Guys we have restocked with the following quality products and they are available now.
Soft plush Merino Pure Wool Wash Mitt
*Made from the finest Merino pure wool
*Very Soft and high quality
*Elasticated cuff
*12" X 8 1/2" in size
£8.49 inc vat
Split dressing applicators 2 pack
The perfect applicator for dressing your tyres & mouldings. Also great for applying polish and wax to panels. Very easy to use and effective. Simply appy the dressing to the applicator and wipe over the surface ensuring your hands/fingers are away from the tyre products being used. Made from quality foam construction.
Product Features
Perfect for applying polish and dressing to the inside areas of your vehicle.
The sliced edges mean you can get a good grip on the foam while keeping your fingers away from the work.
Rinse under running water for easy clean up.
2 Pack @ £2.99 inc vat
Foam fingers wax applicators 2 pack
A novel new wax applicator that fits over your fingers.
Made from super soft foam, designed to fit your fingers giving greater control when waxing. It also features a tapered end allowing it to fit in many different sized wax pots, both large and small.
To use, fold the open end in on itself, creating a cuff that grips either two or three fingers.
£7.25 2 pack
Magic Sponge (Pack of 3)
The new Flexipads Magic Sponge will remove scuffs from interior door panels, kick plates, luggage compartment, boot, estate car load area, seat backs and simliar surfaces in trucks, buses, boats, caravans and around the home!
This sponge is very effective at removing impacted insects from the window, grill or hood of your car.
Caution should be taken on glossy surfaces as the sponge may cause a dulling.
Directions for use
Simply dampen the Magic Sponge and rub it vigorously over the offending mark.
£2.99 3 pack
50mm 5/16UNF DA Backing Plate
For use with DA polishers and sanders that use a 5/16UNF thread such as the PC, UDM, Megs G220 and Kestrel DAS6.
Ideal for 80mm and 75mm pads
Price is for one plate @ £5.99
All in stock now guys available on Autobrite-Direct - The only answer for all your car care products
Regards Mark
