variable speed control for 12v motor?
Results 1 to 9 of 9
Thread: variable speed control for 12v motor?
    May 2001
    South of France
    vectra sri v6
    Hi,
    What I need is a system to allow me to control the speed of a small 12v motor by turning a knob. It has to go from zero to full rpm of the motor and have quite fine control over it. I have a 12v supply, so just need the speed control bit. The motor movement must be quite smooth, not jerky.
    buy, build, rip out of an old appliance....?
    any suggestions?
    Oct 2003
    Westhill Aberdeenshire
    Like it's a hire car
    Re: variable speed control for 12v motor?
    you can buy manual servo operated speed controllers from model shops, maplins, or ripmax quite cheaply
    Oct 2003
    Dom
    Dom is offline
    MIGWeb Moderator Dom's Avatar
    Sep 2001
    Northants
    73bhp MK4 Astra POS
    Above link from Maplin is fine. Just watch how much current your motor takes.
    PWM control of the motor is the only way to go really. Linear regulation wastes a lot of heat/power and reduces the torque of the motor significantly at lower speeds.
    Dom's online shop - www.picbits.co.uk/catalog,bulbs,cable,heatshrink etc
    May 2001
    South of France
    vectra sri v6
    excelent, thanks.
    Apr 2006
    Wrexham
    http://www.cpemma.co.uk/pwm.html
    if you need more current, use a different mosfet.
    Feb 2001
    Edinburgh.
    Vectra GSI
    You can pick up an old Model Railway controller no problem. They work from 0-12v and can be had pretty cheap. Mains powered too.
    CHAMELEON
    Aug 2003
    east yorkshire
    How about an old battery drill motor control ..... high current rated :-)
    Jun 2008
    Peterborough
    1.6 MK4 Astra
    Quote Originally Posted by Chameleon View Post
    I think the model railway controller is best, and they're powered by 12v mostly, they have seperate transformers
