- xe clutch question
- best cams for c20xe
- Z20LET trouble
- C14SE con rod pic
- XE - Replacing Oil Cooler Sandwich Plate Gasket....
- Cav/Cally V6 rocker covers
- Bosch 044 Fuel Pump
- gunson faultfinder
- 1600 cranks
- vectra c intake pipe "how to"
- redtop missfire!
- Engine oil Type for astra gsi turbo
- remove fault light "F"
- Technical info Z14ZEP
- A/f Ratio Gauge!! Wideband Lambda??
- help on engine management light coming on
- Cambelt cover 20SEH/C20NE
- v6 calibra crunchs when i put it in 2 reverse
- heres one for you tech heads!!!!
- Corsa B 2.0 xe wont start
- Has anyone welded a V6 manifold?
- Are chargecoolers efficient for big BHP?
- C14SE con rods
- Vectra C 2.0 Diesel starting probs
- How to remove auxillary belt??
- vxr injectors on c20let
- one way valve on breather pipe from rocker to tophat
- 14se cooling/engine prob
- X14XE Tigra, Poor Running and How to improve?!
- C20let Head Gasket Gone?
- C20XE Engine Problems!
- Cam Belt Change X16XE
- wiring help corsa b
- Carbon canister do i need it??
- Will an f16 fit my cav 95 2l 16v eco?
- clutch release bearing
- What indications do get when...
- c20xe into corsa b help
- bosch fuel pump specification?
- best plugs for x25xe from halfords?
- Lambda Sensor??
- Nitrous Refills
- Frontera Starting Help!!!
- Nova gsi exhaust question
- Corsa sport drive shafts - xe conver.
- fuel pump and swirl pot info
- Doh, Fault Code 74 - Voltage High Air Flow Sensor
- c20let rolling road advice please
- Rev problem
- X20XEV power mods
- Best Facet fuel pump for a 190 brake redtop?
- Engine judder that no-one can find a solution too, HELP HELP
- Low temparature reading on Vectra C 1.8
- hesitation
- 1.4 Flair Single or Multipoint?
- X20XEV with Z20LET turbo, minimum parts???
- Where to get nice quality Jubilee clips
- What Sump bolts to use with XE one piece gasket/baffle plate
- Calibra turbo lost all power-steering fluid?
- f28 gearbox (please help me)
- Phase 2 boost delivery
- c20let coscast head rebuild
- c20let max boost? 56 psi
- Cam shaft sensor location on an 02 plate 2.2 ltr omega
- HKS SSQV fitted... idle problem...
- 1994 astra gsi 1.8 16v(pre ecotec) should i cam it??
- Fault Codes on X1.8XE1 Engine (Help!)
- Dry sumping a LET
- urgent help needed!!!
- Engine cambelt problem
- water sound???
- Brake Cilinder vacuum with Jenvey DTH, question
- turbo help
- Heater not blowing hot?
- where is the hall effect switch
- can u solve my problem no1 can so far so ud have to be pretty good
- An MOT / emissions question... long, sorry.
- Car not 'fast idling'
- Injectors in X14XE
- c20xe is refusing to tickover
- Manta LET gearbox
- fitting quaiffe on f20
- Tiny water leak, but where?
- Diff bearings (useful info!)
- XE rods/piston combo + prices please
- z20let dump valve problem
- gearbox woes!
- Nova C14se fails to idle
- 1.6 16v Ecotec
- C20let
- LET on a manta box
- Water pump
- 1994 astra gsi(1.8 16v pre ecotec??? should i convert to a c20xe"red top"??)
- What do i need to fit bike carbs?
- f18 gear selector pin
- Idea - Adjustable/Variable Ram-Pipes for side draught carbs
- Distributor to Dis pack
- Cav turbo F28 clutch cable problem
- c20xe is idling at about 4000 rpm
- f20 help please
- Z20let help wont run help help
- water pump & timing belt
- How do u fit a dump valve??
- Z20LET Removal
- c20let std boost??
- how to remove water pipe on top of turbo?
- Vectra 2.2
- electric supercharger!
- Helllpppp!!!!! Nova
- zafira 2.2 engine rattle
- Sump bolts
- Pic of a friction plate for a 1.8i cav please
- ARP head studs and head gaskets
- Are RWD drive shafts splined at the hub?
- C20LET Cambelt Change!! HELP !!
- Help Corsa C20 Let not firing!
- How 2 change clutch in 1.8i cav
- (VXR injectors) will they cope with 300-350 BHP
- x16xel low compression on cylinder 1
- Help !! Gear stick problem
- icv and knock sensor wiring
- 2001 Astra 1.4 16v Z14XE ??
