Results 1 to 23 of 23
Thread: **Coming soon** New Z20LET / Z20LEH & Z16LEH pistons manufactured by Cosworth
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    Within the next 2 weeks, Cosworth will have completed their first batch of Z16LEH pistons for the new Corsa VXR and also their forged pistons for the Z20LEH and Z20LET. Pics and details will be posted here fist.
    If you can't get into trouble you might as well stop at home!
    Banned
    Sardinia
    A Calibra or two
    Re: **Coming soon** New Z20LET / Z20LEH & Z16LEH pistons manufactured by Cosworth
    Do you have a price for the Z20LEH pistons and will you sell a batch of 6 rather than multiples of 4?
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    Quote Originally Posted by GaryB View Post
    You mean 6 pistons right rather then 4 pistons? (As opposed to complete sets). Im sure something could be accomodated yes.
    Apr 2009
    Manchester
    Corsa B sport 0.0 0v
    how much are the 1.6 pistons?
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    Cosworth pistons £552.54 to Mig member (set of 4 with rings etc).
    Banned
    Sardinia
    A Calibra or two
    Quote Originally Posted by Dave GSiT View Post
    and for 6?
    VAT included?
    Apr 2009
    Manchester
    do you do rods?
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    and for 6?
    VAT included?
    £828.82 Inc vat and postage.
    Quote Originally Posted by Matthew H View Post
    do you do rods?
    Yes, we do a multitude of other parts. Performance Engine Components :: PEC
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    Z20LET / Z20LEH pistons now in stock. details here :
    Cosworth Z20LET and Z20LEH pistons now in stock
    Mar 2007
    Swansea, United Kingdom,
    Vectra Gsi3.0 V6 F28
    This what I would like to know.
    I`m after some low comp pistons 86mm in diameter for an X30XE, which has a stroke of 85mm.
    Wonder if these would fit??
    Banned
    Sardinia
    A Calibra or two
    I'm considering using z20leh's for an x30xe. It is a choice whether to use these or stock pistons or these - I don't want to go below 9.0:1 and I'll be using a MLS gasket, stock z20lehs on x30xe are about 9.2:1, I note on that for z20leh engines these are specced at 8:5:1 as against stock 8.8:1.
    Amongst others, Wossners* also do low comps for this engine.
    *I'll only mention Wossners in this thread as they are also sold by DaveGSIT/ PEC
    Mar 2007
    Cool well I wanna get to around 8-8.5:1 if possible as I`m going Charged, and wanna do it properly. I`ve been told I can use standard rods too, so hopefully the pistons alone will do the job.
    Banned
    Sardinia
    A Calibra or two
    Quote Originally Posted by Jimbob Gsi 3.0 View Post
    I'm building a supercharged application as well, TBH uprated rods & ARP's were the first thing on the shopping list. Depending on power, add steel crank and maybe girdle too.
    I only know of one typeof pistons for the x30xe that'll get you close to 8.0:1 C/R but given it's DaveGSIs trade post it would be a bit unfair to mention them. ( Search my recent posts or look at my LET turbo spec...)
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    With referance to the V6 engines, its something we have looked into and it is possible. If anyone has any details from their OE engines (we need : comp height, head CC', gasket thickness, small end dia) then we should be able to make semi-educated guesses as to the suitable.
    Mar 2007
    X30XE.
    Cylinder diameter, 86.0mm
    Course of the piston, 85.0mm Stroke
    Have been told that the C20LET will fit,
    C20LET
    Piston Diameter (standard).......85,925/85,965mm (in 5 grades)
    Piston Oversizes.................0,5mm
    Piston Clearance in bore.........0,05/0,07mm
    Piston Rings - number............2 compression 1 oil
    Piston Rings - Width.............(1)(2) 1,5mm (3)3,0
    Piston Rings - Groove Clearance..
    Piston Rings - Gap in Bore.......(1)(2) 0,30/0,50mm (3) 0,40/1,40
    Oil Pressure bar (PSI)...........1,5(22) at idle
    Gudgeon pin diameter.............21mm
    Gudgeon pin fit in piston........Clearance 0,004/0,010mm
    Gudgeon pin fit in con rod.......Clearance 0,015/0,030mm
    Connecting Rod length............
    Crankpin Diameter................48,970/48,988mm
    Crankpin Undersizes..............0,25;0,50mm
    Will see what I can find dimension wise for you.
    Banned
    Sardinia
    A Calibra or two
    Jimbo, do you know anyone who has actually used c20let pistons in an x30xe engine?
    All those I know that have built low comp x30xe's & tried with those pistons have said the valve cutouts are in the wrong place hence the need for Z20LEHs etc.
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    X30XE.
    C20LET
    Thats a good start based on this its possible some C20 or Z20 pistons could suit.
    Mar 2007
    Have been told C20LET pistons and rods will fit straight on without issue, but without taking her apart to measure the criticals I dunno. Will have to pull my finger out!!
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    See, hearing and knowing are very different, We havent even got to valve angle and lift in relation to the cutouts on the pistons yet.
    Mar 2007
    Apart from sending you a stripped engine for you to use, what exactly do you need, and I`ll see what I can dig out, or measure??
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    Cylinder head would do.
    Mar 2007
    I can send you a cylinder head if you need one??
    Pm me if your interested and I`ll see what can be done.
    Also could send you a piston so you could measure little end and big ends then??
    MIGWeb Trader
    Jun 2004
    Essex
    Escort Cosworth
    If your serious let me know, I can give you our address to send some bits down but I'll be honest, we are snowed under at the moment and it might not happen for a couple of weeks....
