Results 1 to 8 of 8
Thread: Alloy Wheels And Tyres Help Needed
    Dec 2001
    GREECE ATHENS
    ASTRA F GT C16SE
    HELLO
    i have an astra mk3
    i have lower the car 3mm with eibach springs
    my tyres are 195/60/14 factory size with
    factory alloy wheels 14'' ET 49
    my question is if i put 15'' alloy wheels ( vauxhall second hand )
    what tyres dimension should i have
    205/50/15
    195/50/15
    195/55/15
    if i use any type of this tyres will i have the ability to use snow chains in the front wheels in case it is needed ?
    thanks in advance
    Dec 2001
    GREECE ATHENS
    ASTRA F GT C16SE
    Anyone who has 15'' alloy wheels here
    Mar 2001
    Torquay
    LC 20VT
    HI had 205/50/15.ET was 45 i had no rubbing problems at all and mine 60mm lowered
    heres a pic
    Dec 2001
    GREECE ATHENS
    ASTRA F GT C16SE
    nice wheels you have on your astra and with lowering seems
    superb and the gsi bumper you have
    so i will not have any problem with 15'' alloy whells and this tyre dimension for snow chains?
    thank you
    Mar 2001
    Torquay
    LC 20VT
    I have a GSi bumper because it is a GSi
    Unsure of the snow chains,we dont get snow here lmao.
    Im sure the manufacturers of the chains will be able to help.
    The wheels are sold now i have these 17 on now.
    Dec 2001
    GREECE ATHENS
    ASTRA F GT C16SE
    great choice for the 17 wheels
    do you think for the 15'' alloy wheels is a lot of space in the front
    for snow chains
    i have seen a lot of snow chains in the shops for 15'' alloy wheels but i was wondering if they fit because mine is lower 3mm in the front
    thanks
    Mar 2001
    Torquay
    LC 20VT
    At 30mm lower,you "should" be ok.Will give more room between tyre/arch.
    This will help you decide the overall diameter of the wheel/tyre combination.
    Dec 2001
    GREECE ATHENS
    ASTRA F GT C16SE
    thank you very much