- XE brather modification. Whos done it an how does it work???
- c12nz intermittent stalling after 20 miles
- vectra V6 hunting
- Cost Help for V6 Clutch Kit + Fitting
- setting up the autuator spring
- c20let think ive blown it
- cav misfire
- What engine do i have
- Studs
- Vecta a c20ne fuel pipe diameter?
- r1 injection
- Zafira 2.0 DTI lost boost
- reverse light wiring
- Help Identifying clutch type (PICS)
- f28 gearbox bolt thread size
- ecu fault codes
- vectra st200 crank seal
- Thrust Bearing Help
- X16XE ARP Rod Bolts?
- Astra Mk 3 Wont Start On First Turn
- Dyno Graph - Any help with diagnostics?
- Vectra V6 SRI Clutch/Gearbox help
- Throttle body conversion
- c20let wiring
- C20LET or Z20LET ??
- Help! I've never driven a turbo..
- short shift???? which one?
- Tigra 1.6 16v OEM manifold off - problems
- XE corsa drive shaft options
- drive shaft help
- Cam pulley timing marks (bizarre Non-vaux)
- help - sister just bought 1.7td astra van p reg and its overheated
- New battery time! Best one to get?
- which belt?
- Corsa B lower cross member
- hyrdocarbon figure on my mot
- turbo spooling up louder?
- need help with my dads golf gti!?!?!
- torque settings
- timing marks 2.0 ecotec
- what is the 1 way valve on a c20let
- x14xe engine number
- How easy is it to re-build a turbo?
- Driveshafts - F20
- equal length driveshafts??
- astra van s reg 1.7 td gearbox info needed
- Carlton TB on 20SEH
- hall sensor and actuator
- what clutch for a c20let?
- water leak help!!!
- Vivaro cutting out..Injector sensor code?
- sri 1.4 8v shafts
- Quiaffe F20 20XE
- c20xe afm
- c20xe starting problem/misfire
- Answers From The Oil Expert Part # 2
- Engine Managment light.... Help!!
- Corsa C 20XE conversion...
- EGR valve location
- sounds like noisey tappets could be cams???
- What RPM does you std C20LET Boost?
- can i run high comp pistons on a 16xe on bike carbs?
- Engine Codes... Hmmmm
- anyone know how 2 tune the x20xev
- Engine installer in South wales
- Calibra V6 Y32se transplant
- Diff bearings
- Vibration after fitment of lightened flywheel.
- 20xe or what?????
- Vectra cracked manifold woes.
- v6 compression readings
- Saenz rods, peoples verdict
- MOT emissions help
- what fuel pump is best 4 c20let conversion in gsi?
- c20xe rocker cover gasket
- Carbs to a X20XEV
- astra h 2.0 turbo
- corsa conversion
- C20LET slow revving ??? arghhh!!
- corsa 1.4 16v sri
- V6 Calibra Won't start, any suggestions?
- Iridium Spark plugs
- Any Diesel Pump experts in or know where to ask? Not Vauxhall
- c20let onto f20?
- vectra auto loom to manual GB? help please
- 2001 vectra sri 150 2.2
- 20xe installer needed!
- c20let underfuellin do u think?
- best place to get corsa c20let phase 2 setup in scotland ???
- My calibra died on m11 yesterday( check out what happened)
- Corsa oil light
- C20XE idles at about 1500/1600 rpm when warmed up but not from cold
- F28 Gearbox - Should I be worried??
- Engine Upgrade.
- Does this fit to F28 gearbox
- Upgrading Turbo Help
- Evo5 or Phase 2/3
- let into nova q`s
- Fitting an X16XE into a nova
- max lift cam for v6
- Clutch Change
- Engine conversion
- z20let cam cover gasket
- timing marks
- c20xe short oil filter??
- wanting technical advice
- V6 transplant
- vectra 1.7td advice
- what's mahle forged
- 16v head...
- Best fuel pump for Corsa Let
- 1400 blocks??
- nova dizzy vacuum pipe
- HELP!!! corsa LET wiring
- rolling road notts or derby
- Astra Mk4 1.6 16V struugling at low revs?
- Mega squirt C20LET help
- help.. car lacks power..?
- Which Fuel Pump?
- Which Clutch?
- C20let / Nova Gsi Gte 1.6 Alternator?
- what injectors
- Couple of Q's about oil & fuelling (C20LET)
- Has anybody ever changed......
- Fueling problem on c20let.
- how much for a C20LET rebuild?
- Engine problems
- Pic request: F28
