Your car got central locking?
You can't actually push the lock in?
Simon - No central locking, to open the boot you turn the key to the right and push the lock bit in !!
Maybe you use another term, but i call it the lock
Seems that something may have broken inside. Best way to check is to get the boot open buy folding the rear seats flat. Clamber into the boot and take the tailgate trim off. Should be held on with 6 -8 allen bolts or torx bits.
You should be able to see the release wire going to the lock itself. Pull that and the boot should open.
Originally posted by SimonP Clamber into the boot and take the tailgate trim off. Should be held on with 6 -8 allen bolts or torx bits.
u cant - theres 2 bolts that u cant get 2 with the boot closed. Ive taken these 2 bolts out of mine for this very reason. I also have no bootlock
Well, just break it. Those rear internal panels are easy to get hold of.
