Aftermarket Astra GSi Grille?
Is there an aftermarket Astra GSi Grille which is made to suit a phase 2 ie 1994 onwards?
I know the answer is most probably NO but its worth a try
thanks
Nope there isn't. But if you're that desperate for a GSi grille for the phase2 then you'll have to have one brought in from South Africa. They do 2 GSi grille's, one for the old style and one that is for the phase 2's.
Pricey to get hold of.
Re: Aftermarket Astra GSi Grille?
Originally posted by FAST PHIL Is there an aftermarket Astra GSi Grille which is made to suit a phase 2 ie 1994 onwards?
thanks You need to replace the headlights,from an earlier mk3,then you can get a GSi grille.
guess im buying phase 1 lights then - was hoping to avoid it but its not too much
