MCB Rating - (Light Industrial)
Results 1 to 8 of 8
Thread: MCB Rating - (Light Industrial)
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    Astra, Vectra Estate...
    Evening
    Just finishing off the electrics in the unit.
    Im running a 180amp welder via a 32amp MCB (welder fused for 25amps)
    Im also running two lines of double sockets on series, each series has 4-6 double sockets - can i get away with 20amp MCB?
    The lights are in the same type of set-up (two lines in series) each series will run 4-6 standard 6 foot floresent tubes, can i get away with 16amp MCB?
    fr any help.
    Apr 2002
    cheltenham
    Mk3 astra sport
    Re: MCB Rating - (Light Industrial)
    It is all down to the cable used, not just the load. 16 amp for the sort of lighting you are talking about is very high, its usally 6amp on 1.5mm2 cable
    32 is ok for the welder if the cable you are using is 6mm
    That quantity of sockets should be on a ring with 2.5mm (maybe even 4mm if it is a very long run) cable and a 32amp breaker
    May 2003
    northampton
    Thread Starter
    Quote Originally Posted by james sport View Post
    you must have been listening to a call i was just having...lmaolmao
    Welder is fine on 32 and using 6mm cable
    Sockets both to run on 32's (2.5mm2 cable) max run 12 meters each (shall look at changing to ring set up as might have a nice large roll of 2.5 coming)
    Lights 6 amps on 1.5mm2 same type of distance.
  5. Remove Advertisements
    Feb 2003
    northampton
    manta A + manta B
    have you done it in singles in conduit j?
  7. #5
    May 2003
    northampton
    Thread Starter
    yep....you know the wall on your right as you come into the unit i have done a run of plugs along there, then i need to rig something up to go over/across the rear doors to run another load on the opposite wall.
    welder has its on 240 shut off industrial unit switch.
  8. #6
    Feb 2003
    northampton
    manta A + manta B
    ill have a gander 2moz
  9. #7
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Don't forget to earth !!
    I am too old for my Calibra and my Calibra is too old for me! we are both stuck!
  10. #8
    May 2003
    northampton
    Thread Starter
    Quote Originally Posted by MSG View Post
    no need...shall be standing the new welder in a child's paddling pool while using it.
    c you tomorrow paul.
