- OMG I've found a Swindon Race Engines C20XE
- Astra mk4 gsi... Problems... :(
- oil pump fault?
- wheres the best place to gas flow a let head
- fuel additives
- help and advise on c20ne turbo conversion ?
- Corsa 1.4 16v inlet manifold.
- Anyone using KMS engine management?
- C20xe corsa 96 non-start
- dai coupe turbo
- cavalier td and astra mk3 tds, rev limit diffences?
- twin 40 webbers onto 2seh?
- Gearbox trouble
- z20leh oil pumb vs z20let
- Valve clearance INFO needed....
- Saab conversion astra g
- cav turbo not boosting
- advice needed for twin 40 carbs
- replacing your ecu
- Vectra B 1.8 aircon removal
- vauxhall red top and gearbox stress
- zafira gsi problem i think!
- z18xe bogging down
- c20let wont start when warm
- Astra gsi turbo tappets
- Wideband product code
- ebc plumbing in hlep
- Is it worth rebuilding xe's or any other engines?
- x20xev tuning
- steel rods oil jets???
- hesitation under throttle
- astra van Izuzu 1,7 DTI 2001
- z20let custom inlet manifolds
- Kangarooing 1.6 mk4 Astra
- 1.7cdti engine cutting out
- arp bolts needed?
- 4 Error codes 1.4 Corsa 16v
- Sounds like a misfire
- Corsa 53 plate, 12 sxi 16v advice wanted please.
- sump on c20xe
- Inlet manifold question
- Some one please guide me !! :)
- Single Line, Non-Return Fuel Injection System?
- standalone mappers in essex
- c20ne Starting And Reving Problems
- EML light flashing...
- oil pressure question...
- TX Autosport LSD.
- Anyone used parts from Pauter Rods?
- how to make a turbo out of a ecotec
- c20xe injectors colours, whats the difference?
- making my xe rwd only?
- C20LET genuine GM belt tensioner
- C20XE/LET head tubes
- threads ripped out of block! where to get hellicoil from?
- x16xe or x20xe in tigra a
- best chain kit for vectra c 2.2
- Best way to fit a new set of exhaust manifold studs?
- Universal water temp sensor
- C20LET smokes on idle
- 1800 Vectra auto cutting out
- cuttng out
- GM part number for astra vxr clutch???
- c20xe camshaft sensor / distributer
- gearbox for 2.0 8V
- wt one would u put on a 2.0l 8v lump
- 2.0 8V Nova - Turboing advice wanted
- Corsa 16v Massive revving on startup.
- need help asap just put c20let it gearbox selects gears but car wont move
- 2.2 Vectra engine rattle
- fault code p0300
- FSE fuel pressure regulator noise?
- idle control valve problems C20XE
- corsa gsi clutch problem omp paddle clutch
- c20xe nova running rought
- what the f help
- 1.4 sri turbo project
- Corsa B 5th gear issues?
- je pistons for an let are they lower compression
- can arp head studs/nuts be used over and over again
- equal length shafts???
- Cosworth management
- 2.0 8V Corsa - Turbocharging?
- corsa b non-start
- corsa b 1.2 head gasket, whats involved
- C20xe Rod Bolts
- xe flywheel with f28
- coscast heads do they all have +1mm valves
- aftermarket management for LET, A to Z infos needed
- spark plugs for z20let
- Nova C20LET actuator incorrect adjustment affect idle?
- c20xe to let
- my c2let nova reves high all the time
- corsa c20xe fault codes
- c20xe AFM diameter
- C20XE into a MK4. ECU Diagnostic issue..
- Vectra b z16xe throttle body
- corsa 2.0xe multi ribb belt
- astra mk4 sxi 1.8 16v what to do........
- Boring out c25xe
- The end of my 3.1L V6, where to get stronger parts?
- C20let exhaust? And also problem backfiring
- Oil Consumption
- C16XE and X16XE differences?
- Corsa 1994 X16XE Exhaust
- Best oil and spark plugs for an xe???
- nova accelerator cable
- Vectra b gsi clutch slave cylinder leaking
- Z16xe/x16xe crank pulley bolt different threads??
- x14xe/x16xe on twin injectors - anyone done it?
- big end caps... what way round???
- Help with megasuirt plz
- saab 9-5 2.3 hot
- to K&N or not to K&N
- Fuel Pump Problems - Corsa B
- Equal length d/shafts for mk3 astra gsi-advantages?
- has anyone fitted an evo turbo to a Z20LEx?
- alloy welding a bung/lug onto side of C20LET cylinder head
- C20LET misfire on full boost
- Astra SRI (Bearing noise/Cam?)
- F23 box question
- Zafira issues? help and advice please
- Astra z16se cutting ou
- Oil and water leaks - 1.4 Sri Corsa B
- x16xe bhp and mod's?
