Basically does it just involve removing the 9 bolts (or 13 howeva many)
and off it comes or is there more involved to get it off, also how long du reckon this sorta job takes for a novice (maybe 2 novice's lol)??
Owns a white Mk3 turbo diesel with more stopping power then engine power..... boosting 0.9bar, Now De-catted!!
easy mate.
all the bolts out of the top. including the screw that holds the scuttle panel down (be careful not to lose the clip underneath as you will not get the screw back in otherwise).
one bolt behinf the front door (youl find this by opening the door.
one bolt underneath behind the front wheel (this is a nut n bolt thing and has a tendency to rust off)
two bolts behind the side of the front bumper. you will have to pull the side of the bumper away, or even remove it altogether to get at these.
see, no too bad at all.![]()
migweb.
running on flexitime, by the umpaloompas
sounds pretty simple have to find out about the bolt where the scuttle panel is as i neva noticed that one
and removing the front bumper is a good idea then to get to the front wing is du not need to go that far
Well considering the bumper is only held by two bolts and 3 screws it worthe whipping it off for ease of access mate.
It really is a simple job, the only nut that is likely to give grief is the one behind the front wheel at the sill level.
Thanx ada-v and Mav for ur advice,
hopefully give it a bash tomz, gonna remove the bonnet aswell but that looked like 6 bolts then remove so that should hopefully be simple aswell
4 bolts for the bonnet mate.
2 on each hinge.
as mavv said, the sill ones are a c\/nt....
the mountings have a tendency to rust and come off.
best to get a couple of nuts n bolts to replace them when refitting.
tokk me n mick about 15 minutes to whip mine off n replace them.
migweb.
You may also have to remove the indicator as it curves slightly around a lip on the front wing.
Dont forget the screw securing the scuttle pannel to the wing, I've forgotten it in the past and....
*crack*
"Oh pants now i need another RHS scuttle pannel"![]()
Dont look like im even gonna get the parts..... shame but nothing i can do except watch my car (or more specifically my front wing) rust to its grave
which wing you need dude?
front passenger side, but thing is this one was gonna be the same colour as mine (nordic blue - dont laugh not a bad colour )![]()
Whats funny about Nordic blue?
Havent seen it so I dont know![]()
lmao
yes you have seen it mav! my cav is nordic blue mate![]()
now tell me its not a funny colour lmao
Well thats because it is the colour the dead parrot was.....Originally posted by mavvmad
Veni,Vidi,Scubi
Oh you mean sky blue thenlmao lmao lmao
Sorry, I don't get it. What is funny about Sky Blue?Originally posted by mavvmad
Veni,Vidi,Scubi
