Drilled through what I think is the cable for the hob today (standalone hob in the worktop) wiring is coming down from the ceiling, which I expected however whoever installed it hasn't ran the cable vertically down to the switch for whatever reason (!)
So the cable runs from the roof down to a heavy duty rocker switch above the worktop then I guess from there down behind the units and into the hob.
So the bit I've hit is the main section from the ceiling to the switch, I'm guessing this is either 6 or 10mm, 6 I reckon, is that right?
Was all installed fresh about 6 or 7 years ago. Anyway my question is instead of smashing out a tunnel and replacing the entire cable I was hoping to just cut out the section (was only using tiny drill bit) and rejoin with a junction box buried in the wall will this be ok? Guessing I would need a 30amp junction box?
There's hardly any damage at all to the cable, it actually still works only trips if the drill bit is in the hole, freakishly have very slightly skimmed the very edge of the black insulation so as long as nothing is poked in the hole everything works, that's why I'm hoping I can just snip and rejoin .
thoughts?
