 mount problems?
  214. vectra c - oil/water mix. Help please
  215. C20LET and Forge Actuator
  216. 1997 Vauxhal Astra 1.7TD Oil Leak **parts required**
  217. evo turbo on c20let
  218. Corsa / combo 1.7d to 1.7 td
  219. cost of c20xe rebuild?
  220. z14 xe running problems
  221. who knows about Vauxhall CDTi engines? help needed
  222. vectra c help please
  223. 2000 2.0 dti astra won't run over 4k rpm
  224. Corsa 1.0 12v down on power...
  225. 1.4 8V corsa, head gasket questions
  226. Walbro Fuel Pump
  227. calibra x20xev running hot
  228. exhaust wrap
  229. mtech v4 ecu
  230. fitting Red DTUK box to Meriva 1.7 cdti help
  231. c20let pistons in z20let
  232. small block 8v engine advice please
  233. c20xe traction control ECU,
  234. c20let max clutch size? 228mm - 240mm?
  235. 1.4L SOHC Water Pipes
  236. TD05 turbo
  237. icv pipe on corsa c20xe
  238. bottom alt pulley wobbling!!
  239. New oil cooler for my project (what thread do I need?)
  240. Cavalier V6 faulty speedo (F25 Box)
  241. Corsa C20XE Died and now not starting????
  242. bike carb'd xe wiring
  243. ICV ?
  244. F20 gearbox Clutch lever problems
  245. electric power steering pump?
  246. Vectra c pipe fitting to astra mk4 1.6 16v
  247. twin webber carbs suggestions, Mk3 Astra 1.4
  248. vectra c help please
  249. c20let knock sensor problem
  250. 20xej over fueling?
