Is there much difference between adjustable and non adjustable cowlings other than the hole for the adjuster stick?
The only real difference is the airbag models which never had adjustable colums. the cowlings on them are longer to.cover the airbag squib (slip ring)
on non airbag models the cowlings are shorter. pitstoppete has early adjustable ones i think mate if thats what you need![]()
Well i have an adjustable one but want a non adjustable one as the hole is ugly and not required.
Do you have an airbag? also are the cowlings in good nick? pm me if you dont need them might be able to sort a deal
The cowling on mine is fine. Non airbag model but also fitted to a mk3 Astra and not a Cav lol
Ah right. i was gona say at first ive never seen a mk3 astra with adjustable steering. till i thought about what you said in the first post
It was fitted to allow the fitment of my omp boss and momo wheel.
if you had a momo boss they fit inside the longer airbag cowlings, omp boss must be slightly larger
No idea but it works just fine excluding the hole that i will hopefully cover up at some point.
no probs man![]()