- Vauxhall Astra convertible bertone 2.2 automatic revs dropping/ cutting out
- Stalling Corsa GLS
- calibra v6 plug problem
- F28 6 speed gearbox driveshaft seals??
- Removing Corsa Sport Engine
- derestricting my airbox
- pic
- Williams rods ?
- Calibra turbo fuel gauge stopped working!! first place to look??
- tuning advice c20xe with bike carbs
- Corsa B help...
- C20let Phase 3, Wont stay running help
- REALLY need some help please guys
- C20xe & twin 45's...
- fuel Pressure Reg Gauge Thread Size?
- Fitting lambda to early pre-lambda 20XE
- saab 2.0 turbo or 2.3 turbo in to RWD
- astra van malta 1st test run 10.6 sec
- C20NE knock sensor?
- r1 carbs
- electric impact wrench from ebay?
- convert f28 electronic to mechanical?
- Cdti150 looses power at 65
- Fitting Cruise contol onto my Vivaro
- whats this for? zzr carbs
- twin carb nova sr will not start
- loose dipstick tube
- EGR Valve
- f13 noisy diff bearing
- Where to get Manta CIH (1.9/2.0)valve stem seals?
- B Vectra cv-joint (2.6 l )
- c18xe help please
- OP-COM test on z20let.
- vectra b rough running
- f16 or f20?
- help clutch
- closed
- Best location for oil temp sensor on 20XE
- Best Turbocharger for 400/420 HP track day Astra MK3
- Cavalier Turbo - Screeching Noise!
- Z20let hesitation after 2.5k
- New ignition coil on C14XE
- astra g running problems
- lumpy vectra part two
- C.V Joint or wheel bearing
- F28 repairs?
- x14xe corsa x14xe astra ????
- corsa project gear linkage problem HELP PLEASE !!!!!!!
- 2.0 DTI engine info please.
- x16xe performance
- Powercap for C20XE - is this worth it?
- C20xe retops engines some really fast and some really slow why?
- Massive external oil leak from head gasket
- C20XE weber jet sizes, cam/ignition settings? Help please!!
- z16xe head gasket part number
- Oil filter relocation - what parts are people running? (xe/let)
- Newbie with Mk1 Astra GTE - Problem 1
- Small Block 8v Exhaust Flange CAD
- how easy is it
- Should i retorque apr head stud kit on a c20let
- C20XE Corsa cutting out
- P1220 fault code on 2.0DTi.
- F23 Astra Bell housing interchangable??
- another astra mk4 v6 conversion lots of questions help please :D
- walbro fuel pump,let parts
- Big Brakes repair KIT
- C20xe fuel lines, fse fuel pressure reg
- just fitted vxr injectors what to do now (duty cycle?!)
- GM clutch V's local car shop clutch,
- C16SE into corsa b
- Megasquirt/microsquirt
- oil pump issue on 2.0 16 v
- cavalier front hubs and drive shafts.
- mk3 astra c20let back to redtop
- vectra 2.0 dti cutting out
- Corsa C Electrical problem
- gear linkage prob
- c20let problems :(
- starter motor on c20xe with f16
- xe wiring last few wires info needed
- is this timing belt kit any good?
- Help with this wire? I should know the answer lol
- How to check and top up gearbox oil in Astra Coupe Turbo?
- astra gsi phase 2 c20let
- whats so good about commetic headgaskets??
- Maximum power for f20?
- vectra 2.2tid intermittent fault
- Corsa B C14SE fault codes?
- C25xe/x25xe coil packs
- jumpy vectra
- Anybody running an eaton m90 on an xe?
- 16v Engine into Calibra
- car kangaroos but no code?
- corsa 20seh.what parts are needed to turbo
- vectra eco tec x20xev rebuild
- intermitent smoking c20let
- c20xe tigra cooling issues
- c20let head
- Corsa 1.0 12v Engine change Whats needed? Help!
- x16xe1 blown its big ends!
- helpp
- Zafira 1.6 16v Idles but wont rev,Fault code p1230
- corsa b 1.2 8v to 1.6 16v.
- ebay con rods???
- c20let clutch options????
- tuning packages for z22se
- C20XE Recognition help needed
- engine splutterin on full throttle
- 1.7td fit in a corsa???
- c20xe firing order (distributor)
- my standard pistons
- over tightend xe sump bolts
- fitting a intercooler on a corsa b
- C25xe missfire
- X16xe or 2ltr 8v .
- HELP!! C20xe F16 box which driveshafts mk3 astra
- Heavy duty (rear) F28 mounts?
- corsa vxr won't start
- c20let oil pump??
- looking for mechanic !!!!!!!!!!!!
- Dud injector
- c20let idling video??
- X18XE1 Head Combustion Chamber Size? CC???
- c20let how too anti lag ???
- Corsa b hub carriers
