Results 1 to 9 of 9
Thread: Calibra On 18's
    Sep 2002
    Leicester
    Fiat Coupe 20v Turbo
    Calibra On 18's
    Is any arch work needed for the above cos i dont wanna get myself into something without knowing what im getting myself into first
    lee may
    Guest
    18's on a cally will go straight on with no arch mods if you stick to ET45, 7 or 7.5 x 18 and run 215/35/18 tyres.
    Sep 2002
    Leicester
    cheers m8
    Sep 2002
    Leicester
    any idea how low id be able to go with 18's on?
    lee may
    Guest
    No idea,
    My cav is lowered 60mm with the above wheels and it never rubs.
    I have had the rear springs out compleatly so just sitting on the bump stops and it didnt hit the arches
    Sep 2002
    Leicester
    so going by ur cav i should be able to get 18's on with a 40mm drop with no problems and no arch work?
    i dont wanna drop it silly amounts as when the infinty kits on that will give it the impression of being alot lower i just want the wheels to sit in the arches nice.
    all i gotta find now is a cheap place that does 18" Oz Superlegerra's
    lee may
    Guest
    Just lowering 40mm will be ok but I dont think you can get OZ's in ET45.
    Feb 2001
    Edinburgh.
    Vectra GSI
    The difference between cavs and callys is that the rear arches on the cav come straight down and then flare out over the wheel arch. The cally arches actually come out first and then come straight down so as long as the wheels fit the cally arches you can drop it as much as you like.
    By the way Lee, do you have any camber trouble with your 60mm drop? I have been having no end of trouble with tyre wear even with a 35mm drop. I DO have a camber adjusting kit but have had to fit standard turbo springs at the moment!
    CHAMELEON
    lee may
    Guest
    I do have some camber but not bad enough to worry about.
    I replaced the trailing arm bushes which sorted out most of the camber.
