What car is this steering wheel is this from please?
Results 1 to 15 of 15
Thread: What car is this steering wheel is this from please?
    Nov 2010
    South Wales
    Vectra GSI or SRI or astra coupe turbo?
    I,m after one like this.I hope you can help.
    Here's the pic.
    Thanks.Lee.
    MIGClub Member Corsa_LET's Avatar
    Sep 2011
    Nottingham
    Astra z20let sleeper
    Re: What car is this steering wheel is this from please?
    Vec gsi phase 2 had silver at the bottom & a silver bit at the top
    Jan 2011
    That`s from Astra Bertone.I have one one mine.Is very good looking but very hard to take of in case of need.
    Oct 2007
    Bracknell
    1.8 mk3 astra GSI
    Since its on a MK3 astra it may well be off a corsa B, i think the mk4 is a different spline to a mk3
    Sep 2011
    Nottingham
    Looks like a later corsa b wheel. I think there are better ones out there like the coupe turbo & vectra gsi ones
    Jan 2008
    south wales
    corsa gsi c20let wip
    def not a corsa one
    MIGClub Member DrewyCoupe's Avatar
    Jan 2011
    Chesterfield
    Astra Coupe Turbo
    loks like vec b sri
    Designed To Be Driven
    Nov 2010
    South Wales
    Quote Originally Posted by DrewyCoupe View Post
    loks like vec b sri
    I was thinking it's a vectra b sri, the gsi has grey on the outer edging and is a 3 spoke .I also know it's not the astra coupe turbo wheel aswell.
    Just looked and it is indeed an vectra b sri wheel,the car for sale section,there's a 2.2 sri150 vectra and it had the same wheel as I am after.The vectra gsi in the for sale section also has the same wheel but with grey on the top and bottom of the outer parts.
    I don't mind if it's off and sri or gsi as I'm only after the centre section as mine is a bit scuffy as in the pic,so either steering wheel will do,not bothered about the outer area and being worn as I won't be using that part anyway.
    Thanks.Lee.
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    Vectra B wheel that. Def not corsa.
    I see them day in day out, which part do you need? airbag?
    Nov 2010
    South Wales
    Quote Originally Posted by 8valve-craig View Post
    Don't need the airbag itself,just the centre section that bolts into the rest of the wheel.
    Thanks.Lee.
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    If i find one this week il see if it comes apart and let you know.
    Nov 2010
    South Wales
    Thanks Craig,the face of the centre section should just undo and come away from the rest of the wheel.
    Cheers.Lee.
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    Defo a vectra b wheel,
    East Mids Regional Co-ordinator simonsri's Avatar
    Dec 2010
    Chesterfield
    Vectra Sri 150
    loks like vec b sri
    deffo a vec b sri and that 100% not a coupe bertone one they have a longer bit at the bottom of airbag.
    Jul 2006
    wrexham
    astra gsi phase 2
    deffo a vec b sri took it out my self out of one and put it in my cav, bit of playin around drill new hole and a bit of filing but it went in ok and looked the dogs danglies
