Results 1 to 3 of 3
Thread: nova arches
    Aug 2002
    Colchester, Essex
    passat TDI
    nova arches
    if the arch has been ground down so that u can feel a distinct gap between the inner+outer arch, is the arch repairable?+approx cost or difficulty if done myself?
    Asta
    Guest
    if its been that way for a while then the outer may have started to rot from the inside and may be better getting replaced too. you could probably repair it your self if youve got a welder and some know-how.
    usually when the arch has been ground away its new arch time.
    Aug 2002
    Colchester, Essex
    passat TDI
    bugger. oh well, it is repairable though.cheers
