Thanks for taking time to read this mini review of our new Interior cleaner 'FAB'!!
This is a car upholstery cleaner suitable for seats,carpets,door linings,roof linings and hard plastic surfaces such as dash boards etc.
It is a fresh powerful cleaner that cleans dirt and grime off any surface leaving a outstanding fresh Lavender fragrance. An excellent strength cleaner for carpets, rugs and upholstery cleaning, using spray extraction machines. It can also be used as a pre-spotter to remove stains. Works with all domestic and industrial machines.
  • Excellent low foam cleaner & stain remover.
  • Use with hot or cold water
  • Pleasant lavender fragrance
  • Concentrated - Dilutes up to 1:100 with water
  • Residual soils easily removed
Here we did a mini review on the 'FAB' cleaner on a Mondeo roof lining.
The tools for the job
Bottle of FAB
Upholstery Sponge
Microfibre
When we started we started with this
as you can see the lining is in need of a clean!
This was the concentrate we used with the cleaning process. To be honest we could have used less product and would have still done a fantastic job!
Then we topped up with water
Then we applied to the roof lining by a mist sprayer trigger on the lining
No extra water was needed here we just agitated with a upholstery sponge and as you can see its getting cleaner!
We then wiped away the excess with a microfibre cloth
This was the result on a 1/4 of the area
Impressive i must admit,,it was so easy to clean, the solution just cut through the dirt rapidly.
Now the other side
We applied the FAB
Agitate
Wiped away the excess
The results!
God im liking this product! (the black line at the top is a untreated area)
And the beauty of this product we only used amount
My review on this product is truly a great product so far,it provides a clean dirt free surface on fabrics with a pleasant lavender smell!
More reviews will be coming soon on more fabric surfaces.
Thanks for reading!
Mark
